Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > General Scale Talk
Thread: 10" tuber
Old 06-20-2006, 05:08 PM   #1
Default 10" tuber
Now that I've gotten some progress done I thought I'd share this creation I'm working on. Its a TLT with a parma bug body (yep, an older body brought out of retirement). Anyway, the body is short, and I'm aiming for a little truck I can shoot down the dorm halls and jump around the skate parks around here.
Plans are for the tube frame to be white. I'm going to take the blue anodizing off the shocks. The bug body is pearl biohazard orange. Wheelbase will be 10.25" or so. Chopped springs with limiting straps for some droop off of jumps. Laid down pede tranny with motor on the passenger side to combat torque roll.
I'm using mapp gas, 3/16" brake line from autozone (I have noticed no noticeable fumes coming off the two times I forgot to prep the area for sauder, however, it does boil and change colors letting me know I screwed up). Anyway, I have to say, I suck at fabrication, every form of fabrication, so either I found my niche with this stuff, or anyone can and should do this atleast once. Bending and forming everything seems to be the hardest part for me anyhow. Well, onto some pics...
the general idea:
http://www.one18th.com/forums/attach...chmentid=23195
my solution to holding 3/16" tube in a 1/4" bender:
http://www.one18th.com/forums/attach...chmentid=23198
another over all, taped up:
http://www.one18th.com/forums/attach...chmentid=23203
brazing progress, back end pretty much done:
http://www.one18th.com/forums/attach...chmentid=23244
http://www.one18th.com/forums/attach...chmentid=23245
http://www.one18th.com/forums/attach...chmentid=23246
and the must have tuber tool:
http://www.one18th.com/forums/attach...chmentid=23243
Shortly after I realized I didn't like how the front end was going together, so I've scratched that idea, and am taking a quick break writing this. I need to figure out how I want to box out the front, and the details of the cab are not yet figured out either.
Plays_with_Toys is offline   Reply With Quote
Old 06-20-2006, 05:41 PM   #2
looking really good too. i seen a bug body 4x4 in a off-road mag last week and it looked really cool rig to build. keep up the good work to.
rich
rocpede is offline   Reply With Quote
Old 06-20-2006, 07:03 PM   #3
Front end is coming together, probably won't change much from this.
http://www.one18th.com/forums/attach...chmentid=23247
I need to burn off all the goobers hanging off. I've decided how I want the trans/battery, however, I'm having a heck of a time bending the tube to form fit my stick pack...
Thanks for the compliments rocpede!
Old 06-20-2006, 07:08 PM   #4
06 Super National Champ
JasonInAugusta's Avatar
Lookin' good.
If you have a MIG available, tack the tubing with the MIG, then braze the joint. Work will go much faster and be less of a headache. Maybe you could tack it all with a MIG on the weekend, then braze in the dorm.
And the thread title is hilarious!
JasonInAugusta is offline   Reply With Quote
Old 06-20-2006, 10:24 PM   #5
Thanks jason! As for a welder, none near me. I don't even have a drill press I had planned to take welding classes next summer, but this project just solidifies that.
Added the floor runners and a cross member below the windshield. I chopped part of the lower crossmember off to clear the front driveshaft. I am going to add a little transmission hoop thing there and tie that into the upper cross member to get back some of the strength I lost when I cut it.
http://www.one18th.com/forums/attach...chmentid=23258
http://www.one18th.com/forums/attach...chmentid=23260
Old 06-21-2006, 03:37 AM   #6
Cool. You don't see very many Bug Tubers.
Old 06-21-2006, 04:14 AM   #7
Here's a bug-based tuber.The guy building it is using PTI mini Goliath axles.
BaddClod is offline   Reply With Quote
Old 06-21-2006, 08:57 AM   #8
~The Scale Shop~
STANG KILLA SS's Avatar
lol at the VW logo in the door.......
STANG KILLA SS is offline   Reply With Quote
Old 06-21-2006, 09:31 AM   #9
Nice build. I like the way it looks.
Double J is offline   Reply With Quote
Old 06-21-2006, 04:57 PM   #10
Got the battery holder bent up, I need to figure out how I intend to keep the battery in though. ooh I just had an idea! Anyway, Here's the stance of the truck with some axles under it.
http://www.one18th.com/forums/attach...chmentid=23270
http://www.one18th.com/forums/attach...chmentid=23271
http://www.one18th.com/forums/attach...chmentid=23272
Still to do: side braces, windshield braces, mount the battery holder, and attach link mount box below the truck. Also need the rear tranny hoop and braces, and I need to figure out how to attach my shocks, since the nuts I was going to use won't adhere to the sauder? Oh well. I have ideas for that as well.
Old 06-21-2006, 05:06 PM   #11
looking good plays with toys glad to see ya back around
Got Rocks? is offline   Reply With Quote
Old 06-21-2006, 05:33 PM   #12
Team *
62PYRO's Avatar
Looking good.I've wanted to do a bug also.Decided to use it as a sand dragger.Nice thing is,that body has been rereleased in case you want spares.
http://cgi.ebay.com/Parma-PSE-VW-Bee...QQcmdZViewItem
Keep the pics coming.
62PYRO is offline   Reply With Quote
Old 06-26-2006, 08:00 PM   #13
Just a little progress today. Got the lower cage all mapped out, including the battery holder. Now I need to figure out link geometry, so I will probably do shock mounts, tranny mounts and my top link mount for the axle on wednesday. Then I can do the suspension mounts on the chassis, build the links and start testing it
http://www.one18th.com/forums/attach...chmentid=23433
http://www.one18th.com/forums/attach...chmentid=23434
Old 06-26-2006, 09:32 PM   #14
lookin good there i like the overall looks of the thing, but it looks like the battery might be a lil low that direction, but thats just the way it looks to me.
T_Boy is offline   Reply With Quote
Old 06-26-2006, 10:03 PM   #15
Yeah, there's only about 2-2.5" of ground clearance, but again, this is no crawler, its designed more as a Monster Jam style monster truck racer. Hopefully if I can brace the axles well enough I can get some video of it at a local skate park. They just built on a year ago that has tons of ramps.
Old 06-27-2006, 12:02 AM   #16
That Was Totally Ninja!
rbgerrish's Avatar
Hey that's super cool! I like the design, and you can tell the final bug will look awesome. It'll probably be a blast to drive! You've got some great tubing skills too.
ryan
rbgerrish is offline   Reply With Quote
Old 06-27-2006, 12:49 AM   #17
Looks like good progess so far.
Old 06-27-2006, 08:55 PM   #18
ryan
Praise from Caesar! Thank you.
And thank you to everyone else supporting this little truck of mine. Wait till you see the top link mount, it should be an easy to replicate tube mount.
Old 07-03-2006, 07:54 PM   #19
Update time. Took me forever to get the links mounted. So long in fact, that by the time I figure out a solid way to do it, a thunderstorm rolled in and forced me to close shop for the night. Its subsided, but there might be another wave heading in.
I was going to keep the shocks secret until the final reveal, but oh well... Remember my worries about the driveshaft angles? Yeah, still worried. I'm going to do some filing, and possibly some shock travel limiting (maybe straps? maybe internal?)
http://www.one18th.com/forums/attach...chmentid=23659
http://www.one18th.com/forums/attach...chmentid=23661
http://www.one18th.com/forums/attach...chmentid=23660
http://www.one18th.com/forums/attach...chmentid=23662
Old 07-04-2006, 12:47 AM   #20
Location: a place of settlement, activity, or residence.
Nice work so far! I do have to say those driveline angles look pretty scary though. How do you think they will hold up?
thaclodking is offline   Reply With Quote
