Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > General Scale Talk
Thread: leaf springs ???? help ????
Old 06-30-2006, 06:02 PM   #1
Default leaf springs ???? help ????
I need a step by step on how to make leaf spring out of the recoil springs
I dont know how to make the little eyelets, Or whatever the shackle bolts to on the spring
kcrossman is offline   Reply With Quote
Old 06-30-2006, 08:25 PM   #2
what scale are you tryin to build leafsprings for?
swamped2a is offline   Reply With Quote
Old 06-30-2006, 09:45 PM   #3
I just heat the end slightly...just enough to get a dim glow, and then bend it around a screwdriver using some small needle nose pliers.
Destroyer is offline   Reply With Quote
Old 07-06-2006, 06:11 PM   #4
thanks for your suggestion, i got them built today.
