Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > General Scale Talk
Thread: Diaz Designs rear pivot scale truck
Old 07-07-2006, 04:38 PM   #1
I joined the Band!
Default Diaz Designs rear pivot scale truck
what do you guys think of this. it's just in the design stages. might cut one out of plexi today..
the rear end pivots to allow for more flex.
ddiaz10240 is offline   Reply With Quote
Old 07-07-2006, 04:41 PM   #2
awsome design i saw somthing like this on a top truck challenge a few years back, it was like a old army willies jeep called the anialator or somthing seamed to work good but it always broke somthing were it meets together
rockschooler is offline   Reply With Quote
Old 07-07-2006, 04:42 PM   #3
Wow you come up with some of the most amazing ideas. I would really like to see if this one works.
T_Boy is offline   Reply With Quote
Old 07-07-2006, 04:48 PM   #4
K_B
This is my Cracker Jack Box Engineering Degree talking, but it may have a tendency to torque twist pretty bad...
K_B is online now   Reply With Quote
Old 07-07-2006, 04:55 PM   #5
I agree with the torque twist ideabut I would try it and see!
doubledub is offline   Reply With Quote
Old 07-07-2006, 05:02 PM   #6
I know it doesn't really matter, but that truck was called the articulator.
Racefan1115 is offline   Reply With Quote
Old 07-07-2006, 05:05 PM   #7
yeah thats it i couldnt remember 100% but that makes sense to be called the articulator
Old 07-07-2006, 05:07 PM   #8
yeah you would need a way to lock and unlock that feature, as it would hurt you in some instances, also dampening would be a good feature as well.
4stAir is offline   Reply With Quote
Old 07-07-2006, 06:08 PM   #9
nice concept, but that may add torque twist. if you lower the pivot point the axle will have more of a twisting action then a side to side action
Warn Off Road is offline   Reply With Quote
Old 07-07-2006, 06:13 PM   #10
I joined the Band!
i can also add a servo to twist the chassis when i want it too using a 3 channel radio.
Old 07-07-2006, 06:15 PM   #11
I joined the Band!
i think i might build this one. just to see if it works.
Old 07-07-2006, 06:18 PM   #12
I'm a stupid C U N T!
slobin3d's Avatar
what are you going to use as a pivot?
slobin3d is offline   Reply With Quote
Old 07-07-2006, 06:19 PM   #13
i think the servo idea is a good one but then you are locked, with no free float...
Old 07-07-2006, 06:19 PM   #14
I joined the Band!
not sure yet. but i'm sure that i can come up with something that will be easy use. out of standard parts.
Old 07-07-2006, 06:20 PM   #15
How would the driveshaft connect to it? I would thenk when it pivots, the driveshaft would restrict it. Or is this a chassis for a clod?
kerosinek is offline   Reply With Quote
Old 07-07-2006, 06:21 PM   #16
I joined the Band!
you would still ahve the leaf springs for the travel and the servo when you need more flex. adjustable suspension.
Old 07-07-2006, 06:22 PM   #17
I joined the Band!
i just need to center the tranny on the frame. the drive shafts will have a swinging motion. i just need to find the sweet spot
Old 07-07-2006, 06:27 PM   #18
thats a good idea, what if you attach a shock so when the chassis is level the shock is at 50% travel, it would limit your torque twist and limit how fat it articulates. just an idea
also wouldnt the hole have to be centered?
Crawlsalot is offline   Reply With Quote
Old 07-07-2006, 06:30 PM   #19
I joined the Band!
that's a secret. i have a few ideas on how to get it to work
Old 07-07-2006, 06:37 PM   #20
slobin3d's Avatar
what would you do about body mounts?
