04-27-2012, 06:37 PM | #1 |
Rock Stacker Join Date: May 2009 Location: Hobart, Tasmania, Australia
| IFS axial build
Hey all, i'm trying to get some info on a build i want. i wish to use a ax10 rear end and a IFS front end, for a koh style rig. but i'm haveing issues as to what diff center to use in the front. i plan on running 1/16 slash hubs/driveshafts and custom arms, but i'm having issues finding a diff center that is the same ratio as axial 13/38 = 2.92:1 and with outputs i can run the slash shafts on also something that isnt to hard to mount would be good. so can any one point me in the right direction as to find ratios/housings info? or maby some one knows? im under the impression E-revo is very close? this might be a posibility?? |
04-27-2012, 06:42 PM | #2 |
Quarry Creeper Join Date: Jun 2010 Location: Ravenna/ Sault Ste. Marie
| Re: IFS axial build
check and see if you can find a front end that matches the over or under-drive gears for the axial axle. then you just get the diff and the new gears for the axle as well
04-27-2012, 07:22 PM | #3 |
RCC Addict Join Date: Oct 2007 Location: gervais
Slash 4x4 is the closes you can get to what a stock axial axle is. It will be just slightly and I mean just slightly overdriven but that's as closes you'll get it
04-27-2012, 09:06 PM | #4 |
Newbie Join Date: Nov 2008 Location: Vancouver B.C.
| Re: IFS axial build
Hey Ive seen that done. Check this out it might help......http://scalebuildersguild.com/forum/...791-Bush-Buggy |
04-28-2012, 02:10 AM | #5 |
| Re: IFS axial build
Thanks for the info guys! looks like 4x4 slash diff center and 1/16th slash hubs and shafts will work perfect. as far as i can see i can run 1.9's over the 1/16th hubs! i will start a build thread soon. this one should be fun! |
04-28-2012, 02:15 AM | #6 |
| Re: IFS axial build
also Copious is there a build thread on your display pic truck?
04-28-2012, 08:43 AM | #7 |
| Re: IFS axial build There sure is 3 posts back I put up a link. If you use HPI E-savage parts you can use the axial gear sets........ I don't have the part number but you can get from HPI the whole diff, carrier and a portion of the suspention
IFS axial build - Similar Threads | ||||
New ifs basher/foff rig build | lagz2point0 | 2.2 Scale Rigs | 8 | 02-17-2012 01:33 AM |
Street's t4r build(going IFS) | StreetKill831 | Losi Micro-Rock Crawler | 95 | 02-08-2012 07:53 PM |
Slash 4x4 IFS build parts list | iflylolo | General Scale Talk | 11 | 03-08-2011 05:04 PM |
1:1 Ifs | tomh1426@yahoo.com | Chit Chat | 25 | 09-27-2005 11:34 PM |
