Winner = spankbomb Crawler Innovations 1.9 Closed Cell Foam Set *GIVEAWAY* Crawler Innovations is giving away two pairs of 1.9 Closed Cell Lil' Nova Foams in any size the winner chooses. "thumbsup" Crawler Innovations has three sizes of 1.9 dual stage foams and the are 4.25", 4.50" & the 4.75". We offer the outers in either soft, medium & firm and they are die cut from conventional foam and are not temperature sensitive. The closed cell inners are water proof and not temperature sensitive either. These are available on the C.I. web site if you would like to order your own: Crawler Tires, Crawler Foams, Parts and Accessories by Crawler Innovations The giveaway winner will be chosen by a random number generator on May 31st. To enter this giveaway you must be a star holding member here on RCC. If you need information about becoming a star holding member, click this link. Thank you for entering and good luck"thumbsup". The closed cell inner foams are designed for 1" wide 1.9 bead locks. The outer foam is Over- Sized on purpose to encase the closed cell inner, and to provide for weight support. 1.9 Lil' Nova Outer Foam Choices: Soft Medium Firm This is the shortest of the 1.9 closed cell inners and is designed for scalers weighing 5 - 6 pounds using tires 4.25" to 4.50" Tall. http://farm7.staticflickr.com/6032/6...5736943d_b.jpg This is the middle height of the 1.9 closed cell inners & is designed for scalers weighing 6 - 8 pounds using tires 4.375" to 4.625"Tall. http://farm8.staticflickr.com/7059/7...0fc72dde_b.jpg This is the tallest height of the 1.9 closed cell inners & is designed for scalers weighing 9 - 12 pounds using tires 4.750" to 5.0" Tall. http://farm8.staticflickr.com/7277/6...62422912_b.jpg The 1.9 closed cell inners & the 1.9 die cut outers are available separately: http://farm7.staticflickr.com/6057/7...971116e4_b.jpg Comparison Pictures: http://farm8.staticflickr.com/7190/7...0c478345_b.jpg http://farm8.staticflickr.com/7135/7...87c5df78_b.jpg http://www.crawlerinnovations.com/pr...20SS%20NF1.jpg |
Re: ***Giveaway*** Crawler Innovations 1.9 Closed Cell Foam Set ***GIVEAWAY*** First one in! |
Re: ***Giveaway*** Crawler Innovations 1.9 Closed Cell Foam Set ***GIVEAWAY*** Im in, thanks for the chance"thumbsup" |
Re: ***Giveaway*** Crawler Innovations 1.9 Closed Cell Foam Set ***GIVEAWAY*** Great products, in and thanks "thumbsup". |
Re: ***Giveaway*** Crawler Innovations 1.9 Closed Cell Foam Set ***GIVEAWAY*** Certainly could use another set, thanks for the chance. |
Re: ***Giveaway*** Crawler Innovations 1.9 Closed Cell Foam Set ***GIVEAWAY*** could use some of these. count me in! |
Re: ***Giveaway*** Crawler Innovations 1.9 Closed Cell Foam Set ***GIVEAWAY*** In thanks forthe chance. |
Re: ***Giveaway*** Crawler Innovations 1.9 Closed Cell Foam Set ***GIVEAWAY*** im in thanks |
Re: ***Giveaway*** Crawler Innovations 1.9 Closed Cell Foam Set ***GIVEAWAY*** I'm in. Thanks for the chance!! |
Re: ***Giveaway*** Crawler Innovations 1.9 Closed Cell Foam Set ***GIVEAWAY*** Nice giveaway Eddie! In for this one as well! "thumbsup" Thanks! |
Re: ***Giveaway*** Crawler Innovations 1.9 Closed Cell Foam Set ***GIVEAWAY*** I'm in, thanks"thumbsup" Could really use a set of these. |
Re: ***Giveaway*** Crawler Innovations 1.9 Closed Cell Foam Set ***GIVEAWAY*** Im in! Really need a set of these for my Highlift right now! |
Oh yeah, I'm in. Sent from my SPH-D710 using Tapatalk 2 |
Re: ***Giveaway*** Crawler Innovations 1.9 Closed Cell Foam Set ***GIVEAWAY*** Need these 4 sure!!! thanks 4 the chance... |
Re: ***Giveaway*** Crawler Innovations 1.9 Closed Cell Foam Set ***GIVEAWAY*** Thanks for this Eddie "thumbsup" |
Im in. thank you for the chance Sent from my DROIDX using Tapatalk 2 |
Re: ***Giveaway*** Crawler Innovations 1.9 Closed Cell Foam Set ***GIVEAWAY*** I am in, thanks for the chance! :) |
Re: ***Giveaway*** Crawler Innovations 1.9 Closed Cell Foam Set ***GIVEAWAY*** Definitely in. Thanks for the chance"thumbsup" |
Re: ***Giveaway*** Crawler Innovations 1.9 Closed Cell Foam Set ***GIVEAWAY*** I am in thanks for the chance, I need some of these. |
Re: ***Giveaway*** Crawler Innovations 1.9 Closed Cell Foam Set ***GIVEAWAY*** I'm in, thanks for the opportunity. |
