| | #1 |
| Newbie Join Date: Jul 2006 Location: taftville
| Just FYI, i am working on a closed loop hydraulic system using a C02 cylnder for pressure and a scale dual action ram. Anyone interested i will post my progress...I am building a scale buggy running an .26 stihl engine for power and tlt axles.I want real looks so i am attempting to go all out.. Thanks and let me know |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Jun 2006 Location: BUILDING A CSC-1 in south mississippi
| it sounds like an awsome idea how bout some pics, and i dont think tlt axles will hold up to the .26 power! |
| | #3 |
| Pebble Pounder Join Date: Jan 2006 Location: Evansville
| Yes You Must Post Pictues!! |
| | #4 | |
| Rock Crawler Join Date: Mar 2005 Location: Dude on my dirt bike in SoCal!!!
| | #5 |
| Pebble Pounder Join Date: Jul 2006 Location: Out of my mind!!
| yeah, the stock tlts probably wont hold up. why dont you send them to me instead. Last edited by john alardin; 07-18-2006 at 09:50 PM. |
| | #6 |
| I'm a stupid C U N T! Join Date: Jun 2005 Location: In the Garage!
| sthil 26cc engine???? if so thats a huge engine for tlts id think something like xfactor or kyosho axles and a 1/6 body would be more to size |
| | #7 |
| ... Join Date: Sep 2005 Location: USA
| I got to see this. |
| | #8 |
| RCC Addict Join Date: Aug 2005 Location: VARCOR
| I think the .26 Stihl is actually wider than a TLT axle. |
| | #9 | |
| 06 Super National Champ ![]() Join Date: Jun 2004 Location: Tennessee
| | #10 |
| are you using a pnumatic system or co2 to pressureize the fluid??? |
| | #11 |
| Newbie Join Date: Nov 2005 Location: Somewhere
| Not as fun as homebuilt, but you might look into a Carson Attack, FG Marder, HPI Baja B5 or a Duratrax Firehammer. I owned a Marder Beetle for about 6 months last year and all I can say is that its a blast. The 23cc Zenoah that was in it would destroy a TLT axle the first time you floored the throttle. That Beetle weighed around 30lbs and it would smoke the tires from a standing start on the asphalt. Even if that Stihl was a little less powerful than the Zenoah, all you're going to have left at the end of the run is a pile of molten plastic and pot-metal shards. |
| | #12 | |
give us more details id like to see what you have planned | |
| | #13 |
| OOPS... I slipped, i meant txt axles, not tlt's.... Totally my bad. ANd for all the people out there it is a air over hydraulic system . And it actually works great in real life, cause it is the emergency back up on the submarines i work on. But, me and a buddy( hydraulic technician on the submarine) have started on the design to copy the navy's so we will post some pics when we get started. I dont know how its gonna work, but i have free realm to a 4 million dollar machine shop and all the materials i could want. So maybe it will actually work.... You never know... Thanks for the reply's , hope to update progress soon. |
| | #14 |
| is it going to work like this, a co2 cartrig will pressure a hydrolic fluid resivoir and then little valves will allow the fluid to be pressed into the cylinder? at least i think it will work. |
| | #15 |
| One more thing, just to let you guys know, i have the stihl .26 and its actually quite small.. a little bigger that .27 wasp with a large cooling head. The reason i am running gas is for tunability, not power. I plan on machining a set of reduction gears to limit the speed. i am designing a short shaft drive to a stampede tranny that will be mounted after the reduction gears so torque is my only demon i am worried about. I want the gas to idle and not foul, this is why i am using a chain saw engine. Again, thanks for the interest, i will keep this up as i go. |
| | #16 |
| just to clarify the wasp is .27 cu inches 4.5cc, sthil 26cc ??? like the same size as a weed eater motor?? |
| | #17 |
| RCC Addict Join Date: Aug 2005 Location: Naoma, WV
| I'm a little confused here. Are we talking about steering or suspension? If you're talking about suspension, saw someone mention ride-leveling, then I have a link that might interest you. It's 1:1 scale but I run it on my rig and works well. I use an air compressor but some have used CO2 in scuba sized tanks. This ia air over hydro by the way. http://www.pirate4x4.com/forum/showt...over+hydraulic |
| | #18 |
| i am talking closed loop for steering, not suspension. And yes i understand that the wasp is 4.5cc and the stihl is 26cc... If you step back and think about it.....that is only 20cc more... If you look at a hospital syringe, 20cc is very insignificant.... I know everyone is skeptical, but either way it will fit... thanks for the comments. |
| | #19 |
| Quarry Creeper Join Date: Mar 2006 Location: the great brown north=(WI)
| is it nitro or gas, in your first post it said .26cc do you mean .26ci |
| | #20 |
| Quarry Creeper Join Date: Sep 2005 Location: Minneapolis
| Does this sound about right? ![]() HS 75 Displacement1.55 cu. in. (25.4 cc)Engine Power1.2 bhp (0.9 kW)Weight11.4 lbs. (5.2 kg)Fuel Capacity.78 pts. (.37 l)Cutting Bar Length18" Standard24" optional One of the most powerful hedge trimmers on the market, the HS 75 features a 1.55 cu. in. high-torque engine to trim large hedges In record time. Features an easily activated gear box lock-out function, large baffled muffler and forward discharging exhaust. Maintenance is simple and less expensive due to fewer components. Weighs only 11. 4 lbs. |
| Thread Tools | |
| Display Modes | |
