| | #1 |
| Quarry Creeper Join Date: Mar 2006 Location: the great brown north=(WI)
| does anybody know how to properly set one of these style of suspension up properly. how would a panhard bar come into play. my current setup as very little travel but i don't car about that, even though it's only like 3/4". my main problem is the axle pinion angle moving. (leaning forward or back) can any one help and heres the rig |
| Sponsored Links | |
| | #2 |
| Dirt Addict ![]() Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
| Basically you have a swingarm type suspension and the pinion will pitch with travel. You'll need to go to a 3 or 4-link style to solve the pinion pitch. Jay |
| | #3 |
| I wanna be Dave Join Date: Jul 2005 Location: Cedar Rapids
| Exactly what roktoy said. It will help though if your links are as horizontal as possible at ride hight. |
| | #4 |
| Get off my lawn! ![]() Join Date: Feb 2005 Location: Cleveland, OH
| If the problem is the axle pivoting around on the links (which moves the pinion even if the axle is stationary) then you need to fix the links to the axle without using balls, or make a C-bracket to hold the axle to the link. It's awfully hard to see what's going on with those huge tires in the way. |
| | #5 |
| Rock Crawler Join Date: Jul 2006 Location: Olympia
| You can do a 2 link if the link splits and attaches above and below the axle center point(early bronco,fj60,06 superduty 1:1's would be worth looking at to get the idea) You would still need a panhard to control the side to side movement. Your panhard needs to have the same angle as your steering to keep the axle/steering from walking and binding at flex. |
| | #6 | |
| Quarry Creeper Join Date: Nov 2005 Location: Danville
One which is what ford motor co did on early broncos and f150s is use rubber bushings at the axle mounts and the frame mounts. This allows more flex because the rubber will flex/distort/give when the axle is twisting up. But where do you get flexy rubber bushings for a 1/10 rc car? I guess instead of using a rod end you could use some rubber tube or hose as your joint by running a bolt through it, just don't tighten it too much. The other method is to have a radius arm on one side and a single link on the other side. This is known as a wristed radius arm. This allows lots of flex becasue the two arms are not fighting each other like in the og system. Problem is though is causes some funky reactions from the suspension (lots of dipping/diving/jacking etc.) and I think It would make tourque twist a nightmare on a shafty. And yes you need to use a panhard bar with this setup to locate the axle latteraly. There are some other traits that go along with the radius arm design as far as susmension reation but seeing how people mount links on rc cars and that they work I feel that those characteristics aren't a big factor. | |
| | #7 |
| thanks for the help but i don't care much about flex. it's going to be a mudder hill climber. but thanks all. i think i got abetter understanding |
| Thread Tools | |
| Display Modes | |
