Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > General Scale Talk
Thread: My 1:24 semi scale comper!
Old 08-03-2006, 07:29 PM   #1
TLTCrawlin's Avatar
Default My 1:24 semi scale comper!
My ssmt:
I plan on mounting the shocks on the inside, but it was easy for mock up on the outside/xrc shock mounts. I need driveshafts, electronics minus motor, and I need to do alot of work tho, but its going to be worth it!
XRC chassis
XRC tires/ outside rim
SSMT axles
SSMT locked trans
SSMT shocks
New electronics soon!
TLTCrawlin is offline   Reply With Quote
Old 08-03-2006, 08:20 PM   #2
very original. trying to use all the stock parts?
S10XtremeSR is offline   Reply With Quote
Old 08-03-2006, 08:20 PM   #3
daaaaaaaaaaaaamn Spenser
what next?
trickedoutTLT06 is offline   Reply With Quote
Old 08-04-2006, 09:40 AM   #4
how do you mount driveshafts to that, i have one and they are belt driven sounds like alot of work, but itll be SWEET
scalecrawler is offline   Reply With Quote
Old 08-04-2006, 11:49 AM   #5
hes using SSMT axles, if im right i think hes just using the XRC frame.
Old 08-04-2006, 03:26 PM   #6
TLTCrawlin's Avatar
Exactly TON06!
Old 08-04-2006, 04:06 PM   #7
mmk my bad sorry should have thought about that!
Old 08-04-2006, 04:08 PM   #8
TLTCrawlin's Avatar
No problem!
Old 08-04-2006, 08:10 PM   #9
everyone makes mistakes
