Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > General Scale Talk
Thread: Bruiser Front and Rear Hub Bearing Question
Old 08-07-2006, 01:06 PM   #1
Default Bruiser Front and Rear Hub Bearing Question
Well I have finally broke down and purchased a Bruiser for Restoration. The other day I started working on the front and rear axels because the wheels were not spinning with out a lot of force. Once I broke them down I found out that the Bearings in the Hubs were frozen. So I began working on them to free them up but I still think that they may have friction on them.
Does anyone know what size bearings I can purchase to replace them and start with new again?
Thanks
Eviltwin_52s is offline   Reply With Quote
Old 08-07-2006, 02:34 PM   #2
Haters gonna Hate
1BadJeepBruiser's Avatar
A 608 size bearing (the size used in skateboarding) has a bore of 8mm, an outer diameter of 22mm, and a width of 7mm. Any decent skate board bearing will work just fine
Mike
