Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > General Scale Talk
Thread: scale frame material
Old 08-20-2006, 04:58 PM   #1
Default scale frame material
so i finally finished my stock tlt, woo hoo! now want to start a sorta scale / backyard basher /crawler. i have 2.2 moabs, and prob will use bronco body. dont know on the tranny yet. see what i can find. i have searched and read alot but am trying to decide on frame material. i like the 1/2 inch sq tube, cut, welded and ripped. what else is good, easy to do? would alum same size be good too? thanks....this is a great site!
azxj91 is offline   Reply With Quote
Old 08-20-2006, 06:47 PM   #2
most chassis people make are from 1/4" aluminum, go to lowes, you'll find stuff
swamp_rat is offline   Reply With Quote
Old 08-20-2006, 09:05 PM   #3
Another type of material you can find at lowes is 1/2x1/8 flat steel. If you can weld or braze it makes pretty convincing scale frame rails if you're going for a box type frame.
All Out Racing is offline   Reply With Quote
Old 08-21-2006, 11:59 AM   #4
i offer the frame rails alone for pretty cheap out of square tube. if you send me a drawing i can bend and cut the frame just how you want then you can do whatever you want to it to finish it up!
peej410 is offline   Reply With Quote
Old 08-21-2006, 06:05 PM   #5
Peej410,
i have seen your frames and some of the builds. They are awesome! Pretty much what i am hoping to do, although it prob wont be as clean as yours. but, i want to try to do it myself, for the fun and to keep it as budget as possible. got a bronco body from lhs, and will either use the 1/4 inch alum, or 1/2 " sq steel. and to all of you, thanks for the help.
Old 08-21-2006, 06:50 PM   #6
thanks for the kind words! pm me if you have any questions, with enough patience you can make a pretty clean frame i bet!
