Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > General Scale Talk
Thread: transfer case
Old 08-28-2006, 07:31 PM   #1
Question transfer case
I was planning on making a clod but i've been bitten by the bug and have decided to make a scaler. my question is, if seen some people on here run i tranny/transfer case combo on their trucks. how do i do this? i think it's really cool and it just makes it that much more like a real truck.
thanks in advance!
smalltowncrawler is offline   Reply With Quote
Old 08-28-2006, 07:39 PM   #2
i assume you just saw my build(i saw you looking at it) all you do is mak a short shaft to the t-case from the main tranny to the t-case. i f you are using a pede tranny as the t-case you'll have to shave the mounting portion off to make it look good
skidooguymxz550 is offline   Reply With Quote
Old 08-28-2006, 07:44 PM   #3
Here is one variation. Not exactly scale, but sort of, and it climbs like a billy goat. Reverse Cowgirl
todd1803 is offline   Reply With Quote
Old 08-28-2006, 07:46 PM   #4
~The Scale Shop~
STANG KILLA SS's Avatar
thanks in advance!
are you trying to say a clod cant be a scaler? :-(
Old 08-28-2006, 08:40 PM   #5
not at all, in fact when i saw your build a thought about doing the same thing with a 1/6 scale dodge my friend gave me, but price is a big issue. i was also planning on building a super
Old 08-28-2006, 08:45 PM   #6
thinkin about usein one of these with a 14-15 in wheel base body. (post #54)
/www.rccrawler.com/forum/showthread.php?t=35527&page=3&highlight=Diaz
any suggestions on how to mount on this frame?
Old 08-29-2006, 05:08 PM   #7
anybody? any sugestions welcome. mounting, which trannys are best for wich(tranny or transfer), driveshafts???????
Old 08-29-2006, 07:37 PM   #8
K_B
I've seen lots of builds where the main tranny is a pede and either another pede or something smaller like a losi for the t-case. But I've seen just about everything used for the t-case; clod axle, Nylint axle, custom fabricated. If it were me, I'd first try a GD-600 mounted in the front with the motor. Then run a pede shafts to a Losi or Stealth tranny. Space is always an issue and those trannies are smaller than a pede but just as strong for the most part. Then run maybe Jato shafts (they're beefier than pede shafts I think) off the Losi/Stealth to your axles!
Piece o' cake, right?
K_B is online now   Reply With Quote
Old 08-30-2006, 08:40 PM   #9
which would have less gear reduction- two pedes or a gd600 and a pede/losi/stealth?
skidooguymxz550- can u post a pic on here showing how you shaved the pede for the transfre case? it would be apreciated.
Old 08-30-2006, 08:50 PM   #10
K_B
I believe you can get a 3.5:1 reduction on a GD-600 but a full-on tranny such as a pede will most likely be stronger. The ratio of a pede is 2.72:1; no idea what the stealth or losi is...
Old 08-31-2006, 08:40 PM   #11
what kind of reduction does a emaxx tranny have? also, were can i buy a emaxx or pede tranny?
Old 09-01-2006, 09:20 PM   #12
any one out there?
Old 09-01-2006, 11:46 PM   #13
K_B
No idea what the gear ratio is on an emaxx tranny. Check the classifieds or check the vendors section. Multiple vendors offer pre-built pede trannies for around $45.
