| | #1 |
| Quarry Creeper Join Date: Nov 2005 Location: Valencia
| Hey all i started working on Daiz build up and when i got to the leaf springs and couldnt figure out how to mount the blocks to the axles and leaf springs to the blocks?? David told me he would sent a picture but he must of forgot...o well!! i also havent been about to get ahold of him so can some one please try to help out alittle!! Thanks |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Jun 2006 Location: Nor Cal
| You flip the axles upside down and mount the blocks to the holes that are in line and not sideways or you could drill holes from the bottom through to the top and do it tha way that wayyou could still mount the servo on hte axle. |
| | #3 |
| Quarry Creeper Join Date: Sep 2005 Location: Lethbridge
| | #4 | |
I noticed that if you drill it out and dont compress the 3 springs back together they tend to fail quickly. I made the hole on the bottom leaf block a little bigger and put a nut under it to it compresses the springs and now i run all 3 springs and they finally stopped bending into W's | |
| | #5 |
| I just put a small counter sunk hole in the middle of the diff surface to except the rivet |
| | #6 |
| I joined the Band! Join Date: Mar 2006 Location: Gardena,Ca.
| here's a couple of shots Last edited by ddiaz10240; 09-16-2006 at 03:02 PM. |
| | #7 |
| restack the leaf springs in reverse and they will help the keep the axle from torq twisting a bit, just grind down the rivet. i'm have a problem with my pdf maker, so i will try and get you a drawing of the axle mounting |
| Thread Tools | |
| Display Modes | |
