Go Back   RCCrawler.com Bulletin Board > Scale Rigs General Tech > General Scale Talk
Thread: Realistic Looking Shocks
Old 09-18-2006, 06:53 AM   #1
Default Realistic Looking Shocks
We expect to ship this shocks early or mid next month.
We are also working on a new super realistic looking 2.2 wheel, stay tuned for more updates...
-RC4WD
Old 09-18-2006, 07:21 AM   #2
Haters gonna Hate
1BadJeepBruiser's Avatar
looks interesting, how about some specs on it? length and diameter etc
-Mike
Old 09-18-2006, 07:52 AM   #3
The very first one will be 120mm long, 20mm diameter, 40mm travel.
Shorter and longer one will be made afterwards.
Old 09-18-2006, 08:32 AM   #4
I am interested.
FrankyRizzo is online now   Reply With Quote
Old 09-18-2006, 10:01 AM   #5
have pricing? im more then interested, and in the wheels, as ugly as they are white spoke steel wheels would make a great lookin crawler wheel!
Warn Off Road is offline   Reply With Quote
Old 09-18-2006, 10:36 AM   #6
Get off my lawn!
microgoat's Avatar
Question huh?
Say what? 20mm is 3/4 inch! You might want to mic that again.
microgoat is offline   Reply With Quote
Old 09-18-2006, 12:08 PM   #7
yes, it is 20mm. At first I was thinking more making them for clod size crawler truck. So it will look very beefy.
Tell me what you guys are looking for, I will see what I can do...
Old 09-18-2006, 12:18 PM   #8
I may be intersted for a TLT build I'm looking into. I'm assuming the are oil shocks?
xjman is offline   Reply With Quote
Old 09-18-2006, 12:33 PM   #9
~The Scale Shop~
STANG KILLA SS's Avatar
aluminum i assume?
will you be producing a plastic version as well? ie less cost?
STANG KILLA SS is offline   Reply With Quote
Old 09-18-2006, 01:31 PM   #10
white wagon wheels, my personal fav. they're not that ugly are they? http://memimage.cardomain.net/member...58_16_full.jpg
corncrawler is offline   Reply With Quote
Old 09-18-2006, 04:42 PM   #11
If a TLT sized shock was available, I would build a scaler just to use them. It's about time somebody did this!
BlueMonster is offline   Reply With Quote
Old 09-18-2006, 04:43 PM   #12
wow even for a clod that's big, id say no more O.D. than 1/2"
rockwerks is offline   Reply With Quote
Old 09-18-2006, 04:54 PM   #13
My shocks on my 1967 Honda CB140 are just a little bigger around then those.
RD400 is offline   Reply With Quote
Old 09-18-2006, 05:12 PM   #14
Web Wheeling
Etype R's Avatar
Way to big, even for a clod or jugg.... I would like to see 12mm shocks for the clods and juggs, and 8mm shocks for the tlt's.
Etype R is online now   Reply With Quote
Old 09-18-2006, 05:33 PM   #15
I don't like them. I don't run shocks like that in real life. They look like cheap factory shocks. FUGLY Why don't you make a real looking Coil-Over with Res or a Real looking Offroad shocks. Like these. These are want are ran in real life for a scale trail rig.
run2jeepn is online now   Reply With Quote
Old 09-18-2006, 05:46 PM   #16
Get off my lawn!
microgoat's Avatar
For real scale appearance, a longer Mini-T shock would be ideal. But those things leak worse than TLT shocks, and they're nowhere near strong enough; the shafts are only 2mm.
What about a longer version of the Sand Scorcher shocks? 8mm OD with a 3mm shaft, with rubber bushings at each end, or ball links.
Old 09-18-2006, 05:53 PM   #17
i personally think that his proposed size is the problem... that diameter is no good.
what about just turning down some tlt bodies and making a good seal and piston system for inside them????
4stAir is offline   Reply With Quote
Old 09-18-2006, 10:26 PM   #18
When I wrote 120mm long, 20mm diameter, 40mm travel. The 20mm is the overall diameter, not the shaft. This shocks doesn't have a shaft. It will be a unique shock, it uses a internal spring and has a 3 piece body.
STANG KILLA SS, no we dont plan to produce plastic version. The price will be around $15-20 a pair.
run2jeepn, once you see the production version, you wont think it is very cheap looking.
I would like to get something like those Edelbrook shocks done too, but it will be very expensive to make. We already got our own tool to make make springs now, so sooner or later we will have a shock like that done. Just probably not so fast.
microgoat or BlueMonster, can you guys give me the specs (Lengh, Overall Diameter, travel length) for a TLT-1 size shocks?
4stAir, our first shocks wont use a piston system. Next one will.
Here is my updated specs for our very first clod crawler shocks: 100mm Length, Shock Body Diameter 20mm, Shock Travel 35mm.
By the way what other stuff would you guys like to see being made, that is scale looking. It has to be aluminum, doing plastic in small quantity is not possible right now.
Old 09-18-2006, 10:32 PM   #19
other stuff.... i want some "scaler" axle housings.
i like the stuff you guys do, i think that new gear reduction is the ticket for my stealth comp rig.
i am sure the shocks will look good.
Old 09-18-2006, 10:32 PM   #20
How about some cheaper wheels?
