01-27-2015, 02:46 PM | #41 |
RCC Addict Join Date: Nov 2008 Location: Central, WA
| Re: Installing a "ToyZuki's fabrication Motor Mount" |
01-27-2015, 03:48 PM | #42 | |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
| Re: Installing a "ToyZuki's fabrication Motor Mount" Quote:
Pics of it didn't happen!! | |
01-27-2015, 03:52 PM | #43 |
01-27-2015, 03:54 PM | #44 |
| Re: Installing a "ToyZuki's fabrication Motor Mount" I was really wanting one for Hera but already had a similar product on hand... almost went with it anyway but I had a lot more parts to buy.
01-27-2015, 05:31 PM | #45 |
Rock Crawler Join Date: Jun 2013 Location: Knox, IN
Anxiously awaiting thise pics. I love the idea of motor forward. But can't give up the 4 link.
01-28-2015, 07:32 AM | #46 |
Sorry for the photos - some are washed a little...... I was told these new smart phones are the best cameras out there. My lowers are Blue monkey wraith lowers. So my axle is pushed slightly forward. Uppers are home made Ti with a slight bend at the chassis side. XR mod axle with RCBro tubes and DSW upper link mount, and his wraith servo mount. Full droop from the side Compressed from the side Clearance on the front driveshaft CRAP Photo but you can see my only problem child, if you want to call it that - Spur nut just touches the back of the servo 1/8 or so from the bottom of the shock travel. Now the servo mount is for the wraith to push the servo back - So if I change that, all is good in the world. I set it up like this bc of the body I was working with. But all in all, like everything RC... If you want it, It CAN be done. Every truck will be a little different, but with enough tinkering - You CAN DO IT!! |
01-28-2015, 07:42 AM | #47 |
Damn. Nice job! You need one of those stubby servos. Although unless your jumping it, both sides shouldn't compress at the same time.
01-28-2015, 08:02 AM | #48 |
Yeah, I can take more off the nut without worry or slide the servo forward, ect ect The set up is far from done on this rig. But it just proves anything can be done with some tinkering. Now I just need portals. |
01-31-2015, 12:38 AM | #49 |
I tried to pull the trigger for my order but he is sold out. I am on the waiting list.
01-31-2015, 01:07 AM | #50 |
Picked up another batch from the water jet shop today! I'll be in the garage on the mill all weekend! Should be set for orders tomorrow afternoon! Thank you for your patience!
02-06-2015, 04:02 PM | #51 |
Newbie Join Date: Dec 2014 Location: Behind a rock
Will this motor mount work with the SSD CMS/3 link setup?
02-06-2015, 04:13 PM | #52 |
I'm unfamiliar with it, I'll do some googling! The key factor is servo placement and upper link placement. If its directly on top of the diff it could come in contact with the spur gear like the blue monkey setup. Love the blue monkey plate so I made my own upper link mount. Pics are in the install thread. Location of the servo also. Level3 racing cms kit puts your servo where it runs into my spur. A customer PatM solved this issue by standing the servo up with stock servo mounts. Pics are also in the install thread! But I'll see what I can find on your kit and see if I see any issues. |
02-06-2015, 05:03 PM | #53 |
02-09-2015, 01:07 AM | #54 |
Rock Stacker Join Date: Aug 2009 Location: kaneohe
02-09-2015, 11:24 PM | #55 |
Mine came today... Installed... Vanquish panhard, CMS, and links ordered... |
02-10-2015, 09:27 AM | #56 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
Zuk's mount has to be the best performance upgrade released in a long time the benefit of having that heavy motor down low and still tucked safe is brilliant........
02-10-2015, 09:42 AM | #57 |
Well thank you! Makes me feel good that you guys like it! Can't wait to let the next cat out of the bag!
02-18-2015, 11:15 PM | #58 |
Here is my rig with CMS / Panhard installed. Working on getting the drive shaft finalized and cleaning up the electronics and wires. |
02-19-2015, 06:29 PM | #59 |
Ok TZ FMM owners, did you drill or grind flat spots?
02-19-2015, 06:37 PM | #60 |
| Re: Installing a "ToyZuki's fabrication Motor Mount" I'm curious too! After seeing the way Harley did his I'm going to be swapping all my rigs over to the thru pin style! There should be a disclaimer that build threads are part of the deal! I've sent these all over the world and hardly ever get any feedback! I guess no news is good news! |
Installing a "ToyZuki's fabrication Motor Mount" - Similar Threads | ||||
Krawler Koncepts Tips and Tricks for Installing "Inside" Skins | Krawler Konceptz | Vendors Paint and Body | 9 | 03-17-2012 02:49 PM |
Project "Purple Skunk" a Metal Fume Fabrication production. | akguanja | Losi Mini-Rock Crawler | 52 | 08-01-2009 09:10 PM |
Visionary Fabrication Chassis "Vendetta" | Usmc8541 | HPI Wheely King | 8 | 02-27-2008 11:37 PM |
Visionary Fabrication (Billet Works) 2.2 Aluminum "Assassin" Bead Lock Wheels Review | STANG KILLA SS | Tires and Wheels | 33 | 12-29-2007 08:42 AM |
