08-28-2014, 08:58 AM | #21 |
Rock Crawler Join Date: Feb 2011 Location: Williston
| Re: Aluminum body Bronco Build along~
It is "tooling foil" can be purchased from dick blick online. L.R. |
08-28-2014, 03:04 PM | #22 |
Rock Crawler Join Date: Jul 2008 Location: E. City
Wow those are turning out nice!
08-30-2014, 01:48 AM | #23 |
RCC Addict Join Date: Dec 2007 Location: London
| Re: Aluminum body Bronco Build along~ |
08-30-2014, 04:25 AM | #24 |
RCC Addict Join Date: Aug 2005 Location: New Oxford PA
08-30-2014, 08:29 AM | #25 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
Do one in cooper Neil |
08-30-2014, 06:53 PM | #26 |
Jeep whore Join Date: Aug 2008 Location: Florida
09-05-2014, 07:07 AM | #27 |
LR, Any updates? Looking forward to the end result. |
09-05-2014, 07:48 AM | #28 |
made my first batch of panels, this is the pinched and bobbed version- then decided it was time to cut the "extra" out of this proline body and make the scale version that it currently is NOT. you can see where I am cutting out an inch or so from the front of the rear corners and midway through the side of the top. Not pictured is the roof which also got cut. L.R. |
09-16-2014, 09:02 AM | #29 |
RCC Addict Join Date: Apr 2007 Location: Murfreesboro
SWEET!!! Glad I stumbled on this thread, keep it up! Matt |
09-16-2014, 10:46 AM | #30 |
Rock Stacker Join Date: May 2011 Location: Manchester, NH
Wow you guys are really upping the ante with these metal bodies! The craftsmanship is impressive.
09-17-2014, 08:19 AM | #31 |
Are you planning on showing how you bond the body panels and what sort of inner structure you will use to reinforce/mount the panels ?
09-19-2014, 01:42 PM | #32 |
I will try to do the exact same thing that MetalMasher does with his bodies. panels are glued up with goop/ shoe goo, clamped together and screwed into interior tabs that come off the roll cage. L.R. |
10-23-2014, 10:28 PM | #33 |
Rock Crawler Join Date: Oct 2009 Location: Wasilla, Alaska
Did you consider the copper or brass tooling foil they have? Then the panels could be soldered together |
Aluminum body Bronco Build along~ - Similar Threads | ||||
Wraith re-build with PL Bronco body | Hobine | Axial Wraith | 37 | 02-08-2013 03:44 PM |
~TSS~ Aluminum Grill for DC pinched Early Bronco Body! | STANG KILLA SS | Scale parts | 10 | 12-13-2011 03:31 PM |
