10-30-2014, 11:43 PM | #1 |
Rock Stacker Join Date: Dec 2011 Location: Apache Junction
| synthetic winch line on bulldog winch?
Hey everyone I have a question, I'm finally getting around to installing a winch on my wraith and wanted to go with synthetic winch line on my bulldog winch. Wanted to know the best way to go about doing this was cause I see that the spool has a set screw to hold metal winch cable in. Was thinking about taking out set screw and feeding through holes and knotting it up but I just wanna get some input, suggestions, advice any help would be greatly appreciated thanks for your time
10-31-2014, 01:17 AM | #2 |
| Re: synthetic winch line on bulldog winch?
why not just tie a loop in the end of the line and put the screw thru the eye of that loop ? If you stick the line into a threaded hole then turn in the screw... it could cut the line as the screw is threaded in. tho' it's not the end if ya tried. in the 1:1 winching world it's required to maintain a couple wraps on the spool when the line is fed out. My 1:1 winch also has only one wee screw retaining the line to the spool. If I spool my line out completely... my winch rope will likely become detached from the spool with minimal tension stressing the line. that spool securing screw is not what holds the line on the spool. It simply secures the end of the line to start the spooling process. The remaining coupla' wraps on the spool is what keeps the line from being pulled off the spool. Last edited by TacoCrawler; 10-31-2014 at 03:31 AM. |
10-31-2014, 01:21 AM | #3 |
Ok makes sense now I see what ur sayin I'm gonna go ahead and try that out thanks a bunch TacoCrawler!
10-31-2014, 05:09 AM | #4 |
Just put it in like the wire line was in. Warn winch is the same way and comes with the synthetic line. I've never had a problem.
synthetic winch line on bulldog winch? - Similar Threads | ||||
New Synthetic Winch Line options | Locked Up | Locked Up RC | 12 | 05-24-2016 11:22 PM |
Synthetic Winch Line | Harvo | 1:1 Full Size Vehicles | 2 | 06-23-2013 10:50 AM |
New Synthetic Winch Line Colors now available | Locked Up | Locked Up RC | 0 | 06-10-2012 09:36 PM |
synthetic winch line | Kranberry | Scale Accessories | 0 | 09-05-2009 10:32 PM |
