12-18-2014, 10:23 AM | #1 |
Pebble Pounder Join Date: Jul 2014 Location: Oregon coast
| SORRCA question
I'm working on a class 3 crawler and noticed there is no wheel base ruling, anyone know what the axle to axle min or max is for class3?
12-18-2014, 10:36 AM | #2 |
| Re: SORRCA question
There is no wb limit but the body must be as long as the wb: Class-3 “Modified” Details: • 146mm / 5.75" max tire size with a 2.2 max rim size (including spare). • A bumper is not required, but to be counted for points it must be mounted to the vehicle's chassis and wider than the chassis rails (chassis cross rails do not count as bumpers). • Gates will be a minimum of 13" wide. • Class 3 body minimum specs: Rock sliders, mirrors, etc. do not count in these measurements: The distance between the inside of the tires (of any axle) can be no greater than 1.25" more than the width of the body at the doors. *Example* (7" inside-of-tire to inside-of-tire = body must be 5.75" wide) The body must be at least 5" wide from the front to the rear of the doors. Tire height can be no more than 0.5" taller than cab height. Height is measured from the bottom of the skid to the top of the bodywork/tube not including a light bar. *Example*(5.5" tire = 5" tall from bottom of skid to top of cab/tube work) Body must be at least as long as the wheelbase of the vehicle. • Body modifications including, but not limited to, pinched front, dove-tailing and boat-siding are permitted as long as the final dimensions comply with the minimum size rules. |
SORRCA question - Similar Threads | ||||
Would your club like to be a SORRCA member? | finishline | Scale Comp Rules | 85 | 02-13-2019 05:29 PM |
SORRCA wants your input! | slobin3d | Scale Comp Rules | 6 | 04-04-2011 06:35 PM |
