12-25-2015, 04:03 PM | #1 |
Pebble Pounder Join Date: Dec 2013 Location: Arkansas
| Axial wraith axle problems, please help
Okay, so I acquired an ax10 scorpion about a year ago with wraith axles in it and I bought some steering links and they were too long so I thought, okay, this must just be a mistake in production. Then I realized it didn't even have wraith c hubs and knuckles, so I bought some. Steering links were still too long and the dog bones were too short. The stub axle I realized wasn't the right one, so I bought some universal axles for it and they're too long. Does this mean that maybe the previous owners shaved down the axle housing to put the other c hubs on it? I've run out of ideas to try, I've just about replaced everything except the axle housing. Should I try a new axle housing?
12-25-2015, 04:10 PM | #2 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
| Re: Axial wraith axle problems, please help
Post up some pics , it may help figure it out.
12-26-2015, 06:59 PM | #3 |
| Re: Axial wraith axle problems, please help |
12-26-2015, 07:37 PM | #4 |
This is a stock setup. Thats knuckle to knuckle , a little over 8''
12-26-2015, 07:40 PM | #5 |
12-26-2015, 07:45 PM | #6 |
12-26-2015, 07:47 PM | #7 |
Flip your knuckle , either left to right or 180
12-26-2015, 07:48 PM | #8 |
The longer mount of the knuckle should be on the bottom.
12-26-2015, 08:09 PM | #9 |
12-26-2015, 08:15 PM | #10 |
Look at the knuckle , the two mounting tabs are two different lengths , The longer one go's on the bottom.
12-26-2015, 08:25 PM | #11 |
Alright, I feel like the biggest doof in the world, it's the right length, however, that still doesn't explain why the tierods won't fit?
12-26-2015, 08:28 PM | #12 |
The tie rod is too long because you are using the double arm not the bolt on arm that goes on the other side of those knuckles.
12-26-2015, 08:34 PM | #13 |
Your using the wrong side of the knuckle
12-26-2015, 08:37 PM | #14 |
You need a set of Ackerman arms , They screw into the two hole on the other side of were they are now.
12-26-2015, 08:42 PM | #15 |
Oh, didn't know you were supposed to use that side.. I feel stupid, but thanks a bunch guys!
12-26-2015, 08:44 PM | #16 |
Its a learning curve. |
12-27-2015, 10:40 AM | #17 |
So you all good now ?
Axial wraith axle problems, please help - Similar Threads | ||||
axial wraith axle uk? | amatris1996 | Axial Wraith | 0 | 05-03-2015 05:39 PM |
Problems with a axial scx10 front axle? | axial 4x4 crawler | General Crawlers | 18 | 12-28-2014 11:49 AM |
Axial wraith problems | ShadS | Newbie General | 1 | 11-13-2014 06:39 PM |
New Axial Wraith from SPAIN - first pictures and first problems | oskitarr2004 | Axial Wraith | 4 | 01-14-2014 02:37 PM |
Problems with axle grinding/ vanquish knuckles, axial cvds?? | yjdavid | Axial AX-10 Scorpion | 2 | 12-08-2009 02:21 AM |
