01-21-2017, 03:16 AM | #41 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
| Re: RGT bronco |
01-23-2017, 02:26 PM | #42 |
| Re: RGT bronco
Really been thinking of a new body, really don't want to cut up the bronco to the way I would like need to practice my skills. Bodies I've looked in to is many Stampede 50's chevy, 66 f100 Rj speed 80's crawler pickup Tamiya blackfoot, midnight pumpkin The last two are hard bodies and feel little more comfortable since I've built countless static models kits and my own junkyard builds. The Blackfoot is really temping, I seen a pic of a Blackfoot cab and a flatbed that was really cool and made gears turn in my head. Just need to figure out the body once I get things mounted to see of performance is with new axles. |
01-30-2017, 07:35 AM | #43 |
| Re: RGT bronco
Well finally have some direction on this build just need to found a Blackfoot body at a decent price as that will be the base of the build from now on. In looking for some inspiration I can across a rig I really liked and it just happens to be owned by a fellow rcc member (low range) and so I contacted him to ask if it was OK to build a scale rig loosely based on his rig. Which he was flattered and gave the ok. I figured I would ask before I posted up pics just a respect thing. So here is where my little bronco is headed, |
01-30-2017, 04:27 PM | #44 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
| Re: RGT bronco
Wow... my intrest in this build just tripled! Thats a cool rig and i used to have a blackfoot back in the 90s, my first ever hobby grade rc! Man this just keeps getting better! |
01-30-2017, 04:57 PM | #45 |
| Re: RGT bronco |
01-30-2017, 10:19 PM | #46 |
| Re: RGT bronco
It's finding all the other bits that go with the body gets costly. Almost worth buy the new 2016 kit just for the body lol
01-31-2017, 05:11 AM | #47 |
I joined the Band! Join Date: Jul 2011 Location: Philippines
| Re: RGT bronco |
01-31-2017, 08:11 AM | #48 |
Quarry Creeper Join Date: Jul 2015 Location: Moncton
| Re: RGT bronco
I just ordered two of these, one for each of my daughters to learn to crawl with. I know they will get beat up a fair bit so I didn't want to spend much on them yet. I'm thinking some better tires and weighed wheels will be about the only mods i'll do to them unless there's something else that's pretty much free and easy. |
01-31-2017, 11:58 PM | #49 | |
| Re: RGT bronco Quote:
02-01-2017, 10:08 AM | #50 |
| Re: RGT bronco I've got a few Traxxas 2075 servo's kicking around, those are my go to servo usually for a standard build. Cheap and readily available here.
02-03-2017, 09:45 PM | #51 |
| Re: RGT bronco
Yup, cant decide between this rgt, barrage, or mst cfx for my first scaler. Might get this and pass it down to my 8 y/o son when i step up to a "true" 1/10 scaler. Hillbilly you should totally pull the trigger on the blackfoot kit, then sell the chassis as a roller. |
02-03-2017, 10:27 PM | #52 |
| Re: RGT bronco
I've been saving money from parts I've sold. Plus I need to find a midnight pumpkin body too for a mix and match. Blackfoot cab w/ midnight pumpkin bed. Which might save a little money in the long run.
02-04-2017, 03:35 AM | #53 |
| Re: RGT bronco
Well I redid the links in the rear now it moves free and drives haft don't bind but also moved the axle back about 1/2" to an 1". Fixed the pinion angle too not so steep And changed the link mount from the stock everest 10 to an scx10 level3 link mount. Also finished building the rear axle. With scx10 lockouts, one piece axles, a spool and underdrive gears. The 4 link consist of 4 stock lower links, 2 stock rod ends, 4 revo rod ends, and 2 aluminum unknown rod ends at least for now just mockup on the cheap since it's what I have around. Kinda pushed back but will adjust when I get my new body Last edited by hillbillyrc; 02-04-2017 at 03:42 AM. |
02-06-2017, 10:06 AM | #54 |
| Re: RGT bronco
Thought I would show before and after of my axialed everest rear axle BEFORE AFTER Not much left of the everest axle. The case, some hardware and a few bearings. Axial based parts are HD Ud gears, hot racing spool, strc lockouts and stainless steel axles, and a couple lockedup rc scx10 bearings. Still need to lube the gears after I shim it a little more. Last edited by hillbillyrc; 02-09-2017 at 01:34 PM. |
02-09-2017, 07:04 AM | #55 |
| Re: RGT bronco |
02-09-2017, 10:24 AM | #56 |
| Re: RGT bronco
One thing you'll notice is the front bumper is to close and will need to moved out a hole for full turn lock when flexed.
02-10-2017, 04:02 PM | #57 | |
The original RDT axles have nice small pumpkin, could outboard the rear shocks. Fronts could outboard too, attach them on top of axle tubes so tires don't rub during steering. | |
02-11-2017, 03:19 PM | #58 |
| Re: RGT bronco
They are rgt rock cruisers just with fj40 body. I could have got the same one, but not much of a Toyota fan personally.
02-12-2017, 06:15 PM | #59 |
| Re: RGT bronco
Finished with axle swap on my rgt. The rear stock links for uppers and lower with different rod ends stretched the wheel base in the rear. Fronts are random links I bought from another member here. Right now my wheelbase is 10.75" Need to make a better drag link but just used what I had for the moment. Which is a stock upper part of the y-link. Thoughts so far need new shock, ones I used are far to stiff. Need to shorten the front driveshaft male side cause still bottoms out before full compression. Need the new body so I can settle on a final wheelbase. Then I can work on a forward motor mount after I get a scx10 trans. Debating on a transfer case or using stock trans (if I can find metal gears for it) for a transfer case. |
02-14-2017, 02:44 PM | #60 |
| Re: RGT bronco
I've had jury duty for most of last week and finished up early today, which left me sometime to work on my rgt. First off was to address the stiff shocks well the rear isn't as bad of the fronts. So when I had the slick rock shocks I also bought mini t Springs which worked to bring to life the front end. I used the soft pink spring still need more testing/driving to make sure the aren't to soft. Also trimmed down a male side driveshaft to it had that fit the stock one. Since I don't have my new body and for testing I comp cut the rear to match the new wheelbase. I got one actual testing shot after driving a bit before the rear driveline dropped out. Rest of these are just poser shots |
