02-18-2017, 11:39 AM | #61 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
| Re: RGT bronco
How hard would it be to put leafs under this thing? Just to get around the shock clearance issue. Probably cheaper to just get a tf2 chassis but... no challenge lol Love these budget 1:12 rigs. |
02-18-2017, 03:06 PM | #62 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
| Re: RGT bronco
Not sure but will find out I plan on leaf springing the rear to match my inspiration rig
02-18-2017, 05:05 PM | #63 | |
Rock Crawler Join Date: Nov 2009 Location: OKC, ok
| Re: RGT bronco Quote:
Sent from my SAMSUNG-SM-G891A using Tapatalk | |
02-18-2017, 09:06 PM | #64 |
Newbie Join Date: Feb 2017 Location: US
| Re: RGT bronco
When using leaf spring how is articulation? I've not researched much in leaf springs but think that would look amazing for scale truck. Sent from my SM-S920L using Tapatalk |
02-18-2017, 09:33 PM | #65 |
| Re: RGT bronco Leafs will definitely reduce rear articulation but if your after scale looks and crawling then its all good.
02-19-2017, 11:15 AM | #66 |
| Re: RGT bronco
There are some tricks such as the Chino mod to get leafs to flex.
03-04-2017, 03:23 AM | #67 |
| Re: RGT bronco |
03-04-2017, 04:08 AM | #68 | |
Rock Crawler Join Date: Feb 2015 Location: Melbourne
Sent from my SM-G930F using Tapatalk | |
03-04-2017, 06:09 AM | #69 | |
| Re: RGT bronco Quote: Hey have you had any flex out of the mounting post for your servo yet? Mine flex like crazy. Sent from my SAMSUNG-SM-G891A using Tapatalk | |
03-04-2017, 11:03 AM | #70 | |
I'm looking in to a cms which would fix the flex you talk about. This is one I was looking at since with a little work scx10 bumper mounts work http://m.ebay.com/itm/Vanquish-Axial...854?nav=SEARCH Last edited by hillbillyrc; 03-04-2017 at 11:06 AM. | |
03-04-2017, 11:11 AM | #71 |
| Re: RGT bronco That has been posted everywhere, there is another clone based in the UK also. The base of all the rigs mentioned are the same they start to differ when it comes to body, electronics, and wheels and tires. Also the same mods everyone is doing works for all the rigs.
03-07-2017, 03:16 PM | #72 |
| Re: RGT bronco
Well big things are coming ... Look for a new build thread in 1.9 section soon! |
08-10-2017, 06:52 PM | #73 |
Newbie Join Date: Jul 2017 Location: Sampson Co.
| Re: RGT bronco
Just got my RGT crawler. Toyota rock cruiser body. Been having loads of fun with it. Just today was playing around with it, and found that the rear left wheel had on grip. The other three wheels clawing for traction on the firewood pile it was climbing over. Just that one wheel with no power.
08-10-2017, 08:08 PM | #74 |
Quarry Creeper Join Date: Oct 2012 Location: Oregon
| Re: RGT bronco
Couple possibilities, the pin in the wheel hex broke/fell out/hex stripped in wheel or the locker in the diff stripped. Should be easy to see which it is, hold the two rear wheels and turn them in opposite directions. If the wheel nut spins around in the center of the wheel it is the hex, hex pin, or stripped wheel, if the wheel and nut still turn together then the axle is slipping in the locker. |
08-28-2017, 08:06 PM | #75 |
Newbie Join Date: Aug 2017 Location: Norfolk
| Re: RGT bronco
Has anybody got any ideas on how to gain more shock travel in the front without having the chassis bottom out on top of the servo? I noticed after wanting to attempt the barrage mod of flipping the chassis braces that I can't do that with the RGT, as the shock towers and chassis braces are all one piece for front and rear. Short of buying actual ECX ST's and CB's, I've got no idea what to do. I already flipped trays, but I haven't re-secured my rx or esc yet, so, it's not entirely set in stone. Whatever you guys got goin on, let me know!
