05-17-2017, 09:05 AM | #1 |
Newbie Join Date: Feb 2016 Location: Canada
| Attaching Scale Accessories
what is the best and what is best used to secure scale accessories in place for the trail? Such as: Bungies or glue? TSH Camping Bundle, Coolers, Axe, Lantern etc. |
05-17-2017, 09:11 AM | #2 |
| Re: Attaching Scale Accessories
I see a lot of nets used Hang up and Drive |
05-17-2017, 11:02 AM | #3 |
E6000 is good too.
05-17-2017, 12:57 PM | #4 |
Moved to Scaler... cough. Huge blobs of hot glue mixed with CA tire glue then velcro straps and then screwed down with drywall screws works for me. Last edited by EeePee; 05-17-2017 at 12:59 PM. |
05-17-2017, 01:08 PM | #5 |
I use E6000 glue, as it stays flexible. 3M double sided tape. Zipties. Velcro. |
05-17-2017, 08:09 PM | #6 |
Newbie Join Date: Apr 2017 Location: US
My tamiya cc01 Fjc, as far as scale accessories: Glass cloth rolled to simulate a towel or sleeping bag ( came with my tacoma when I bought it) Shovel, Rake, and Stomped ($2.99 @ Micheals) Gas can and toe shackles ($15.00 wish.com) Roof Rack w/ working lights ($20.00 wish.com) Steel boards ($0.57 each home depot) Zippo Case (not shown) used as tool box. Mini blue tooth speaker ($20.00 best buy) black box at the top strapped down with gopro straps. My way of thinking outside the box, budgeting. Sent from my SM-G935V using Tapatalk |
05-17-2017, 10:18 PM | #7 |
Quarry Creeper Join Date: Nov 2013 Location: alberta
Small rare earth magnets work well for me easy to remove an item or rearrange if so needed
05-17-2017, 10:32 PM | #8 |
Rock Crawler Join Date: Apr 2014 Location: Portland
Or.. Just mount it like you would on your 1:1.
05-18-2017, 01:23 PM | #9 |
Pebble Pounder Join Date: Mar 2015 Location: PEI Canada
I use Velcro, and for the roll cage I use Zipties.
05-18-2017, 02:38 PM | #10 |
IMO it all depends on what surface material they're being mounted to... and whether they will remain static or be removable - re-positioned on occasion. I think using hot glue is good for most temporary and light weight accessories. E6000 if it needs be a stronger bond to plastic surfaces. For re-positioning or quick removal... I use tiny magnets and a steel (thin) plate for the hold/re-positioning. ie: my dog utilizes magnets in its paw(s) and a thin steel plate in the bed to allow for position changes or removal. The fuel cans were hot glued temporarily in the hauler's bed... but have since been removed and were relocated to inside the trailer. And I utilize home made bungee cords to hold down my quad to the trailer. Hot glue works for temporarily securing other static accessories inside the trailer's bed, underneath the quad... I've yet to have the quad's bungee mounting fail, even during a flop - roll. Bottom line... utilize any of the several methods that can get it done. A single type of mounting method generally will not suffice for every accessory mounted. But the hot glue use is quickest and easiest for a short term hold. E6000 holds stronger but takes longer to dry. The hot glue seems easiest to remove from contact points. And will absorb less if dealing with absorbent cloth mountings. Velcro works okay.... but excessive ambient temps tend to find the Velcro's adhesive backing can fail on occasion (too hot or too cold). So be sure the surface it is attached to is cleaned and oils are removed. An alcohol wipe cleans/removes surface oils fairly well. I'd suggest trying hot glue first... if that fails... try another method. |
05-20-2017, 10:42 PM | #11 |
Quarry Creeper Join Date: Mar 2009 Location: western ny
Good old fashioned Shoe Goo
05-21-2017, 12:35 AM | #12 |
^ 1972 is now considered old fashion ?
Attaching Scale Accessories - Similar Threads | ||||
Attaching Scale Accessories | j.krug | Paint and Body | 4 | 09-08-2016 10:37 AM |
Attaching Body to Look more Scale | sharkattack99 | 1.9 Scale Rigs | 10 | 07-12-2016 05:14 PM |
Attaching a scale body? | Knox_Crawler | Micro Scale Rigs | 6 | 02-03-2011 12:24 PM |
Attaching scale Accessories | neo | Scale Accessories | 10 | 04-07-2010 06:02 AM |
Attaching the plastic scale hub | neo | Axial SCX-10 | 6 | 04-05-2010 09:10 PM |
