06-22-2017, 08:47 PM | #1 |
Pebble Pounder Join Date: Dec 2013 Location: Arkansas
| Shocks are overrated
I'm currently building a tube chassis and I've got some questions about shocks, im about to give up and say no shocks, hence the name of the thread First of, what kind of shock should i run??? I've got trailing arms in the back, so i kinda like the idea of running yeti sized shocks on it on the back, but thats way to king of a shock for the front.. want to keep it around 100-110mm on the front, any input? I've heard a lot of good things about the traxxas big bores, what do y'all think of them? Also, is a single shear shock tab okay to run? Id rather have double shear but seems like some shocks have different size ball on the top? Thanks y'all! P.s. sorry about the long post |
06-22-2017, 10:13 PM | #2 |
Rock Crawler Join Date: Jul 2013 Location: california
| Re: Shocks are overrated
Don't give up on shock, trust me running no shock at all is a very bad idea. Is the rig for more speed runs and or crawling? Traxxas big bores with some spring tuning are a good all around shocks. The rc4wd king coil overs look really cool and they seemed to work well (I have never run them but, a friend had them and he liked them). Both of them are made in the sizes you listed.
06-23-2017, 08:10 AM | #3 |
RCC Addict Join Date: Dec 2014 Location: So Cal
This thread made me chuckle, I feel your pain and irritation. A buddy and I threaten to buy cnc machines to build shocks at custom lenghts! Look at Assiciated SC10 rear shocks to put on the front, length should be good and they aren't that "fat" for clearance sake. Emulsion shocks. Yeti rears are good, 5" long with an 1-5/8" stroke if I recall, not "fat" either. HPI Savage shocks are 6" with a 2" stroke, for what that's worth. Something I consider at this point: How much wheel travel am I trying to achieve, which leads to where on the arms (leverage now needs to be considered for spring rate availabity) will the shocks mount and on the chassis, which now dictates shock length and stroke. Finally, with all that info, at full compression, the shock should be 90 degrees to the arm to be truly progressive. You can single shear the shock tabs, provided they are made thick enough to carry the load, 16 ga would be as light as you'll probably want to go, on a crawler. Basher or U4, I wouldn't do it unless its easy to cut them out and weld new ones in should they bend. Where are the build pics for this thing? |
06-23-2017, 09:55 PM | #4 | |
| Re: Shocks are overrated Quote:
Anyways, this is where I'm at right now with it, not totally sure on the spare yet or not | |
06-24-2017, 12:18 PM | #5 |
G Mades, I personally haven't run them. I like the looks and the concept of adjustment, but have read you really have to work on them so they don't leak oil. As for different shocks, color is the concern? They all work off the same design platform. Not like you could do shim stacks and valving inside these little shocks. Score Yeti shock bodies are silver, Associated are silver. You can de-anodized colors you don't like. What matters is shock length and stroke in the end. Rc4wd Kings look the part and come in different lengths, just may be a little fragile if you're going fast all the time. Powerstrokes come in a variety of sizes as well. How much $$$ do you want to throw at shocks when the cheap ones work as well or nearly as well as the expensive ones if you know how to tune them. Full circle now, yes, shocks are over rated!
06-25-2017, 09:21 AM | #6 |
Pebble Pounder Join Date: Jan 2016 Location: Port Huron
I'm running gmade rsd shocks. I packed the orings full of green slime and they aren't leaking. I like them. I've also used the eBay knockoff king shocks. The cheap blue ones and they are super smooth and don't leak. Sent from my iPhone using Tapatalk |
06-25-2017, 05:38 PM | #7 |
What about the boom racing piggy backs? Any feedback on them?
Shocks are overrated - Similar Threads | ||||
Flex is overrated | MaFoDes | Chit Chat | 21 | 08-26-2015 04:12 PM |
Are My Batteries' Capacities Overrated?? | Tommy R | Electronics | 10 | 03-21-2011 01:11 PM |
Ohio State...........overrated!!!! | DISTURBIN' tha PEACE | Chit Chat | 10 | 01-08-2007 09:26 PM |
