09-19-2017, 07:32 AM | #1 |
Rock Crawler Join Date: Jun 2017 Location: Land of burning couches
| Transmissions?
Getting ready to embark on my first true scale type build. Utilizing a 66 Ford Truggy with an all tube chassis. Its a heavy pig already with nothing mounted up. It will utilize a wraith skid. I'm tossing around the idea of using a centered rear housing designed for Yeti and trying to run inline motor and transmission setup to fight torque lean, as I'll be utilizing a roc412. I have ZERO knowledge in this area is my real issue, like none. Don't have any idea where to begin looking. Any help would be appreciated. I THINK I'm on the right track for fighting the lean, but I could be totally off base too, so set me straight if I'm wrong. Thank you in advance. |
09-19-2017, 07:34 AM | #2 |
Quarry Creeper Join Date: Dec 2015 Location: Centerton
| Re: Transmissions?
If you want true to scale I'd go with the SSD RC Scale Transmission. I used it for the first time and that's all I'm ever going to use now. It's a great tranny! Sent from my iPhone using Tapatalk |
09-19-2017, 12:32 PM | #3 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
| Re: Transmissions?
i think you mean GCM? SSD doesn't have any scale trans on their site. GCM Webstore Canada International - Drivetrain Parts |
09-19-2017, 12:57 PM | #4 | ||
| Re: Transmissions? Quote:
A centered axle will have little to no effect on torque twist so don't expect significant results. What will help is underdrive gears and a sway bar. Proper suspension geometry can replace a sway bar but you would have to figure out what works best with a custom chassis. Quote:
Scale Transmission Kit for SCX10 | ||
09-19-2017, 01:41 PM | #5 | |
09-19-2017, 01:58 PM | #6 | |
As far as the transmission, Dlux make a really cool one that has built in overdrive for the front and makes the driveshafts spin in opposite directions. The counter-rotating shafts do a great job in canceling out torque twist and using wraith axles makes it easy to flip the rear gears around so everything moves in the proper direction. Dlux Fab | |
09-19-2017, 02:50 PM | #7 | |
09-19-2017, 03:03 PM | #8 |
| Re: Transmissions?
oh wow that Dlux setup is slick! not as scale as that awesome SSD setup i had no idea about... but still slick!
09-19-2017, 05:36 PM | #9 |
| Re: Transmissions?
SSD has a scale ta mission for the scx10 version one on their site Sent from my iPhone using Tapatalk |
Transmissions? - Similar Threads | ||||
Planetary transmissions | Mr Willys | Newbie General | 12 | 07-15-2016 12:00 PM |
transmissions | some_guy | General Crawlers | 8 | 01-13-2008 07:36 PM |
Transmissions | aussie_N_B | Newbie General | 2 | 09-18-2006 05:56 AM |
Transmissions, Transmissions! Pros, Cons, All different typ | kevinlongisland | General Crawlers | 5 | 06-21-2004 05:49 PM |
