11-25-2017, 07:10 PM | #1 |
Oppan Gangnam Style Join Date: Jun 2005 Location: Shingle Springs
| SCX10 ii + TRX-4 =
Something different and way cool. Well its kinda the same but not really. I posted them here because I don't have anything planned to put them under yet. Some of you might remember that I have "portalized" several different axles over the years using the 3racing portals for the original AX10 (before the SCX10). I put them on a few sets of Losi MRC axles, several sets of RC4WD yota axles and even a CC01. They could hold up to some moderate power and were good enough for brushed on 3s. Fast forward to now.... When MST came out with the CFX-W and Traxxas announces the TRX-4, I thought "finally someone has a kit with portals". However, there are a few things I don't really care for in each kit so I thought about another conversion of sorts. After asking friends with these rigs a lot of questions, I decided to start buying some parts. Several hundred dollars later I had all the parts I needed to start. Measuring and eyeballing for several hours allowed me to formulate a game plan which seemed pretty easy as things almost fit or did fit together but were kinda flimsy. After some time on the lathe, I came up with some adapters and done! Now to figure out what to put these under.... You will see these in the 1.9 section some time in the near future. |
11-25-2017, 07:13 PM | #2 |
| Re: SCX10 ii + TRX-4 =
I approve of this. When do I get my set? |
11-25-2017, 09:58 PM | #3 |
Very cool!! Been talking with someone, just recently as this afternoon about an scxii/trx mash up but a little different pumpkin placement.
11-25-2017, 10:09 PM | #4 |
I wanna be Dave Join Date: Jul 2010 Location: Toronto
You're the king.
11-25-2017, 11:02 PM | #5 | |
| Re: SCX10 ii + TRX-4 = Thanks! Send money to my off shore account and I will send you a set. Thank you! Quote:
Thanks but maybe more like the royal blacksmith? | |
11-26-2017, 01:06 AM | #6 |
Quarry Creeper Join Date: Oct 2008 Location: Finland
Ingenuity! Wont the high pinion force you to build a tall truck? Flipping the centre part and making low pinion axles would give more clearance to allow the heavy parts like motor and transmission to be located lower on the chassis. |
11-26-2017, 07:45 AM | #7 |
Dean think the trx4 could be fitted to yota axles?
11-26-2017, 10:14 AM | #8 | |
| Re: SCX10 ii + TRX-4 = Quote:
Of course, anything is possible. Pretty much the same basic operation to put portals on any axle. Keep in mind that the inner shafts may need modifying for width. I'm running two long side shafts for ease of assembly and since the shafts have a smaller dia. between the CV end and the locker end, that may be an issue if you just grind and shorten the locker end. | |
11-26-2017, 11:01 AM | #9 |
I wanna be Dave Join Date: Jan 2004 Location: Austin Texas
Killer- solving the worls problems one axle at a time! That extra gearing means even less torque twist annnnddd more clearance.
01-02-2018, 04:46 PM | #10 |
Rock Crawler Join Date: Jan 2011 Location: Blaine, MN
and then? These look awesome!
01-04-2018, 02:33 PM | #11 |
Wow, do want! |
01-09-2018, 06:53 PM | #12 |
I wanna be Dave Join Date: Nov 2009 Location: Chico now
You are the Master!
01-10-2018, 12:02 AM | #13 |
Rock Stacker Join Date: Oct 2016 Location: Petaluma
Great ingenuity. Can you say what aspects of the TRX axle you are not fond of?
01-11-2018, 08:45 AM | #14 | |
| Re: SCX10 ii + TRX-4 = Thanks! I might make a few sets of adapters if time permits. Thanks Travis Quote:
I don't have a need for the selectable locker but it's definitely a cool feature I like to have different things I can't leave anything alone (This is a silly reason but...) I can't run Traxxas axles at Axialfest but want portals. | |
01-11-2018, 10:30 AM | #15 |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
Very nice Dean, these are what inspired me to set off on my endeavor! How do the portals change your final drive ratios compared to the stock ratio? Ernie |
01-11-2018, 12:22 PM | #16 |
I wanna be Dave Join Date: Feb 2009 Location: Cowtown, USA
So awesome, thanks for sharing! |
01-11-2018, 07:33 PM | #17 | |
01-11-2018, 08:15 PM | #18 | |
Thank you! [QUOTE=Lavigna;5786811]I totally understand the desire to alter and create into my own. Stock is never an option it seems. Again, great job![/QUOYou! Thanks! | |
01-15-2018, 11:23 AM | #19 |
Pebble Pounder Join Date: Sep 2006 Location: keller
I'd like a set of adapters if you make Some? This was one of my first thoughts when the trx-4 came out. I didn't want to buy a whole truck for just the portals. Lol great work! Sent from my SM-G955U using Tapatalk |
01-16-2018, 07:20 AM | #20 |
Moderator Join Date: Aug 2017 Location: Readsboro, VT
It's an SCX 10-4!
SCX10 ii + TRX-4 = - Similar Threads | ||||
Scx10 2 or Traxxas Trx-4? | jksquires43 | General Scale Talk | 12 | 08-27-2017 08:59 PM |
Axial SCX10-II vs RR10 Bomber vs Traxxas TRX-4 vs Vaterra Ascender | MasteroFlego | Newbie General | 39 | 08-05-2017 08:08 AM |
