11-29-2017, 03:07 PM | #1 |
RCC Addict Join Date: Feb 2017 Location: Surprise
| Skidplate |
11-29-2017, 04:00 PM | #2 |
Pebble Pounder Join Date: Nov 2016 Location: USA
| Skidplate
I have the scx10.2 one. Have yet to install it. I’m a bit hesitant due to the fact in how much it raises the transmission. In addition, I would have to cut out more material from the back panel of my hilux. Also, i would figure you would want the weight of the tranny down lower rather than higher. Just not sure the benefits of a small bit of clearance you’d gain is worth it. Still on the fence at this point.
11-29-2017, 05:11 PM | #3 |
| Re: Skidplate
Not sure about an scx2, but if you install this skid on an scx without adding a way to raise/relocate the frame side of the upper links wouldn't you end up with literally 0 vertical seperation of the links at the frame side? Usually that's not the hot setup and makes for an unstable truck while adding a ton of stress to the links/rod ends. Maybe useful with link relocation brackets, or aftermarket chassis? Looks similar to what is recommended for the GMRC Drag Queen chassis, which works very well. |
Skidplate - Similar Threads | ||||
Aftermarket Skidplate? | blackcruzer | Axial Wraith | 7 | 09-19-2013 08:18 PM |
Different Skidplate Use | WipeOut | Tamiya Clod Buster | 5 | 11-20-2007 03:25 PM |
Pinion Skidplate | RallyRoach | Tamiya TLT Crawlers | 3 | 08-25-2005 05:23 PM |
