08-19-2019, 12:03 PM | #1 |
Quarry Creeper Join Date: Jun 2007 Location: Los Angeles
| Light scale rigs suspension and foam set ups.
I need some input to set up a very light truck right. The truck has a very short wheelbase (10.5), I really like the challenge of trying to make this thing works. I can't complain too much about it, for its size the performance are pretty amazing, especially in very technical spots, climbing is a bit of an issue but I'm sure it could be improved with the right suspension set up and foam Here are the specs - Chassis: SCX10.2, mostly stock besides aluminum shorter links, a G10 SWB chassis, brass knuckles, I tried to keep as many parts plastic... - Weight: I would say it's 4 Lb max - Tires: Pitbull Rock Beast with Pitbull foams on Incision plastic wheels - Electronics: 2200 3S battery with SW4 and Revolver V2 Snubnose - Suspensions: Dravtech shocks with Losi Mini T springs (black front and pink rear), AE 15WT oil all around, rear VP Antirocks (they do help a bit tame the rear end while climbing). When it sits, there's maybe 80% droop front and 50% rear, shocks are same length and use the same mounting positions front and rear Build thread: Hardcore Sami Again, I'm really happy with its performances, i was not expecting to follow comp or even C3 rigs with this thing. I feel that the rear suspensions are pretty stiff, also sits maybe too high. As for the foams, C.I. makes a few for this particular tire but they all seem too hard for the light weight application. Thanks in advance for your input. Gilles Last edited by utieh; 08-19-2019 at 12:07 PM. |
08-19-2019, 03:29 PM | #2 |
| Re: Light scale rigs suspension and foam set ups.
You can cut some of the foam out to make it softer. Sent from my SM-N950U using Tapatalk |
08-20-2019, 02:32 PM | #3 |
My barrage works really well on stock memory foam in the Axial ripsaws. Springs are a bit soft, but Axial scx springs fit, but a bit loose
08-21-2019, 02:54 PM | #4 | |
My suspension set up is pretty close to this, I just ordered some Hyrax with the same foams, I believe (https://www.amainhobbies.com/crawler...r-2034/p638324) Looks like you're shaving half of the foams' outer diameter. Quote:
Light scale rigs suspension and foam set ups. - Similar Threads | ||||
Need some help - coil spring suspension set-ups | ecoli | General Scale Talk | 10 | 12-04-2011 08:23 AM |
SWX suspension set ups show how your mounted | Fordx4Ranger | Axial AX-10 Scorpion | 12 | 11-02-2009 12:43 PM |
Pics of your Creeper's suspension set ups | smashmetal | Venom Creeper | 43 | 05-06-2009 10:13 PM |
Suspension set-ups | Rhino 10 | Newbie General | 10 | 08-28-2007 08:08 PM |
