09-11-2020, 05:38 PM | #1 |
Newbie Join Date: Feb 2020 Location: usa
| dumb questions
I have a MN90 that I've modded: https://youtu.be/MmFheiEfTpE Tires: Looking around for upgrade tires that aren't the usual banggood stuff but maybe I don't know where to look? I know I can fit WPL tread on here but specs seem rather limited. Using the MN rims restricts me to the stepped diameter thing -small on the outside, and larger on the inside. I might be able to get some rims 3d printed and fit "normal tires" but hopefully there is something off the shelf. Options? Controllers: I don't know much about them I'm afraid, but I know that I don't like having a dozen of them around in a box with one dedicated to each truck. I know with the Flysky I can maybe bind like 10 vehicles to the controller. Does this mean that I need a specific Flysky or other brand receiver for each?. I think so but I'm not sure. First post, cool forum. Thanks for reading! Last edited by independent thinker; 09-11-2020 at 05:43 PM. |
09-12-2020, 04:46 AM | #2 | |
RCC Addict Join Date: Nov 2017 Location: 3rd rock pile on the right
| Re: dumb questions Quote:
Ive got the flysky gt5 n love it. It can bind up to 20 rx. It uses the fs-bs6 rx, which has a gyro (can be turned off). But the ones ive found are bout $20 each. But, i did some searchin n u can use the fs-ia4 n ia6 rx with the gt5 tx n theyre between $12-$18 each. Flysky aslo has the gt3 thats pretty popular. I think alot of people do a upgrade to get more than 3ch on it though. Spektrum n futaba are high end radios. As for the tire question, im not so sure. Wat size are your wheels? 2.2/3.0 ir smaller than that? Proline makes a 2.2/3.0 tire for the slash i believe. Hope that helps, even in the slightest lol | |
09-14-2020, 01:21 PM | #3 |
| Re: dumb questions
cool, thx for the feedback. i think i've got the radio questions under control re: tires, the inside diameter where the rim mounts are two different sizes. OD is 78mm, width is 32mm. 28.5mm for the outer rim diameter, and 40mm for the inner. what the heck size tire would this be? Last edited by independent thinker; 09-14-2020 at 01:25 PM. |
09-14-2020, 04:52 PM | #4 | |
09-14-2020, 05:17 PM | #5 | |
Here's what an 1/12 (1/14 really,) MN D90 comes with: OD. = 78 mm/3.07" WIDTH. = 32 mm/1.259" INNER BEAD DIA. = 40 mm/1.574" OUTER BEAD DIA. = 28.5mm/1.122" Not seeing how a 2.2/3.0 would work. Your typical 2.2 has an OD of over 5" and the Slash is a 1/10 scale truck | |
09-15-2020, 01:57 AM | #6 |
Rock Crawler Join Date: Mar 2019 Location: Terrassa
| Re: dumb questions
1.55 inch is a common tire size ...look at rcmart or amain hobbies Here all scalers use Rock beast or Mickey Thomson https://www.amainhobbies.com/pit-bul...58124?v=612209 https://www.amainhobbies.com/rc4wd-m...15042?v=576912 Good tires make all the difference |
09-15-2020, 11:36 AM | #7 | |
clearly, but finding ones to fit an MN or a WPL is a pita. 1.55"s are still to big for these things. 1.0" and 1.2" are too small. what tires are you using for MN and WPL? | |
09-15-2020, 12:45 PM | #8 |
| Re: dumb questions |
09-17-2020, 11:16 AM | #9 | |
| Re: dumb questions Quote: that's ok. i've seen Donald's work. those tires are stock WPL, MN, and JJRC pieces of various durometers. i have most of those except the JJRC NDT's which i don't need. there's one guy: https://www.youtube.com/watch?v=mhcMTE28rJs who's using rc4wd rock crushers on his B24 with printed wheels. i might go this route. | |
12-13-2020, 05:40 AM | #10 |
Pebble Pounder Join Date: Dec 2020 Location: USA
| Re: dumb questions
Any updates on the quest for tires? For rims, the WPL and MN wheels are interchangeable with a common 5mm hex hub. As far as I know, the WPL rims are symmetrical on both sides so I would go that route and eliminate that oddball (MN) from the equation. |
01-11-2022, 01:38 PM | #11 |
| Re: dumb questions
I have both the WPL V4 tire and wheel combo, with foams and the aftermarket 'generic' 70mm 10-spoke beadlock tires/wheels seen here: Both are very good wheels to fit the WPL and MN90 trucks but the edge goes to the generic beadlocks [real beadlock rims] as that is a very soft, sticky, pliable tire. Here's a halfway decent review... https://www.youtube.com/watch?v=--4TTQ8WZJU |
01-11-2022, 02:26 PM | #12 |
| Re: dumb questions
the yeti jr uses a 1.2 /1.55 tire and rim but ive had a vary hard time finding those but heres the thing there are adaptors for just about every size to any size what i would do is find some decent 1.55 wheels and a 5mm to 12mm adaptor with the 12mm adaptor you can run just about any wheel and tire combo you want and there are some realy good 1.55 tire options out there i did this with my d-12 based midnight pumpkin drift truck my d-12 is running 1.0 wheels with a 2.5 tall tire on 7mm hexes Last edited by ferp420; 01-11-2022 at 02:28 PM. |
dumb questions - Similar Threads | ||||
Dumb Servo Questions | Greatscott | Electronics | 2 | 01-05-2019 12:47 PM |
Some Newbie (maybe dumb) Questions | mrbails | Newbie General | 3 | 09-15-2016 07:32 PM |
going to order a CC-01 have some dumb questions | stevelknievel | Tamiya XC/CC01 | 2 | 01-16-2011 03:37 PM |
I am RC dumb! Lots of questions! | wranglercheroke | Newbie General | 7 | 07-16-2009 12:57 AM |
Couple dumb questions | knuckleslammer | Electronics | 20 | 04-05-2009 09:47 PM |
