Go Back   RCCrawler Forums > Scale Rigs General Tech > General Scale Talk
Thread: rti ramp- need help building one; specs please
Old 09-26-2007, 07:02 AM   #1
Default rti ramp- need help building one; specs please
need some help from you guys.......we're going to be starting our scale class this up coming season and i was thinking about making an RTI ramp for the comps. need some of your help with the specs on making the ramp. i understand the ramp is 30 degress but i need info on the scoring. i know that according to UTRCRC's rules that the rigs cannot score no more than 500 on the ramp. "500"............how does this score affiliate with how high you go up the ramp. any help on this matter is greatly appreciated, thanks alot .
RydeFab is offline   Reply With Quote
Old 09-26-2007, 09:43 AM   #2
REST IN ALOHA CHIP
YoUnG_vErSiOn's Avatar
for 1:1 scale you take 3' and 30 degrees . Ryde i made one already.its kinda small though i'll give it to you, so you kinda have an idea.
YoUnG_vErSiOn is offline   Reply With Quote
Old 09-26-2007, 10:40 AM   #3
shoots, thanks .................now just the scoring part is all i need to be explained to me .
Old 09-26-2007, 10:53 AM   #4
PapaGriz Yo
Grizzly4x4's Avatar
The "500" you refer to is the Ramp Tavel Index (RTI). A vehicle drives up the ramp, when a tire begins to lift off the ground it must stop.
From the center of the wheel (the one on the ramp) use a straight edge placed perpindicular to the ramp's surface to find the measurement point on the ramp. Then measure from the start of the ramp (where it meets the ground), up the surface of the ramp, to the point you found.
If a rig drives 7" up the ramp and it has a 12" wheelbase, the RTI is found by:
(7/12) x 1000 = 583
Grizzly4x4 is offline   Reply With Quote
Old 09-26-2007, 11:02 AM   #5
Sinking with the ship
1BadJeepBruiser's Avatar
May want to hit up colquittcustoms/DJ had a sick RTI ramp in MOAB, Im sure he can supply better pics for you to build your own His was awesome because it was adjustable, it was good for 1.9s and even bigger scale trucks like JIA ralph tuber
Old 09-26-2007, 11:08 AM   #6
PapaGriz Yo
Grizzly4x4's Avatar
Here's an illustration of how to measure.
Old 09-26-2007, 11:33 AM   #7
The score is a ratio of distance traveled along the ramp divided by your wheelbase. Then multiply that by 1000.
I made this illustration of the rules as I understand them. Maybe it will help:
TunaMaxx is offline   Reply With Quote
Old 09-26-2007, 11:34 AM   #8
Oops... look like others responded bevore me while I was making the illustration.
Old 09-26-2007, 11:46 AM   #9
PapaGriz Yo
Grizzly4x4's Avatar
Tunamaxx, your measurement should be to the red circle, not the green circle.
Old 09-26-2007, 12:10 PM   #10
The illustration is based off my interpretation of the rules I found at UTRCRC that 05tacoma stated in his first post.
I've seen it measured both ways, as each has it's advantages. Measuring at the contact patch makes for higher RTI numbers, but leaves the exact measurement open to interpretation depending how much tire bulge their is, etc. Measuring at the axle center line results in lower numbers, but removes much of the fudge factor from the measurement.
Mind you, this is from back in the day with 1:1 rigs, but that was quite some time ago now and a more standard approach may have been accepted.
Old 09-26-2007, 12:18 PM   #11
thanks alot guys, now i understand . i appreciate even the illustrations and photos that you guys took the time to post. HRCC and i really appreciate it ....................now it's off to the "shop", gots me a ramp to make . thanks again.
Old 09-26-2007, 12:29 PM   #12
PapaGriz Yo
Grizzly4x4's Avatar
Using that measurement system a vehicle can't score an RTI of 1000 without driving the rear tires up the ramp.
Using my illustration below and the other method, the distance traveled up the ramp is equal to the wheelbase when the rear tire is right at the bottom of the ramp. This is how the measurement was intended to be since it is a ratio of ramp travel to wheelbase.
The UTRCRC guys think only 1.9 wheels are scale so their judgement is suspect anyway.
Old 09-26-2007, 12:31 PM   #13
PapaGriz Yo
Grizzly4x4's Avatar
Post pics when it's done.
Old 09-26-2007, 01:38 PM   #14
Touché!
I don't ever remember anything other than attacking the ramp with the rear positioned beside it though, but you are right.
Now that I am thinking about it, I remember a ramp from years ago that had a slider built into the side of A 1:1 ramp. It allowed a bar (that was held perpendicular to the ramp surface) to be slid back and forth to find the center of the wheel.
I have redone the original illustration in my first post to show that it is UTRCRC rules. Then I created the following which should be more in line with yours:
I'd never heard of them until 05tacoma's first post!
