08-30-2011, 09:48 AM | #641 | |||
You could custom order it, otherwise it will be about a week and a half. | |||
08-30-2011, 02:08 PM | #642 |
Newbie Join Date: Apr 2008 Location: australia
Cheeds mate. Ill wait the week and a bit.
09-14-2011, 07:55 PM | #643 |
Quarry Creeper Join Date: Jul 2009 Location: Cherokee, NC
JRH, I have a 35t Torquemaster Handwound and I was wondering what the max voltage is for it. 3S? 4s? More?
09-15-2011, 11:05 AM | #644 |
I recommend 3s, but you can run 4s.
09-15-2011, 06:47 PM | #645 |
Quarry Creeper Join Date: Oct 2009 Location: Athens
Same question again please, what do you consider the max voltage of 2 x 45T motors on a XR10? Any experience with a decent starting point for gearing as well please? Cheers Mark |
09-16-2011, 08:18 AM | #646 |
15t pinions to start. 3s and 4s lipo is totally safe. People generally run 3s. You could run up to 6s if you wanted, but on an XR10 the 6s battery shape won't give a low center of gravity.
09-16-2011, 12:53 PM | #647 |
Fantastic. Thank you |
09-20-2011, 06:08 PM | #648 |
Hey mate got my motor today. A.hell of a lot quicker than I expected. Keep up the good work. Just a quick couple of questions. Ive heard that sparkin at the brushes isnt good. My motor sparks when it starts up. Is this normal? And what pinion would you recomend for 3s in a wraith. Cheers, Gav. |
09-22-2011, 01:11 PM | #649 |
Pebble Pounder Join Date: Aug 2011 Location: phoenix (Ahwatukee)
Looking at some of your motors, which would you recommend for a wraith on 2s? I would like to keep the speed similar. Thank you. |
09-23-2011, 02:05 AM | #650 |
RCC Addict Join Date: Sep 2009 Location: sacramento
20 turn is reel close
09-26-2011, 05:53 AM | #651 |
Would running an 18T TorqueMaster on 3S for the Wraith have enough torque for some low speed crawling? I am looking for the same..maybe a little more speed but with some crawlability. Running a BR-XL. I know that you said before, to compare motors to yours, it's best if we compare the RPMs and not the Turns. What's the stock motor's RPM per volt? Last edited by constantmotion; 09-26-2011 at 05:59 AM. |
09-26-2011, 09:06 AM | #652 | |||
10-08-2011, 06:38 AM | #653 |
John, I'm just piecing together my XR10 and noticed your motors have a crimp on spade style connection tabs on them. Not a fan of this style of connection so i'm wondering if it will have any affect on warranty if i solder on 2 wires to these tab instead? Cheers Mark |
10-08-2011, 09:09 AM | #654 |
You can absolutely solder to them, it is the more common method of connection and won't affect warranty.
10-08-2011, 04:38 PM | #655 |
Fantastic, thanks. |
10-13-2011, 12:30 PM | #656 |
Ordered a custom 23t for my wraith 2 days ago, do you guys e-mail a shipping notification? Is it still about a 2 week lead time before it ships?
10-26-2011, 07:59 AM | #657 |
Pebble Pounder Join Date: Mar 2009 Location: Regina, Saskatchewan
John, I recieved notification that my torquemaster pro combo shipped yesterday. I'm going to be running it in a Wraith, wondering if I should leave the timing alone or advance it, say 4-6 degrees? BTW, currently running it on 5100mah Nimh. |
10-31-2011, 03:17 AM | #658 |
Newbie Join Date: Sep 2011 Location: Ridge
I was wondering about the fat pack wind. like how hard is it on motor life VS power/torque gain. Also im collecting funds to pick up a motor or motor/esc combo and was wondering if running a 35t motor with 20/84 gears on 2s be asking alot of the motor( will be upping to 3s if i get a br-xl) the stock axial 55t seemed to not like the extra gearing when "in the bind" ............ maby with the 35t i'll throw the 14tooth pinion back in |
11-03-2011, 02:51 PM | #659 |
| I'm wondering the same with my new 27t for my wraith. I don't know If I should mess with it. I don't know how to tell what it's set at currently
11-04-2011, 07:29 AM | #660 | ||||
TorqueMaster Pro Handwound Rock Crawler motors - Similar Threads | ||||
R1 w/ HH TorqueMaster Pro 540 Handwound | nafie | Electronics | 2 | 07-16-2011 10:12 AM |
