Go Back   RCCrawler Forums > Vendors > Holmes Hobbies
Thread: TorqueMaster Pro Handwound Rock Crawler motors
Old 01-21-2009, 11:52 AM   #181
MrH
count me in too
MrH is offline   Reply With Quote
Old 01-23-2009, 11:14 AM   #182
Default 45t p -94 motors
can you preorder the p-94 motors that are coming in a couple of weeks...lmk...thanks
Originally Posted by JohnRobHolmes View Post
The origional Pro version (this thread) will be remanufactured, estimate about two months. The p-94 version is getting wound now- two weeks out. Sorry for being hard to get ahold of, I just started school and will need to change the phone hours.
ROCKCAD is offline   Reply With Quote
Old 01-23-2009, 11:18 AM   #183
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Not right now. I am not fond of preorders.
JohnRobHolmes is offline   Reply With Quote
Old 01-23-2009, 11:27 AM   #184
Default motors
no problem, thanks for posting back fast!!! lmk when they arrive. i'm in for 2-45t motors...thanks again
Old 01-30-2009, 09:36 AM   #185
So if I understand correctly, the P-94s are going to be ready in a couple of weeks, while the original's are being phased out?
I need a 35T and 45T motor, plus some batteries. Will send you an e-mail shortly John. I don't care which of the torquemaster versions they are, just want to actually be prepared for once when the Losi comp crawler gets released (although final gearing would be nice to know!) !
ecoli is offline   Reply With Quote
Old 01-30-2009, 09:46 AM   #186
The p-94s are being wound right now, the OG TM is being produced again and should be ready around end of march or so.
P-94 version should be in late next week.
Old 01-30-2009, 11:22 PM   #187
When you say OG do you mean 4 magnet?
And then another question. Can I lock the motor and turn the armature to adjust timing and get more torque out of these motors so I lose some clod stall?
rc4x4crawler is offline   Reply With Quote
Old 01-30-2009, 11:35 PM   #188
Two magnets were the OG design, but there were a few hundred 4 magnet versions that were sold. Small difference in speed, slightly faster.
If you want to change timing, just loosen the endbell and rotate it. You want it to be faster with advanced timing. If you look on the can there should be timing marks. Don't wrench the comm, that is just a cheater trick for stock motor drivers.
When you advance timing you will lose torque at the motor, so if you gear down to compensate for the extra wheelspeed you could gain torque at the tire. Otherwise you may not get more torque, depending on the voltage and wind of the motor.
Old 01-31-2009, 08:57 AM   #189
Ok. I got the idea from my dad who did race stock cars. I will leave them alone then. You know of any other 4 magnet motors? My drag brakes are just not strong enough on 2 magnets.
Thanks
Old 01-31-2009, 09:03 AM   #190
Drag brakes are even weaker on 4 mag cans. What ESC are you using?
Old 01-31-2009, 09:10 AM   #191
Really. Well I guess I thought that because I was running a 4 magnet 45t on an FXR and then switched to 2 magnet sidewinder. But now in the Berg I run Mamba max with to integy motors. It could be the motors I guess.
Old 01-31-2009, 09:13 AM   #192
Integy motors have poor drag anyway. Tekin controllers have a bit more drag than Castle controllers.
Old 01-31-2009, 09:15 AM   #193
Ok so would you recommend a 35t P-94 or wait for the OG 35t pros to come in? For a Mamba max esc.
Old 01-31-2009, 09:21 AM   #194
Both will perform near identical, I have no preference between the two really.
Old 01-31-2009, 09:49 AM   #195
Ok. I think I will pick up some p-94s when they come in.
Thanks JRH.
Old 02-02-2009, 10:05 AM   #196
Good stuff. Sent you an e-mail, let me know if you didn't receive it and I'll resend.
Old 02-24-2009, 01:42 PM   #197
Just had them ship in. Believe it or not 14 have already sold off the site before I got here and posted.
Old 02-24-2009, 01:55 PM   #198
pdm
Got my pair ordered
pdm is offline   Reply With Quote
Old 03-03-2009, 03:11 AM   #199
p-94 build is now officially discontinued. Good thing I have plenty of the OG TorqueMasters on the way from Japan right now. ;)
You said end of March? Im in need of 5 35T OG TMs and since you said the p-94s are discontinued I assume I now have to wait for the TMs. You said your not fond of Pre-ordering but is that still a NO then? j/w so I can make sure a few of my rigs are covered... Thx John
Rocky
ADDICT is offline   Reply With Quote
Old 03-04-2009, 11:16 PM   #200
You still looking at the end of march for your Hand Wounds? So couple weeks?
TorqueMaster Pro Handwound Rock Crawler motors - Similar Threads
R1 w/ HH TorqueMaster Pro 540 Handwound nafie Electronics 2 07-16-2011 10:12 AM
You may edit your posts
