| | #1 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| ![]() I just got in some new lipo packs for crawlers, and they are just what we need I have done extensive testing and data logging to try and recommend the RIGHT pack for you, and nothing less. Getting a lipo pack that doesn't have proper discharge rates will shorten the life greatly, and waste your money! Here is the current line up: 2.2 single motor packs: single 55t 540 motors and slower: ![]() ![]() single 45t 540 motors and slower, Crawlmaster outrunners, Revolver Black Outrunners: **Can be used on handwound 35t motors, but battery life may be reduced** ![]() ![]() Dual Motor Packs/ High Power Packs Dual 35t and slower, single 20t, Cobalt Pullers, Outrunners over 5 ounces ![]() ![]() And now an inexpensive high discharge rage for a limited time! ![]() I run the two cell 2200 pack in my comp rig, and the two pullmaster motors are real POWER hogs. The pack does wonderfully, doesn't miss a beat, doesn't warm up, and keeps a high voltage throughout the run. Top speed is around 15mph with current geardown I highly recommend the 2200 packs for all competitive BERG setups, they will yield long cycle life and top notch power. Any questions, just ask!! Last edited by JohnRobHolmes; 09-27-2008 at 01:02 AM. |
| Sponsored Links | |
| | #2 |
| PapaGriz Yo ![]() Join Date: Apr 2004 Location: Planning
| | #3 |
| That would be a great choice IMO. I can get it in a 4 cell pack if you wanted a single chunk. I have ran my 20t on 4s 16C 2100 cells and they did OK, but the extra margin of the 20C cells is needed for pack longevity IMO. |
| | #4 | |
I think I prefer the two 2S packs so I can switch to 7.2V on the fly. | |
| | #5 |
| RCC Addict ![]() Join Date: Oct 2005 Location: Trussville, AL
| WOW, just saw the prices of these things and well .... would any of these packs work good with your faster 540 motors like say the 11T, 13T, 15T, or 17T? |
| | #6 |
| Gold Star Baby! ![]() Join Date: May 2007 Location: Taylors Falls just hanging with the MNRCRC crew.
| JRH which 7.4 would you recomend for a Novak Goat? |
| | #7 |
| Rock Crawler ![]() Join Date: May 2007 Location: Norwich
| Can you get a Silver Knight 2C with a Hyperion tap? |
| | #8 |
| Quarry Creeper Join Date: Aug 2007 Location: Castle Rock
| Would the 3S 2200 pack be great for a heavy 2.2 rig with a CC Mamba Max ESC, 35T Warrior motor, Dig servo, and JR 9100T steering servo? Or should I go for the 3S 1300? Thanks |
| | #9 | |
| TEAM MODERATOR ![]() Join Date: May 2004 Location: Tennessee
Personally,I'd go with the 2200 over the 1300. That's what I'll be getting for my 2.2 running similar electronics. | |
| | #10 | |
| I can. I chose the 20C packs for the 2200mah because the motor won't burst as much amperage when stalled on 2 cell as compared to 3 cell. The tap that comes on them is compatible with hyperion but smaller. Plug them into the 4s slot if you have a multi-tap, all the way to the right side of the tap. Quote:
2200 all the way. As recommended in the first post I would not use a 1300 pack on anything faster than a 45t motor. | |
| | #11 |
| Quarry Creeper Join Date: Mar 2008 Location: Redlands
| John, can you give me the dimensions of the 7.4v 2200mah li-po? |
| | #12 |
| Alll the info is on my site, click the pic. |
| | #13 |
| Yeah I a retard, I did that like 30sec after I posted, i'll have to check my clearance for that battery. |
| | #14 |
| I wanna be Dave Join Date: Apr 2005 Location: It's good to be a Pirate!
| I have been running the 11.1 1650 on my Berg and have had no issues at all. I have about 100+ cycles through the battery and have not had an issue. |
| | #15 |
| Pebble Pounder Join Date: Feb 2008 Location: Bala Cynwyd
| Which one from your new line up do you recommend for the Revolver? |
| | #16 |
| I would use either the 1300 or the 2200 packs. If you drive really hard the 2200 pack is a good idea. If you don't get wedged much and need a smaller pack the 1300 will work just fine- or even the 1650. Franky is probably running the 1650 on a revolver black, but I like to overestimate your needs just in case. 3 cell lipo on a revolver no matter what though. |
| | #17 |
| Quarry Creeper Join Date: Aug 2005 Location: Vegas Baby!
| Just ordered on of the X-Caliber 15C 3-cell 11.1 volt 1650mah Li-Po's. Cant wait to try it out! |
| | #18 |
| RCC Addict ![]() Join Date: Oct 2005 Location: Oak Hills
| hey john, when will you have more x-caliber 2C 1300 packs in stock? I could use a few |
| | #19 |
| Newbie Join Date: May 2008 Location: Hampton
| I just got my Black Knight 2200mah 7.4 packs in. I understand now about putting the plug all the way to the right on the 4S plug on the Hyperion multi connector. It is quite snug, should I shave the tabs a little, and what settings should I use on the Hyperion 0606i AC/DC charger? Standard 2S and follow the ratings for the battery? I'd like to know before I solder on any connectors. THANKS!! |
| | #20 | ||
2s lipo, 2200mah, it will charge at 2.2 amps. Nothing more to set. | ||
| Thread Tools | |
| Display Modes | |
