08-15-2008, 06:07 AM | #21 |
Yes it is, I will fix that up.
08-15-2008, 11:22 AM | #22 |
RCC Addict Join Date: Feb 2006 Location: ccxc
hmm must have missed it......I'll check it out thanks for the info
08-15-2008, 03:15 PM | #23 |
Quarry Creeper Join Date: Apr 2008 Location: Garden Grove
| FXR and BEC
I do like the FXR. I have three. If you use 3s lipo, you must use a CC BEC or you will not be happy with it. The amp draw from the servos and the esc are to much for the 3A internal bec.
08-15-2008, 04:04 PM | #24 |
I have more on the way due in monday or tuesday.
08-19-2008, 04:50 PM | #25 |
Back in stock.
08-25-2008, 01:45 AM | #26 |
Pebble Pounder Join Date: Dec 2006 Location: QLD, Australia
hi john, im looking to run a Tekin (mainly for the size) and lipo in my axial. im currently running a 7t cobalt, rooster crawler & 7cell saddle pack. what sort of lipo would you recommend for the cobalt, and how would it go with a Tekin, or would i need to go a mamba max. cheers, Seb |
08-26-2008, 09:56 AM | #27 |
The Tekin would be awesome, I run them with my cobalts with no issue. I would recommend at least a 35amp battery for the 7t. If you are going to run 3 cell you may even want to use a 45 amp battery for longer battery life. |
08-26-2008, 02:59 PM | #28 | |
thanks for the help, but to narrow it down would there be any lipo you sell on your site that you would recommend? i no nothing about batteries, but i will most likely run it on my front axle so size is a bit of an issue. but as for choosing the right specs, id rather get expert advice. any help with a charger would be great aswell. feel free to email or pm me the answer, instead of cluttering up this thread , but i cant pm you so i just posted instead. cheers, Seb | |
08-26-2008, 03:13 PM | #29 |
Quarry Creeper Join Date: Jul 2008 Location: Galt
No, please DO clutter up the thread, 'cause I want to know the answer too! I plan to run the FXR + Cobalt7T, but I don't know which battery to get. Will this battery fit on the optional Axial batt/servo tray, and is this what you'd recommend for the FXR+7T? Last edited by XPLORx4; 08-26-2008 at 03:26 PM. |
09-09-2008, 08:46 PM | #30 |
Quarry Creeper Join Date: Jun 2005 Location: in the middle of the pacific ocean
I am running the FX-R Pro with 2 35t HHH motors in my berg. On 2s I had no problems. When I switched to 3s, I get all 6 light on and everything stops when climbing. I know other people are running this same combination. If I run a cc bec, wold that help my situation. I figure if I take the load off the bec, maybe it would help with the thermal shut downs? Or are these motors to much? EDIT: I hooked up the cc bec at 6 volts and it took care of the problem Last edited by dorji; 09-10-2008 at 12:17 AM. |
09-09-2008, 10:07 PM | #31 |
Holmes Hobbies Join Date: Jan 2007 Location: No Where
I just ordered one,Thanks John
07-26-2009, 11:42 AM | #32 |
Quarry Creeper Join Date: Apr 2009 Location: Long Beach
| FXR - hotwire Current settings? I just recently got your FXR (week to 10 days ago), set it up in my Axiel 2.2 comp and using a Holmes 35T, a CC BEC to the servo's and 2S and 3S lipos. Gearing not low, 13-87. I also just got your Hotwire and also being a newbie with ESC etc. (old nitro guy) took some time to get it all ready. I have played with it around the yard and messed with the setting. Saturday was my first trip to the rocks. I was using my 3S lipo and 5 minutes into crawling the FXR went up in flames..... So what did I do wrong??? I can't tell you all the setting now, because it is fried, I do know it was set for 3S cutoff, instant reverse, and the current was high 60-70??? This is probably the reason for the fried FXR? I thought the current setting had something to do with throttle control. Any help, advise... would greatly be appreciated... Thanks Norris.. |
08-01-2009, 04:18 PM | #33 |
Sounds like a bad unit from the factory. All warrenty is done through Tekin, per their request. Just give them a ring and they will take care of you.
09-07-2009, 12:31 PM | #34 |
I wanna be Dave Join Date: Dec 2008 Location: ?
when is that new esc your making out to the public?
09-08-2009, 09:00 AM | #35 |
The current run should be done in about two weeks.
09-17-2009, 09:40 PM | #36 |
I wanna be Dave Join Date: Aug 2008 Location: Deep in Swing Town
HH, what is your words on the FXR running two of your 35t motors in my berg.?? anything i should know??? sometimes we go out for 2-3 hour crawls at a time.... thanx |
