Go Back   RCCrawler.com Bulletin Board > Vendors > Holmes Hobbies
Thread: Tekin FXR and FXR-pro ESCs in stock
Old 08-01-2008, 01:48 PM   #1
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Default Tekin FXR and FXR-pro ESCs in stock
Just got a fresh shipment of FXR ESCs. These are my preferred ESC on my comp rigs. Small, powerful, and drag brakes!
Specs:
The Tekin FX R is the most feature packed, smallest, and BEST ESC for brushed motors! This sets the standard for all other ESCs to follow.
Easily access to programming
PC interface for custom programming (Tekin HotWire required)
On board temperature indicator
Pro-style Solder posts for easy wire replacement
Self diagnostics and factory reset
Pit tune mode
Digital glitch filtering
One touch radio calibration
Programmable features:
Drag brake - 13 steps
Push control-anti drag - 13 steps
Neutral width - 13 steps
Voltage cuttoff - none, 2S, 3S, custom
Current limiter - none, 12 steps
Throttle profiles - 7 choices
Brake profiles - 7 choices
Reverse type - 3 steps
Reverse strength - 13 steps
120 day limited warranty
INCLUDES: One FX-R Brushed Electronic Speed Control Two 1x1" pieces of servo tape Three 4.5" long zip-ties Three Tekin sticker sheets
SPECS: Input Voltage: 4-9 Cells/2-3S Lipo Motor Limit: 12 turn On Resistance: 0.0012 ohms BEC: 6V/3A Dimensions: 1" x .8" x .4" (25mm x 20mm x 10.2mm)
JohnRobHolmes is offline   Reply With Quote
Old 08-05-2008, 08:34 PM   #2
FIRE the Bamster!!
Bart bender's Avatar
The Hotwire is not included? Is this required to custom program or is that done with the button on the Esc?
Bart bender is online now   Reply With Quote
Old 08-05-2008, 10:10 PM   #3
Are you going to carry the Hotwire kits?
SuperBad is offline   Reply With Quote
Old 08-05-2008, 10:19 PM   #4
TCS/Holmes Hobbies
SVEN's Avatar
The Hotwire is not included with the ESC. Although it would likely make programming easier, it is not required to set up the speed control. The FX-R is probably the easiest ESC's I've set up with out a USB link. You don't need the transmitter to change the controller's settings, just the two buttons and the blinking lights.
SVEN is offline   Reply With Quote
Old 08-05-2008, 11:25 PM   #5
I have them, just not on the site yet. Hotwire is not included with the ESC, but not needed for programming.
Old 08-06-2008, 03:34 PM   #6
Do you consider these to be better than a Mamba Max? Are there more setting options for the Tekin? I only ask because I've been running MM's on all my rigs for a long time now but have been considering trying this one since its so small, however it will only take 9 cells where my MM can take up to 12. What are the advantages/disadvantages of the Tekin over the MM? Why is this one preferred over the MM other than the size? Thanks for your response John.
'04 Rubicon is offline   Reply With Quote
Old 08-06-2008, 03:43 PM   #7
I couldn't tell a difference between the two, driving them without knowing which was which.
The tekin is smaller and easier to stick program. It cannot handle the same amount of power as the MM, which may be trivial in a crawler. I use them for the smaller size and nothing more, as compared to a Castle product.
Old 08-06-2008, 10:24 PM   #8
isnt the Pro version able to handle more cells?
Deezul is offline   Reply With Quote
Old 08-07-2008, 07:51 AM   #9
No, just more amperage.
Old 08-07-2008, 08:21 AM   #10
JEracing's Avatar
I have the FX-R and don't have BEC in my rig (yet) what can you tell me about this? Whats reccomended?
JEracing is offline   Reply With Quote
Old 08-07-2008, 08:33 AM   #11
A Castle BEC is what I use to power my hungry servos. I set it to 6v generally.
Old 08-08-2008, 06:06 AM   #12
JEracing's Avatar
CC BEC has a 10 amp rating... is this the reason for using it? The internal BEC in the FX-R is set at 6v 3A.
So voltage isn't the issue??... it's the amperage??!!
Old 08-12-2008, 10:50 PM   #13
Hey John so does this mean that you can do all this without the hot wire:
Push control-anti drage - 13 steps
Voltage cuttoffs - none, 2S, 3S, custom
And what are the extra features with the hotwire?
rc4x4crawler is offline   Reply With Quote
Old 08-13-2008, 08:28 AM   #14
The only extra features of the hotwire are throttle curves, that I can think of.
All the rest is easily adjustable via radio, everything you listed.
Old 08-13-2008, 09:57 AM   #15
Ok thanks John I'll pick one up from you as soon as I get the $.
Old 08-13-2008, 02:46 PM   #16
binaryterror's Avatar
I found the drag brake in the FX-R to be way better than the MM.
binaryterror is offline   Reply With Quote
Old 08-13-2008, 05:42 PM   #17
I have found the strongest settings to be the same, and more difference with respect to drag brake depending on motor selection instead.
Old 08-13-2008, 10:50 PM   #18
FXR and RPRO have no throttle curve adj at all.............no biggie
Old 08-14-2008, 08:45 AM   #19
They do if you use the Hot Wire controller to program those.
Old 08-15-2008, 12:56 AM   #20
I crawled that crack
hotwheels000's Avatar
I was just at your site and it shows out of stock on the FXR, is that a mistake ?
LMK, Thanks
hotwheels000 is online now   Reply With Quote
You may edit your posts
