| | #1 |
| owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| ![]() ![]() Looking for fresh a123 M1 cells but don't want to hack up a Dewalt pack? I get factory fresh cells, in any qty you desire. These are my personal favorite for short distance packs. The cells are light, have a high discharge rate, and take quite the abuse. The quality control and consistency between cells is the best in the business. up to 60C burst (138 Amps) (I recommend using them at 25C max) 62mm by 27mm 75 grams Chargeable in as little as 15 minutes 2300mah 3.3v nominal per cell Order them direct here, $15.50 each : http://holmeshobbies.com/product.php...&cat=22&page=1 For orders over 48 cells, I can give discounts. PM me here or send an email through my site. a123 1100 cells also available 3.3V 1100mAh (cell/no tabs) 30C/60C Rating: 30C (33.0A) continuous, 60C (66.0A) burst Dimension: 18mm x 65mm Weight: 40 grams Termination: Cell only with PVC wrap Thank you, JRH Last edited by JohnRobHolmes; 09-26-2008 at 12:22 PM. |
| Sponsored Links | |
| | #2 |
| I wanna be Dave ![]() Join Date: May 2006 Location: akron
| thats a great price john.. I will order some up this weekend... do you think you will carry the double AA'ish size one's as well??? |
| | #3 |
| I can. They would be useful for us I reckon. I will check it out and possibly put them on the site this afternoon. |
| | #4 |
| sweet there nice for scalers.. |
| | #5 |
| Rock Crawler Join Date: Jun 2007 Location: Great Britain
| Do you know if there are any of these cells close to the size of 2/3a cell?? |
| | #6 |
| The 1100 cell is 18mm x 65mm. 1mm larger in diameter than 2/3a, and just a smidge longer than two cells in a row. Gonna add them to the website now, I can get them drop shipped within 24hrs of ordering. |
| | #7 |
| man that is cusomer service there... ask for a product and within the hour it is there to order ... nice job I will get order in this weekend if all goes well.. |
| | #8 |
| I have many products that I can get, especially batteries. I just choose not to spread my store and inventory too thin sometimes. |
| | #9 | |
| PapaGriz Yo ![]() Join Date: Apr 2004 Location: Planning
My Triton 2 charges Li-ion so it should charge these right? These are the same thing as what's in the Dewalt packs? | |
| | #10 |
| Yes, they are the same as the dewalt cells. They take a special charge algorithm though, you need a123 or LiFePO4 charging. For 2 or 4 cell packs you can charge as 6v or 12v lead acid, but a 3 cell pack is an odd voltage and must use 3s LiFe charging. |
| | #11 | |
I'll look at my manual. My Dewalt pack for the cordless drill charges in like 15min, maybe I'll just solder on a deans connector to the charger. | |
| | #12 |
| . ![]() Join Date: Nov 2005 Location: Rock chucking territory
| Ty was charging them as 3 cells on a Triton and popped alot of them too!! He started building just 2 cell packs and then putting one in as a jumper and had better luck then I believe. |
| | #13 | |
I read the manual. When charging LiPo or LiIon you set the battery capacity and the exact battery voltage. The charger chooses the amperage. Sounds like the cc/cv system isn't a good idea. From the manual. Notes about charging LiPo and Li-Ion batteries: • Triton2 automatically sets the charge current based on the battery’s 1C rating. Therefore, it is very important to enter the battery’s exact rated capacity (in mAh) in the programming. For example, if a capacity of 600mAh is entered Triton2 will set the charge current at 0.6A (600mA). For a capacity setting of 2500mAh, the charge current will be set to 2.5A (2500mA). If you do not change the factory default battery capacity value, Triton2 will charge the battery as if it’s rated at 350mA (0.35A). • LiPo and Li-Ion batteries are charged using the “constant current / constant voltage” process (cc/cv). Constant current is delivered during the first part of fast charge. As the battery reaches a pre-set voltage (4.0V for Li-Ion, 4.1V for LiPo), Triton2 shuts off constant current and starts to apply a constant voltage. As the battery’s voltage equalizes to the output voltage of the charger, the charge current will drop to approx. 1/10 of the charge current setting, at which time all charging will stop automatically as the battery is fully charged. | |
| | #14 | |
| Moving on!! ![]() Join Date: Sep 2007 Location: Colorado Springs
Hey JRH, Is there anyway you could put 4 of these a123's side beside one of your 9cell 2/3a packs and post a picture. I have also been looking to change to these cells, I am just lazy and do not want to change my battery mount if I needed to make it bigger:-P If ya can't no biggy, I will just wait till Griz buys them and take a peak at his | |
| | #15 | ||
| | #16 |
| Quarry Creeper Join Date: Apr 2007 Location: YAKIMA
| hey jrh can you get them in the same size as sub c's to fit jp knuckle packs? thanks chad |
| | #17 | |
The main thing that has stopped me so far is dropping more $$ on a new charger. I have a MRC 989 that says it will do 1-8 cell Lithium ion/lithium polymer and 6-24v lead acid/gell cell batteries. I would assume that a 4 cell could be done? I know I can pick what charge rate and cut off for any battery. I did not know about the lead acid charging. JRH--Could I get away with not buying a new charger? Here is a link to the manual. I know very little when it comes to these. http://www.modelrectifier.com/resources/BatteryChargers/RB989_manual.pdf | |
| | #18 |
| Mr. Holmes, I would like to get some of these and charge them with my A123 charger. Do you know the correct way to wire them to charge with it? |
| | #19 |
| [HOONIGAN] ![]() Join Date: Nov 2005 Location: Grand Junction
| Grizz and 666, The batts that Ty has (they are the cells I gave him, and gave you guys too) are Milwaukee cells. They E-Moli cells, they are similar to the a123's but they are a different cell. They have completely different charging voltages, peak voltages, capacity, etc. If you try and charge them the same as an a123 one of them is going to blow up. Also, the a123's are badass and are a lot better than the E-Moli's. I've been running both of them for over a year now and they are both great but the a123's are better. |
| | #20 |
| Jeez "Wrecker" your always correcting me.... All I have are A123's. Love 'em!!! |
| Thread Tools | |
| Display Modes | |
