01-08-2010, 02:08 PM | #241 |
RCC Addict Join Date: Oct 2005 Location: Trussville, AL
got my waterproof version in the other day and installed. Everything works like a charm. Updated the software and set my setting and the scaler is ready to rock and roll. This thing takes up less space and is less of a headache than try to use a waterproof box Now waiting on the throttle curves to become available |
01-08-2010, 10:38 PM | #242 |
RCC Addict Join Date: Jan 2009 Location: O.C
[QUOTE=JohnRobHolmes;2213122]Could be a bad unit. Were you running the Holmes Hold when it stopped? Send it on in, I will replace it out. Include the details of what you were running and how to contact you. John Holmes 716 W. Sexton rd. Columbia, MO 65203 Thanks John, I'll have it shipped out tomorrow (Sat.) with the details. Last edited by badger; 06-21-2012 at 11:36 AM. Reason: address change |
01-09-2010, 11:54 AM | #243 |
RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
So does the new Castle Link software have the Holmes Hold options? I haven't installed it on mine yet. |
01-10-2010, 02:42 PM | #244 |
Pebble Pounder Join Date: Dec 2008 Location: Sykesville
| Tried it today with a new motor and the same thing. I tried to calibrate it a few times like the one guy suggested. It just appears not to take the calibration for reverse. I will send it out tomorrow to: John Holmes 716 W. Sexton rd. Columbia, MO 65203 Thanks Jeremy Last edited by badger; 06-21-2012 at 11:36 AM. Reason: address change |
01-10-2010, 08:46 PM | #245 |
Quarry Creeper Join Date: Dec 2008 Location: Lansdale
The esc I have setup for the rear axle isn't arming. It just flashes green. It will turn red when I apply throttle but no motor movement. Now if I wait and leave the battery plugged in it will start to run in reverse on it's own at this point it will except throttle inputs but no neutral. Front esc is running fine. I loaded and reloaded the frimware a few times and I reset my reciever settings a few times. It was working perfectly last weekend I updated it today and nothing. Any suggestions?
01-11-2010, 08:14 AM | #246 |
I wanna be Dave Join Date: Dec 2008 Location: ?
[QUOTE=JohnRobHolmes;2213122] A week or so on the ESCs. QUOTE] any news on these |
01-11-2010, 08:43 AM | #247 | ||
JRH I haven't got word of them shipping out yet. I left town for a few days, just got back and your package is here. | ||
01-11-2010, 05:40 PM | #248 | |
It won't hold level like that picture that was posted, but that's probably because I have cheesy cheap integy motors. lol | |
01-11-2010, 08:00 PM | #249 |
Fixed! Thanks for your assistance |
01-12-2010, 07:52 AM | #250 |
This ESC looks like a must have I really like the BEC feature my questions are does it program on the Castle link like a Mamba Max and are they in stock?
01-12-2010, 09:35 AM | #251 |
| John Would you say it is fair the internal BEC was just a bad one in the esc. Do you feel that I should run a external BEC? I saw a few other people have the same type of problem. Then I see some have none. Also I am thinking about putting my Vanquish dig with a Hitec 5645mg on as well as my Hitec 7950 for steering or my servo winch If I do there will be two servos. Should this internal BEC hold up? Last edited by sally1800; 01-12-2010 at 09:50 AM. |
01-12-2010, 10:30 AM | #252 | ||
It programs similar to the mamba max, but you need the castle link usb adapter. Quote:
01-15-2010, 04:27 PM | #253 |
Quarry Creeper Join Date: Sep 2009 Location: Divide, CO
Are these in yet?
01-15-2010, 10:19 PM | #254 |
RCC Addict Join Date: Dec 2005 Location: Tucson
Today i had a problem with my BR's today. My custom lipo cutoff didnt work. it was set to 9.2v on both esc and it dumped to 7.78v. Now my lipo is dead. Never using the custom cutoff setting again. just setting it to 9.0v. I dont know what went wrong its never done this before the 1.05 update. passive drag brake is on not holmes hold.
01-16-2010, 04:11 AM | #255 |
Newbie Join Date: Oct 2007 Location: Germany, Wesel a. Rhein
| no calibration possible
Hi there, I've got the new TM BR-XL yesterday and tried to calibrate it this morning. The postions 4 + 5 will work fine (user guide 3.1, pg2). Pos. 6 wasn't exactly like in the user guide. It will beep rapidly but the grenn light will flash too. Pos. 7 is uncritical too. But the ESC will not store the neutral position. Instead of this the red light ist flashing and it beeps. Tried it with another battery (2s and 3s) and another motor (Cobalt puller 7t). Using a Spektrum DSXR and the SR3100. What's wrong? I'm afraid, I need some help. Thanks Tom Last edited by Tomdigger; 01-16-2010 at 04:29 AM. |
01-16-2010, 10:26 AM | #256 | ||
| Yes, I am looking at a few hundred here. They will be shippable by wednesday, I am just waiting on some plugs. Quote:
I will write this into the 1.05 instructions as a warning too, if necessary. Quote:
You may just need to adjust your neutral throttle setting on the radio. You can also try going into the Castle link and widening your deadband to a larger setting. This should take care of it. | ||
01-16-2010, 12:49 PM | #257 |
Hi John, that was the right hint. Thanks Tom |
01-18-2010, 07:05 PM | #258 |
I trickled the battery back and used for a comp on Sunday. set on 9.0v and worked great no over discharging. I full charged the pack the first time it over discharged and only drove it for 2 mins and it went to 7.76v recharged it to 12.60v and ran the comp and it went to 12.10v. I thought the twin BR's where drawing to much and causing it to dump the battery past the cutoff. it only does it on custom cutoff and not on the preset cutoff.
01-18-2010, 07:47 PM | #259 |
Rock Crawler Join Date: Feb 2007 Location: Lorain
So these will be shippable by wednesday, but how soon are we going to be able to order? Much success with the waterproofing? |
01-18-2010, 08:29 PM | #260 |
I'm waiting on one to, will they be ready soon?
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/holmes-hobbies/200916-torquemaster-br-xl-big-brushed-power.html | ||||
HH TorqueMaster BR-XL new bad boy esc! | This thread | Refback | 10-04-2011 03:37 PM |
