03-17-2010, 04:44 AM | #301 |
Just ran the BR-XL last comp for the first time. Seemed great.. I did have the Shudder issue, but my Holmes Hold and Drag brake are 100%... I know this isn't an ESC issue, but is there any reason why a front motor seems to have less power then the rear? I've checked, brushes, gear mesh and all the bolts on the case for any binds. The Rear seems to engage first as well. |
03-17-2010, 06:06 AM | #302 | |||
Try turning the drag down to 50% to get rid of the shudder, then you can bump it up slowly to see how much your motors will take. Has your front motor overheated? I have had this issue before too. Could be a timing issue as well. In your position I would probably just swap the motors front to back and see what happens. | |||
03-17-2010, 12:33 PM | #303 |
Rock Crawler Join Date: Dec 2008 Location: Marengo, Ohio
03-19-2010, 10:01 PM | #304 |
Hey John does the Field Progamer work on this as well?
03-20-2010, 01:10 AM | #305 |
I wanna be Dave Join Date: Jan 2009 Location: laying low
03-20-2010, 04:34 AM | #306 |
Rock Stacker Join Date: Mar 2009 Location: Finland
03-21-2010, 03:19 PM | #307 |
Pebble Pounder Join Date: Apr 2004 Location: Aurora
Just put in my new ESC. Everything is working great! The only question I have is I seem to have lost rear drag brake when I am in front dig. Is this a software problem? I saw on mine I have the new Beta software. Should I download the V1.02 software? I even switched motors to see if that was the problem. My motors are also HH. Mine has the same shuddering issue when I have Holmes Hold turned on. Any advise? |
03-29-2010, 06:26 AM | #308 |
Rock Crawler Join Date: Nov 2009 Location: Wildwood
So when is the adjustable throttle curve going to be available?
03-30-2010, 08:57 AM | #309 | |
| It works as a castle link, but not as a stand alone field programmer. My ESCs don't use a standard "mamba" or "sidewinder" compatible firmware. Quote:
How is your dig actuated? It probably won't make the next firmware release, it is taking a lot more work to fit the throttle profiles on the chipset than expected. It is still on slate though, and is the number 1 feature being worked on. | |
03-31-2010, 11:10 AM | #310 |
yeah....I need something to get that low speed control that I have been missing.
04-01-2010, 10:21 AM | #311 |
I wanna be Dave Join Date: Feb 2006 Location: Campbell, CA 4 hrs 2Rubicon !
Pardon for asking, Is there an Update for increased Drag brake ? I ask because my Version 3 DIG switch would have the ESC plug into it and just as you reach near neutral it would apply a awesome drag brake. but the unit does not work like that and Punkrc is sending a replacement that probably be the standard version. Thanks |
04-01-2010, 11:04 AM | #312 |
the drag brake cannot be increased any more. If you need more drag than 100%, turn on the hold.
04-01-2010, 03:09 PM | #313 |
I wanna be Dave Join Date: Sep 2008 Location: behind the wheel of a monster truck...
Sent you a message about my esc's on the site..Get back to me when you can..
04-01-2010, 04:48 PM | #314 |
Rock Crawler Join Date: Sep 2007 Location: Colorado Springs
John, I just have to say. AWESOME Product!! I have one of your first batch esc's and love it. I have not even plugged it into a castle link since I got it. I loved the settings it came with!! At a recent comp, I was pulling Turtle on PW for like 20- 30 mins. 55t motors, 4cell lipo, full throttle the whole time. Motor bunt the shit out of my hand but the BRXL was not even warm. Clicky for the video Last weekend at the scale comp, 45t and 6cell lipo. About an hour later, motor is up in smoke and the BRXL not even warm. Great job and now I need money for 3 more to replace my other ESC's |
04-03-2010, 11:04 PM | #315 | |
04-07-2010, 08:10 PM | #316 |
On the Auto lipo LVC Does that mean I can plug in whatever lipo and it automatically detect it's cutoff ? |
04-07-2010, 09:01 PM | #317 |
Yep, it will beep the lipo count right after the initial arm.
04-07-2010, 09:29 PM | #318 |
I wanna be Dave Join Date: Dec 2008 Location: ?
04-07-2010, 09:49 PM | #319 |
I wanna be Dave Join Date: Jul 2006 Location: The beautiful Pacific Northwest
I just bough one of these from a buddy of mine and I believe it's from your 1st run (It's new in package no sticker or anything). So if I normally run a 3-cell lipo, and plug in a 4-cell, it will automatically set the cut off to 13 volts or so? If so, that's great! Before I install this ESC what should I do to make sure it's updated? I do have all the Castle links so that's not a problem. Also John, is this basically what you use for the waterproofing? http://www.drillspot.com/products/44...tting_Compound Are you waterproofing them with the cases on now, I thought I saw that you were doing it without the cases on for the first batch. Thanks, Tim. |
04-09-2010, 04:23 PM | #320 |
Rock Crawler Join Date: Jul 2007 Location: E LEE, NV
Bought one of these.and love it |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/holmes-hobbies/200916-torquemaster-br-xl-big-brushed-power.html | ||||
HH TorqueMaster BR-XL new bad boy esc! | This thread | Refback | 10-04-2011 03:37 PM |
