08-25-2010, 12:25 AM | #441 |
Newbie Join Date: Jul 2010 Location: Longmont
Can it run brushed or brushless
08-25-2010, 05:03 AM | #442 |
Noted about the issue you had with throttle points, I will check into it. This one is just brushed, as the thread title states. |
08-30-2010, 09:54 AM | #443 |
Rock Crawler Join Date: Apr 2010 Location: Central FL
Everyone seems to be divided on this issue, so I'll defer to the expert... Would the onboard BEC in the BRXL be enough to run a Hitec 7950? Here are the stats from Servocity: Idle Current Drain (4.8V): 9mA at stop Idle Current Drain (6.0V): 9mA at stop Current Drain (4.8V): 220mA/idle and 3.8 amps at lock/stall Current Drain (6.0V): 300mA/idle and 4.8 amps at lock/stall Seems like @ 6v it will be pushing that BEC pretty hard... |
08-30-2010, 10:07 AM | #444 |
Yeah, that is right on the edge of it. If you will be competing, I would suggest that you have another BEC for prosperity. For tooling around the yard, not so critical as you can always pick up a BEC if the need arises.
08-30-2010, 03:11 PM | #445 |
08-30-2010, 04:47 PM | #446 |
RCC Addict Join Date: Jun 2008 Location: Nunya Idaho...
quick question on these and a bec, running duals, do I remove the red wires on both esc's?
08-30-2010, 05:02 PM | #447 |
If you want an external BEC to power the servos and RX, yes you would remove the red wires on the ESC rx wire. Otherwise, you can run the internal BECs in parallel with each other with no problems.
08-31-2010, 10:39 AM | #448 |
Rock Stacker Join Date: Sep 2008 Location: Redmond
Just checking to see if you have found what went wrong or where I went wrong the the ESC I sent back to you. Thanks, Chris |
09-02-2010, 06:13 PM | #449 |
Anything yet?
09-02-2010, 06:15 PM | #450 |
What is your name, or some part of your contact info?
09-02-2010, 08:28 PM | #451 |
Chris Berge, order # 5352, ordered on the 13th of August, shipped back and received on your end August 26th. Thanks |
09-02-2010, 08:31 PM | #452 |
Probably already going your way, I will confirm in the morning.
09-03-2010, 11:49 AM | #453 |
That's cool, not trying to rush you or anything, just trying to get a workable schedule going. That ESC is the last piece of the puzzle for my TTC build and want to ensure I can get some good test and tune in before the big event in October. Thanks, Chris |
09-03-2010, 11:52 AM | #454 |
Looks like it is still here, my mistake. Today's mail run has already come and gone, so I will get your package back to you in tomorrow's mail. Thanks for the patience!
09-03-2010, 12:02 PM | #455 |
No sweat, I know how hectic things can be. I've got a back up ESC for the time being to get some runs in. Thanks for the update!
09-05-2010, 02:28 PM | #456 |
RCC Addict Join Date: Sep 2009 Location: Bradenton
is this the ecs that comes in $109. combo?if it is will that motor do good when wet?thanks
09-05-2010, 04:54 PM | #457 |
It is, I've had that motor deep in the mud and water, as long as you do preventive maintenance you shouldn't have any problems, but running them in silty water and mud can reduce their lifespan.
09-06-2010, 10:08 AM | #458 |
Rock Crawler Join Date: Mar 2004 Location: Albany
Hey John I have a new BR-XL that I could get to calibrate but it work for a short period once I adjusted sub trims to keep it from spinning the motor in reverse. Now it lights up and the led's act like it is functioning normal but there is power going in and with a volt meter nothing coming out of the motor outputs. My other BR-XL works like a champ though.
09-06-2010, 11:01 AM | #459 |
Quarry Creeper Join Date: Nov 2009 Location: Kaplan
Ordered one of these for my XR10 |
09-07-2010, 04:38 PM | #460 |
RCC Addict Join Date: Dec 2005 Location: Tucson
Is it ok to run 2 esc with the reds wire connected and no external bec. will it up the amps? Will it work fine or should i just use a External bec to be safe?
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/holmes-hobbies/200916-torquemaster-br-xl-big-brushed-power.html | ||||
HH TorqueMaster BR-XL new bad boy esc! | This thread | Refback | 10-04-2011 03:37 PM |
