12-08-2012, 08:11 AM | #1121 |
Newbie Join Date: Oct 2012 Location: philippines
Anyone having issues such as loosing full throttle during hard turns and gaining it back when you let go of the steering? Am I missing something? Thanks! |
12-17-2012, 09:06 PM | #1122 |
Newbie Join Date: Sep 2012 Location: Newfoundland
| Re: TorqueMaster BR-XL Big Brushed Power!
I want to order the TorqueMaster BR-XL. Can it be wired to handle dual motors?
01-08-2013, 05:12 AM | #1123 |
Quarry Creeper Join Date: Feb 2009 Location: The work bench
| Re: TorqueMaster BR-XL Big Brushed Power! When wiring this unit up I still need to install the battery wires right, and does the positive (red) and negative (black) wires go into the same sides as the two motor wires that are already installed? And can you use the castle feild card to program this?
01-08-2013, 07:29 AM | #1124 |
The red and black wires are the battery leads, you need to install the battery plug. The through holes are the motor power. You can only use the field card when hooked to a computer like a normal Castle Link.
01-08-2013, 09:29 AM | #1125 |
Boy I was all kinds of confused! Thanks for the info!
01-14-2013, 04:47 PM | #1126 |
Quarry Creeper Join Date: Mar 2006 Location: Australia
Do you have a projected date on the new mini esc?
01-14-2013, 07:48 PM | #1127 |
alittle something different. Tamiya VDF 2 drifter with BR-XL and HH 27T 540 Sport. big thanks to John for all the motor help and building a killer motor for my needs |
02-02-2013, 08:05 PM | #1128 |
Quarry Creeper Join Date: Oct 2009 Location: melbourne, australia
hi guys ive just hooked up my new brxl and there seems to be a problem. im getting no power to the motor. all lights flash as they should and my servo works fine that is connected to brxl. ive tested the motor and it works fine when not connected to brxl. anything i can try before sending it back for you guys to look at?
02-02-2013, 08:36 PM | #1129 |
Are you getting any arm boot tones from the motor? When your throttle is at neutral, are all lights off on ESC? Is forward green and reverse red?
02-03-2013, 03:33 AM | #1130 |
double checked it and all the lights are correct. its also driving now which it wasnt before except now the motor it doesnt run very smooth.
02-03-2013, 07:42 AM | #1131 |
Brush hanging, something in the motor?
02-03-2013, 11:37 PM | #1132 |
tried two different motors and got the same result with both
02-05-2013, 11:07 PM | #1133 |
now when i plug it in im getting the green lighting flashing really quickly and its not driving again.
02-06-2013, 12:50 PM | #1134 |
Try to reflash the ESC firmware, otherwise send it in and we can check it out.
02-09-2013, 05:57 PM | #1135 |
Pebble Pounder Join Date: Jan 2013 Location: Seattle
Hi John, Could you take a look at my problem? I think I killed my HH TorqueMaster BR-XL I'm also going to submit a message via your website, since I'm not sure which is the proper way. Thanks! |
02-11-2013, 06:26 PM | #1136 |
Rock Crawler Join Date: Sep 2012 Location: Pasadena
John i have a question on waterproofing, can you do a mmp if I send the sensor cable and the fan plugged in?
02-12-2013, 08:20 AM | #1137 |
I can. The sensor cable would be plugged in with dialectric grease, and I highly recommend getting rid of the fan if you plan to run in water. If the WP job is just for resistance to water, fan is OK.
02-12-2013, 02:41 PM | #1138 |
Yes sir for water resistance. And how about a sensored motors?
02-12-2013, 04:58 PM | #1139 |
No problems with that either. Even if the can is swiss cheese we can at least protect the components and keep it running solid under water.
02-12-2013, 05:09 PM | #1140 |
How much for both items? Is it $10 each and i'm sending in my cobalt puller 500 for a rebuild too
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/holmes-hobbies/200916-torquemaster-br-xl-big-brushed-power.html | ||||
HH TorqueMaster BR-XL new bad boy esc! | This thread | Refback | 10-04-2011 03:37 PM |
