02-12-2013, 06:18 PM | #1141 |
Newbie Join Date: Feb 2013 Location: Grande Cache AB
| Re: TorqueMaster BR-XL Big Brushed Power!
hey john im looking at purschasing the Brxl esc im going to be running a dual motor set up with 2 Tekin 35t heavy duties the 6s lipo is that just for the esc or will the motors handle power that high? also if im running a hitech HS5646 wp steering servo will i need to run an external bec any input would be greatly appreciated thanks nick |
02-12-2013, 06:31 PM | #1142 | |
Rock Crawler Join Date: Sep 2012 Location: Pasadena
02-12-2013, 06:40 PM | #1143 |
| Re: TorqueMaster BR-XL Big Brushed Power! |
02-12-2013, 07:13 PM | #1144 |
I personly run zippy flight max's or turnigy from http://hobbyking.com/hobbyking/store/index.asp here
02-12-2013, 07:36 PM | #1145 |
Rock Crawler Join Date: Nov 2012 Location: Charlotte
Well looks like ill be sending some items your way soon JRH. I've got a MMP and Tekin 13.5 which could use your WP services.
02-15-2013, 12:45 PM | #1146 |
Rock Crawler Join Date: Jun 2008 Location: Clinton,Michigan
hey john do the waterproof br-xl's still look like this (minus bullet connectors of course). or are they being waterproofed and then plastic case installed over top. |
02-15-2013, 01:05 PM | #1147 |
They are now epoxied inside the black case. It is lighter and easier this way.
02-15-2013, 01:12 PM | #1148 |
thank you ! I just picked one up from a guy who runs a hobbyshop and he said it was not the waterproof version. so it came today and the heatsnik has some clear glossiness to it and the board seems pretty shiny from what i can see thru the case. is the waterproof coating super thin on these things now. I would have not had a thought about it being waterproof but when i saw the clear stuff on edges of heatsink it made me wonder if it is waterproofed already. sorry can't seem to get a good pic of it Last edited by discgolferlee; 02-15-2013 at 01:30 PM. |
02-15-2013, 03:57 PM | #1149 |
easiest to look at the leds. Conformal coating of the regular units can also get on the heatsinks.
02-15-2013, 04:08 PM | #1150 |
02-16-2013, 11:28 AM | #1151 |
An updated mini design has just been finished and will start production right away. The first batch will be small to ensure there are no problems with production, then we will start regular production volumes. New specs: 1.1x1.1x0.138" (28x28x3.5mm) ESC size, no wires 0.315" (8mm) diameter capacitor 1 amp BEC for internal power or RX power only 1.2mOhm ON resistance (same as big brother) slim RX wire Stackable design Future tweaks to the BRXL line include an enhanced throttle mode with active motor speed modulation. It will put an end to rollaways and LOCK motor speed into the range you specify. Even rolling downhill, if you give 1% throttle the motor will not be able to coast faster with Active Modulation enabled. |
02-16-2013, 11:40 AM | #1152 |
Wow I like. Good choice on the low amp bec as well.
02-16-2013, 10:52 PM | #1153 |
02-17-2013, 01:13 AM | #1154 |
It depends on the situation. Conformal coating, electronic safe silicon (non acidic outgassing), and epoxy potting are the three main types we use. For the SW and AE you will have the easiest time with a conformal coat applied on in 3 to 4 layers. It is one part, dries via air, and can be brush applied. A google search shows up many options for purchase. We use Dow Corning, Henkel, and 3M products on the majority.
02-17-2013, 06:12 AM | #1155 |
How do you do it fill up a small small container and dip it in it, or what?
02-17-2013, 09:07 AM | #1156 | |
Rock Crawler Join Date: May 2011 Location: SoCal
| Re: TorqueMaster BR-XL Big Brushed Power! Quote:
Has this been done before? | |
02-18-2013, 07:04 AM | #1157 | |
I don't have an exact timeline for the addition, it is the next engineering task. The method I will be using for motor control has not been used in RC before, and rightfully so because it depresses the motor speed at low RPM and makes the throttle more sensitive. Great for competitive rock crawling and robotics, horrible for racing. | |
02-25-2013, 02:27 AM | #1158 |
Newbie Join Date: Feb 2013 Location: Okinawa
Sorry i have a question, but there's a lot of posts to check for an answer ( And I'm a Newbie ) I want to run two Holmes Hobbies TorqueMaster BR-XL ESC's. Do i need a cut off For LiPo's?? If so any recommendations (Please)
02-25-2013, 07:16 AM | #1159 | |
comes with auto lipo cut-off. why do you want to run 2 of them? from the website... and welcome to the hobby! "The TorqueMaster BR-XL is a new ESC for crawlers, robotics, and off road trucks. It has been designed from scratch to meet the rigorous demands of low speed control and high speed power. 5 amp 6 volt on board switchmode BEC delivers unbelievable servo power at any input voltage. Huge 80 amp continuous rating. Most impressive is the 6s lipo maximum input voltage, giving even the most power hungry drivers what they want. Comes stock with Auto lipo LVC, Full drag brake, instant reverse, and 100% reverse throttle settings. 1 year warranty Water resistant design 2s to 6s lipo input onboard 6v 5a switchmode BEC 50x39x21mm 45.6 grams (with battery and motor wires) Brushed only 80a continuous, no single 540 motor limit Stick and Castle Link programming compatible Reverse and brake adjustment Regenerative Drag Brake Active Hold Brake (The Holmes Hold!) Quiet mode Dual motor crawlers, go fast racers, wheel speed trail junkies, pullin mofo's, robot builders, and any brushed fanatic will love it!" | |
02-25-2013, 07:20 AM | #1160 | |
is this purely a software change or will this only be available on a newer version of the esc with hardware needing to be changed. In other words will past br-xl owners simply be able to upgrade firmware? thanks and sounds like an awesome awesome tool to have in the crawling belt | |
LinkBacks (?)
LinkBack to this Thread: http://www.rccrawler.com/forum/holmes-hobbies/200916-torquemaster-br-xl-big-brushed-power.html | ||||
HH TorqueMaster BR-XL new bad boy esc! | This thread | Refback | 10-04-2011 03:37 PM |
