Go Back   RCCrawler Forums > Vendors > Holmes Hobbies
Thread: TorqueMaster BR Mini Packs the Power!
Old 11-07-2013, 04:22 PM   #181
Default Re: TorqueMaster BR Mini Packs the Power!
Just a thought. How will programming work on these stacked babies. Are you able to program both at once or separately?
Tossedman is offline   Reply With Quote
Old 11-07-2013, 05:41 PM   #182
Originally Posted by saniel68 View Post
I turned off my LVC on now mine works flawlessly.
I just use my timer on my radio to keep track of run times. Usually two 7 min comp practice scenarios with no worries.
Good to hear... what batteries are you using?
tapped-out is offline   Reply With Quote
Old 11-07-2013, 05:47 PM   #183
E-Flight 450 mAh 30C packs and **** 450mAh punch packs with deans micro connectors. Stock 16 G wire. The CKRC are basically rebranded Gens Ace batteries.
saniel68 is offline   Reply With Quote
Old 11-07-2013, 08:58 PM   #184
I'm kinda scared of turning off the LVC because of lipo catching fire.
Old 11-07-2013, 09:00 PM   #185
Program them separately using castle link.
Old 11-07-2013, 10:50 PM   #186
Alright I hooked up my br-minis to my computer via castle link to lower LVC. I see there's a firmware update original firmware is 1.10 update is 1.11.
not sure if I missed the info on this what changes have been made in new firmware?
Old 11-07-2013, 11:12 PM   #187
E.Y. Designs
Can you solder some connectors on before you ship for a little extra? I don't have my soldering iron right now and I'm thinking of picking up a pair of stacked ones...
EverettY is offline   Reply With Quote
Old 11-08-2013, 08:07 AM   #188
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
It fixes the issue with Hold mode. it is a good update!
Sure can, we will add that as options to the stacked ones.
Didn't get the stackers added to the site yet, I got pretty sick yesterday and had to go home early. Its on the agenda for today.
JohnRobHolmes is offline   Reply With Quote
Old 11-08-2013, 08:36 AM   #189
Glad to hear that, I'll be ordering mine soon.
Jslick is offline   Reply With Quote
Old 11-08-2013, 10:02 AM   #190
Me too.
Old 11-08-2013, 10:55 AM   #191
Dual ESCs on the site and available for purchase, waiting to get pics finished. We are giving a two week lead time for building on the site, but are starting the construction right now so first come first shipped.
Holmes Hobbies LLC
Old 11-08-2013, 11:29 AM   #192
Excellent! Order placed. Now where are those Bully 2 axles?
Old 11-08-2013, 01:48 PM   #193
John...care to elaborate on the "Regenerative Drag Brake"?
ittybitty is offline   Reply With Quote
Old 11-08-2013, 02:09 PM   #194
Just normal drag brake like most other ESCs, it charges the battery during drag. This is why bigger batteries allow for better drag, they have lower resistance.
Old 11-08-2013, 11:17 PM   #195
Holmes Hobbies LLC
I placed my order fonight. I also ordered 2 Crawlmaster Pro this morning.
Quiel is offline   Reply With Quote
Old 11-09-2013, 01:58 PM   #196
Ty
Is there a way to get longer wires for supers? Thanks Ty.
Ty is offline   Reply With Quote
Old 11-10-2013, 06:30 PM   #197
Is 10ga to big? Do alot of G6 type driving. 2S alota C 35t T M pro HH.
yjbrad is offline   Reply With Quote
Old 11-10-2013, 09:13 PM   #198
Originally Posted by Stick Crawles View Post
I'm using max amps 430mAh 100c, and still have the issue using 16ga wires, I'll try reducing the cut off voltage or turning it off and see if that works.
Well I updated the br minis and turned the lvc off on both escs and still having the cut out issue, starting to loose faith in these little things...........
Stick Crawles is offline   Reply With Quote
Old 11-10-2013, 09:27 PM   #199
I'll turn mine off tomorrow and test it out... I think the answer is going to be 40c-90c burst 800mah lipos.
Old 11-10-2013, 09:31 PM   #200
Finally got mine soldered and installed into my sporty. Worked flawlessly! Never got above 100f. Can't wait to get some for the pro
Hittman is offline   Reply With Quote
Tags
bad ass
TorqueMaster BR Mini Packs the Power! - Similar Threads
TorqueMaster BR-XL Big Brushed Power! JohnRobHolmes Holmes Hobbies 1351 05-13-2020 03:52 PM
Mini torquemaster ???? Mrblue Losi Mini-Rock Crawler 80 05-01-2010 08:59 PM
You may edit your posts
