![]() | #101 | ||
| ![]() Quote:
![]() | #102 |
Quarry Creeper Join Date: Jan 2010 Location: Clover
It's my first set of HH esc's, can we enable Holmes Hold on these mini or should we wait for a firmware update? Sorry if this question has allready been asked but I didn't found an answer Thanks ![]() |
![]() | #103 | |
| ![]() Quote:
You really shouldn't need the Hold turned on in any of your rigs Francis. I'm running them stock in all of my rigs and haven't had any problem with them rolling when I didn't want them to. When we were running 5lb + rigs the Hold was really beneficial, but these days it's not so necessary for the comp rigs. | |
![]() | #104 |
Quarry Creeper Join Date: Jul 2008 Location: Reno
Ity, when you say your running your stock, do you mean you didn't program any of the paramiters? Just got mine and haven't tinkered with them yey. Also my first HH esc's. Thanks
![]() | #105 |
Thanks Ryan for the answer ![]() As I'm new to HH esc I wanna test this new feature but I won't. |
![]() | #106 | |
| ![]() Quote:
![]() At this point I have them in my 2.2 Berg, 2.2 XR, 2.2 Shafty, and have a set for my Super Berg also. The Super will probably get the Hold turned on, but I will turn the Brake Amount down to something like 60% so they don't lock up as hard, but those 8" tires need the extra braking. | |
![]() | #107 |
That's great. thanks again ![]() |
![]() | #108 | |
owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
| ![]() Quote:
You will need to wait until firmware 1.10 comes out. On the mini it didn't port properly, so Holmes Hold does the opposite and moves the rig ![]() | |
![]() | #109 |
I wanna be Dave Join Date: Dec 2006 Location: here
The answer to post below is I have some bad batteries. So I noticed with my Br-minis When I go forward and reverse with the throttle as if you are trying to flip the rig back over on it's wheels. I lose power ... esc's shuts off. esc's are not hot @ all. any ideas ? I can also get the Rig to do this while holding it. Moving triger on remote forward & reverse. More info I have both red esc wires going into the RX. My bec powers sevo only.. esc's power the rx.. I've tried 3 different batteries. Last edited by tapped-out; 10-09-2013 at 10:45 PM. |
![]() | #110 |
99% guess- your battery or battery side wires are too small, or the packs won't handle the motor. Did you try turning off the lvc?
![]() | #111 | |
| ![]() Quote:
![]() | #112 | |
| ![]() Quote:
Thanks for the help. Thanks.. Last edited by tapped-out; 10-09-2013 at 10:42 PM. | |
![]() | #113 | |
| ![]() Quote:
![]() | #114 |
AND...are you balancing the batteries?
![]() | #115 |
I edited my post... looks like bad batteries. Thanks guys. Yes my charger balances my batteries every time. Last edited by tapped-out; 10-09-2013 at 11:24 PM. |
![]() | #116 |
Rock Crawler Join Date: May 2011 Location: SoCal
Do you suppose they've actually gone bad, or were they marginal on current delivery to begin with? IE small mah and low-ish C-rating.
![]() | #117 |
![]() | #118 | |
| ![]() Quote:
I tried 3 Gens Ace 450 25c 3s with all 3 batteries esc's would cutoff. I thought maybe the Gen Aces batteries brand just aren't powerful enough for the br minis. So I tried 1 Cheap battery pack Elite 450 black label With same results.. esc's cutting off. After reading the post from John,ittibitty & winnerone I tried 1 more Gen Aces 450 pack. Rig is running perfect. My bad batteries all cells have good voltage. Idk. I'll be testing all my batteries in the rig today. | |
![]() | #119 |
Interesting. The Gens Ace 450's are fine...but you must have gotten a couple "bad ones". I run the same packs in all of my 2.2 rigs...I think I've got around 22 of them at this point ![]() |
![]() | #120 |
Tags |
bad ass |
TorqueMaster BR-XL Big Brushed Power! | JohnRobHolmes | Holmes Hobbies | 1351 | 05-13-2020 03:52 PM |
Mini torquemaster ???? | Mrblue | Losi Mini-Rock Crawler | 80 | 05-01-2010 08:59 PM |
