![]() | #81 |
Rock Crawler ![]() Join Date: Aug 2015 Location: Big Island
John - I think you meant the stock Bomber is the same as the Yeti - with the transfer case and all. From the respective manuals: ![]() But nonetheless, that is a great explanation of the tangible differences in KV, thanks ![]() Last edited by mikebecher; 12-17-2015 at 12:29 PM. Reason: cause I wanted to |
![]() | #82 |
owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
The final ratio is the same from wraith to Bomber (as I understood reading through the manual), but the transmissions have different internal ratios to get there. The chart you posted has diff x internal ratio, and multiply that by spur/pinion to get final.
![]() | #83 |
Ah, I found the discrepancy - I was using Wraith Spawn ratios which differ from the original Wraith (32p vs 48p). So John is right (of course!) the Bomber and Wraith (non-Spawn) ARE essentially the same ratio... Bomber: 64/12 x 5.67 = 30.22 Yeti: 64/16 x 5.67 = 22.67 Spawn: 56/12 x 7.60 = 35.47 Wraith: 80/20 x 7.60 = 30.40 And I found another typo the Spawn manual ![]() |
![]() | #84 |
I wanna be Dave ![]() Join Date: May 2015 Location: Moving
So it looks like I need to drop pinion to a 10 tooth. I can't go any bigger on the spur without removing the shroud and I'm underdriven in the rear axle so not much else I can do. Even if I geared everything as low as possible with what's available the 3500 would still be way too fast. That's why I went with the 2200 this time. I feel like I'm missing something. I try to follow all the rules and I end up with a warmer motor that cogs. Lol. Somebody should take my toys away before I hurt myself.
![]() | #85 |
Add a little punch control, and medium startup. Not every situation can take full voltage surges without issue. The first choice is for your intended wheelspeed, utility is most important of all. Even with a little more motor heat, if the system works then you have found what you need! If 2200kv wasn't usedul I wouldn't have made it a choice.
![]() | #86 |
Thanks again John. I am very happy with this motor and its performance. I'm going to make the changes you suggested tonight and I'll post up my test results which I'm sure will be positive.
![]() | #87 |
Ok so I added 20% punch control and went from high to medium startup power. I then set my throttle endpoint back to 100% forward and laid into it. Zero cogging, zero hesitation, no more noise, and after a good 30 minute test I'm sure she's running cooler as well. Thanks John for the help and education. I'm ecstatic at the way she runs now. More wheel speed than I'll ever need or use and even better low speed control compared to my 3500 which was already awesome just a little high strung for my purpose. Overall, I know I made the right choice switching to a lower kv for this build and am completely happy with the outcome. Curious to see now what my run times look like. I get to find that out tomorrow. I'm psyched.
![]() | #88 |
That's awesome!
![]() | #89 | |
Rock Crawler Join Date: Dec 2015 Location: Charlotte, NC
| ![]() Quote:
With that said, I have read through all of these posts and from what it sounds like, I would like to run my wraith similar to how you are Screamer. Good technical crawler and not too speedy. However, I don't really have anything to compare too when folks talk about "too fast" or "slow enough for crawling". Screamer, any chance you could post some videos of your rig at full speed and crawling with the 2200kv in it? What gearing did you end up with? Thanks! | |
![]() | #90 | |
Quarry Creeper Join Date: May 2011 Location: Battle Ground WA
| ![]() Quote:
Crawling wise, you can watch mine (the blue one) crawl in this video, you can see it's perfectly crawlable. https://www.youtube.com/watch?v=jwEzXBVWtUw | |
![]() | #91 | |
| ![]() Quote:
I am curious what Screamers top speed is with his 2200. | |
![]() | #92 | |
I wanna be Dave Join Date: Sep 2012 Location: Victoria, BC
| ![]() Quote:
![]() | #93 | |
| ![]() Quote:
Here's the vid. Driveway's a bit frosty. https://www.youtube.com/watch?v=1Ufj...ature=youtu.be Last edited by HahnsB2; 12-31-2015 at 01:39 PM. | |
![]() | #94 |
Newbie Join Date: Dec 2015 Location: USA
hahns, your videos convinced me on the 3500 vs the 3300 stubby! I have a 3s pack and will try gearing it as low as possible. I just placed roughly 6 orders for the 3500 and BLE pro... none of them have went through. My VW dirty diesel gift card is paying for this upgrade and doesn't seem to like paypal that much! Looks like I will have to wait until Monday to get my order in. |
![]() | #95 |
RCC Addict ![]() Join Date: Jul 2008 Location: Fox Valley WI
I ordered the same combo for an AR60 axled monster truck build with the Proline Destroyer tires on Clod wheels......judging by your video it's going to be insane!
![]() | #96 |
Sorry for the delayed response, hopefully this info is still helpful. I only run 3S batteries on everything I own and on the bomber specifically I am geared 13/64 and on 3S top speed is right at 17mph. This goes back to what I was saying before about how motors are feeling quicker on the bomber than they are on similarly geared Wraiths. I'm not arguing that the Wraith and Bomber have similar final gear reduction but for whatever reason, the same KV motor feels faster to me and others on the Bomber. My friends are running 3500kv Holmes motors that would have blown the doors off of my Wraith with a 3500 in it and 12/56 gearing. With the 2200 i did pick up more noticeable low speed control and it's now starting to look like longer battery life. Edit: After watching Hahns second video again I can confidently say my 2200kv Puller Pro standard is AT LEAST as fast as his. I really couldn't believ it myself the first time I pulled the trigger. I was sure I installed the wrong kv motor. Last edited by SCREAMER; 01-01-2016 at 09:15 PM. |
![]() | #97 | |
| ![]() Quote:
![]() | #98 |
I was going to say, on stock gearing the wraith on 3500kv and 3s is much faster than hahns video. I've been running the stock gearing for purposes of torture and startup testing.
![]() | #99 |
Newbie ![]() Join Date: May 2009 Location: mesa
ok so i have a yeti pick up a tekin rx8 esc now i'm sure what motor to run , do i run the tekin pro 4 hd 3000 kv ? . or the holmes hobbies puller pro bl 540 xl 3500v .some in put will be great .i will mostly running 2 s and 3s |
![]() | #100 | |
| ![]() Quote:
Holmes Hobbies 2 pole vs 4 pole brushless | CoolRunning | Electronics | 1 | 02-13-2017 08:32 AM |
