![]() | #61 |
owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
That sounds like a great place to start for 3s lipo use.
![]() | #62 |
Newbie Join Date: Jan 2008 Location: Petaluma
Thanks!I will be ordering later today.
![]() | #63 |
I wanna be Dave ![]() Join Date: Mar 2007 Location: roland,ar
got mine in, this thing is small!! i love it! |
![]() | #64 |
Newbie Join Date: Jan 2008 Location: Fort Wayne
How much would i be limiting this motor going with a 1600 8 cell vs a 3s lipo. What capacity and discharge rate should I get in a 3s?
![]() | #65 |
I would recommend a 2100 15C pack for the average user who may be thrashing hard. You can get away with as little as a 1500 15C pack. You won't be limiting it much, but the wheelspeed and punch won't be as strong.
![]() | #66 |
Pebble Pounder Join Date: Feb 2008 Location: Bala Cynwyd
Do I need to upgrade to the Outrunner motor plate for the Axila kit or has that been upgraded since the "Live build"?
![]() | #67 | |
Rock Crawler Join Date: Sep 2005 Location: IDK
| ![]() Quote:
The revolver black has the same bot pattern as normal brushed 540 can motors ![]() Bolt on ![]() | |
![]() | #68 |
Newbie Join Date: Jul 2008 Location: Orange County
I am totally new to crawling (I don't even have a crawler yet) but not new to brushless. I was thinking of an axial AX10 with the revolver motor and sidewinder esc. Will I be happy with the power from the revolver or would you recommend the crawlmaster? The regular crawlmaster seems a little better built and is only $10 more (out of stock though). What gearing should I use for this? Using the speed calculator it looks like with the stock 87t spur it would take a 25 tooth pinion to hit 6 mph with a 3s lipo. Does that sound about correct?
![]() | #69 |
I would use the Revolver, and use a 12t pinion. The Crawlmaster has a bit more power, but it is hard to get proper gearing on an AX10 without some dremel work sometimes. 6mph on 3s lipo, you shouldn't need such a large pinion. If you plan on competing, you may want to use a brushed motor first. If you plan on just having fun and tooling around an outrunner is a good choice for worry free running. |
![]() | #70 |
I'm not planning on any competition at all I am just looking for a change of pace and something to play with in situations where I cannot use something like an E-Maxx or an electric converted Losi 8ight-t. I got the gearing info using a speed calculator from RCMonster.com but I am sure I got my numbers mixed up. Right now I have a 2100mah lipo and 2 -5000mah lipos both are only 2s though, for the short term would they be good to use? Also with the 8 cell 1500mah saddle packs you have how much run time can I expect? Thanks! |
![]() | #71 |
Pebble Pounder Join Date: Jul 2008 Location: Australia
![]() | #72 |
Rock Crawler Join Date: Jun 2007 Location: Great Britain
So I just got one of these from a mate and want know what pinion to use. I'm running a 3s1p 2000Mah LiPo and an R2D on a Mamba Max.
![]() | #73 |
Quarry Creeper Join Date: Dec 2006 Location: Dirty Jerzee
Just sent payment for a black revolver.
![]() | #74 |
Just got a small batch of special run motors in. These are slightly longer and heavier, with 25% more torque than the original motors. I kept getting bugged to have some on hand, so here you guys go! http://holmeshobbies.com/product.php...7&cat=0&page=1 They are still sensorless, but make great motors for when you don't want to mess with any maintenance. Same price as original! Last edited by JohnRobHolmes; 04-06-2010 at 03:29 PM. |
![]() | #75 |
RCC Addict Join Date: Feb 2008 Location: Crawlerado
Awesome! Was just thinking I'd like to have the original version for my tlt. Guess its time to go to the bank ![]() |
![]() | #76 |
I am fishing around for a motor for my GMade R1 and found this Revolver. Buggy here. Shane's GMade R1 Rock Buggy Build I am not familiar with these types of motors. What turn or kv do they rate at? Also, would this motor work on a Tekin Fx-R? I am going for a higher speed crawler/basher. Probably 30% crawl, 70% heavy throttling. Right now I am running a 35T with a 12t pinion (R1 stocker) on 11.1v and it is about 40:1, I believe. Or if you have a recommended motor/esc combo, do tell. The HH larger 540 motors will not fit in the chassis, the endbell hits part of the chassis, so it needs to be a smaller motor. Thanks for any help. |
![]() | #77 |
It is a brushless motor, so you will need a brushless ESC like a mamba or sidewinder. One ESC per motor is needed. The KV is right at 1100, so it will be slower than your 35t motor. I think this would work very well for you if you use 4s lipo or gear it a bit faster than what you have now. You can gear it pretty high, it has a lot of torque. The only downside is that since it is non-sensored the low speed control isn't the best. Since you will be mostly heavy throttle, that shouldn't be a huge deal. |
![]() | #78 |
Great. Thanks for the information.
![]() | #79 |
Newbie Join Date: Mar 2010 Location: Colo Springs
First of thanks to Holmes for the great price and fast shipping on the out-runner I got my revolver this week and hooked it up to my SCX10 with a Quark 65A Roadster ESC using the stock pinion. I am running this motor using a 4S LiPo and it is working GREAT ![]() Since it is running so well (and cool) with a 4S can I try stepping upto a 5S for even more wheel speed? Thanks! -Ryan |
![]() | #80 |
It is a big jump, but if you are very diligent about watching the heat amounts on the motor give it a shot. Hysteresis losses in the stator will start to rear their ugly head at high speeds, so don't be surprised if your cool motors becomes cooking hot in a matter of minutes. I haven't gone over 4s, so you are in unknown territory.
