Go Back   RCCrawler Forums > Vendors > Holmes Hobbies
Thread: HH Cobalt Puller- Reborn page 35!
Old 06-11-2008, 09:49 PM   #321
Default Still Available?
JRH,
I see that there is ONE Cobalt Puller available on the website, but it still says preorder. Is this still available in-stock or is it for your next batch? The reason I am asking is that it says shipped June 4th and I am interested in making the purchase.
Let me know,
Thanks.
TJAugie is offline   Reply With Quote
Old 06-11-2008, 11:17 PM   #322
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
If there is one on there right now, it is available right now. Removed preorder from title.
JohnRobHolmes is offline   Reply With Quote
Old 06-11-2008, 11:50 PM   #323
Originally Posted by Deezul View Post
as far as motor guard. where to buy?
Only build them because clods put the motors so low to the ground, and I just made a mine from thin sheet of Aluminium.
I thought about just cutting up a soda can
Got my truck drive worthy and, JRH my god these are powerful motors.
They proved to much on 11.1 volts for my raptor2s so I dropped down to 7.4 and they still kick ass.
Crawling up my couch and the truck started pushing the couch and I was sitting on it.
Oh and I have one question about temp. Do I take it at the housing or the rotor and brushes? it runs about 110 at the housing and about 140 inside.
Speedyboy is offline   Reply With Quote
Old 06-12-2008, 12:53 PM   #324
On the housing is where I temp at. The brushes get up to 180f pretty easy, just try and keep the housing under 160f.
Old 06-13-2008, 08:54 PM   #325
just dropped in an FXR Pro and bumped to 8 cells..........20P 86T Spur......serious wheelspeed now..........enough to break stuff. I blew out a lower link rod end. Got aluminum now ...glad I didn't go brushless.
Deezul is offline   Reply With Quote
Old 06-15-2008, 09:35 PM   #326
when will you have some 7t in stock? Like to get one for the ax10 rtr
hummer6504x4 is offline   Reply With Quote
Old 06-17-2008, 02:48 PM   #327
i too am wandering about heat. i have a 3 cell lipo and my motor got HOT! should i put a fan over it or something?:-( i don't want to ruin this motor
crawler4lif3 is offline   Reply With Quote
Old 06-19-2008, 08:34 AM   #328
Should post up the next batch this afternoon, they will be back in hand within a week or so.
You can put a fan over it if you wish. I recommend keeping the can under 160f, which is hot enough to burn your hand. Do you have a temp gun to check it with?
Old 06-20-2008, 04:37 AM   #329
I got a 7T puller last week. It's a great motor but is my rooster crawler ESC with a 6-cell NIMH limiting the power output? How many amps can this motor draw at full load?
kj385 is offline   Reply With Quote
Old 06-20-2008, 10:35 AM   #330
throw 8 cells at it ........woke mine right up. Running an FXR though
Old 06-20-2008, 10:59 AM   #331
7 or 8 cells would wake it up. The rooster crawler will limit the power just because of the voltage limits. You could advance the timing a few degrees for a bit more power, and I know guys have run the rooster on 8 cells before.
Amps at full load- breakage of tlt diffs occur around 30 to 35 amps. If your rig is stronger you could pull about 80 if you really wanted to. Your batteries and driveline will limit the amp draw more than the motor will.
Old 06-20-2008, 11:26 AM   #332
Hey JRH, How would you go about advancing the timing ?
toytech93 is offline   Reply With Quote
Old 06-20-2008, 11:30 AM   #333
Loosen the two screws on the "endbell" and rotate the aluminum part a bit. In the forward direction it will speed up, and it will become slower in reverse. You won't have to advance it more than a few millimieters in relation to the can. Any more than 7 degrees will start to heat up the motor a good bit and cause more stalling amperage with no gain in torque. Any more than 15 degrees and the brushes will start to wear fast and they will get really torn up from braking and reverse use. I time them all to zero before I ship them.
Old 06-23-2008, 03:56 PM   #334
Well , I just installed a 3 cell lipo !!! All I can say is WOW ! A crawler should not have this much wheelspeed...... I love it ! I'm glad I already installed the axial slipper, it needs it. THANKS JRH !
Old 06-24-2008, 10:53 AM   #335
Any update on the 10T when they will be back in stock? i need 4. thx
ADDICT is offline   Reply With Quote
Old 06-27-2008, 10:26 AM   #336
One more batch up for sale, should be done in about a week.
http://holmeshobbies.com/product.php...2&cat=0&page=1
Old 06-27-2008, 11:51 AM   #337
Awesome!!!
Order placed
tsaun987 is offline   Reply With Quote
Old 07-05-2008, 09:45 PM   #338
Location: ***Just a rock floating in the middle of the pacific ***
how would a 7t puller run with mamba max and 3cell lipo 11.1v 2200mah r2 trans and 13th pinion run with tlt axles....
kaotik crawler is offline   Reply With Quote
Old 07-06-2008, 07:13 AM   #339
Pretty cool really, just depends on how hard you are on the trigger and the ambient temp. Well within spec I would say- no worries.
Old 07-12-2008, 10:22 PM   #340
John, order a 7t tonight from you, question is what esc to get. In your experience what is best, mamba, sidewinder, fxr or something new?
Thanks
KenDobson is offline   Reply With Quote
HH Cobalt Puller- Reborn page 35! - Similar Threads
R1 + Cobalt Puller Highlucks G-Made Crawlers 3 05-31-2010 09:38 PM
You may edit your posts
