11-24-2008, 08:49 PM | #401 |
Rock Crawler Join Date: Aug 2008 Location: Tucson
I am curious to know if a mamba monster on A123 9.9 volts would turn two cobalts smoothly? Parallel wiring. Zero to step by step smooth. Not sure if thats a MM question or a Cobalt question. Either way, any input would be helpful.
12-05-2008, 02:18 AM | #402 |
Any info?
12-05-2008, 06:28 AM | #403 | |
Yes it would, no problem at all. Even a MM would do the job. | |
12-05-2008, 02:43 PM | #404 |
Very cool. Thanks for the info. Running 2, 7 turns would equal running 1 3.5 turn? Is that correct?
12-05-2008, 02:44 PM | #405 |
Yes, but these aren't like a normal 7t. They are about as fast as a 30t motor.
12-29-2008, 04:02 PM | #406 |
Pebble Pounder Join Date: Oct 2008 Location: Grand Junction, CO.
John, I have four 2S Lipo's that I don't really want to replace, they a rated for 24.2amps continuous. I'd Like to run the 7T. My question is this: Is there any reason I shouldn't just run 2 of the Lipo's in parallel? That should give me 48.4 amps continuous with double the capacity at 7.4 volts and I wouldn't have to replace my batteries. |
12-31-2008, 10:43 AM | #407 |
Rock Crawler Join Date: May 2004 Location: Calgary
I managed to score a NEW 5t off a forum member a while back, and I'm now debating what vehicle it will find a home in. My question, is as to how is will handle a 3S LiPo. Is this fine, or will the motor be running a bit hot? |
12-31-2008, 11:01 AM | #408 | ||
It would run hot on 3s, but for comps it is fine. Just don't go out bashing for too long without keeping an eye on the temps- keep check on it until it stabilizes and you know how hard it can be thrashed. | ||
01-01-2009, 08:56 AM | #409 |
I wanna be Dave Join Date: Jan 2006 Location: Iowa, the antirecreation state!
John will you ever get anymore 10T's in again? I really hope so Eric |
01-01-2009, 12:23 PM | #410 |
I will probably get them remade the first quarter of this year.
01-01-2009, 05:23 PM | #411 |
Great to hear John |
01-03-2009, 07:43 AM | #412 |
Newbie Join Date: Apr 2007 Location: finland
Hi ! I was going to order a 7t Cobalt Puller but they were out of stock ! I shouldn´t be so slow.. Any info when You will be getting more ? |
01-19-2009, 11:52 AM | #413 |
Pebble Pounder Join Date: Nov 2008 Location: fresno
John, rigtht now i am running a pro integy lathe 65 turn motor. i love the current speed i have with it. not a real fast kinda guy. my problem is i would like more torque. i was going to start a new thread but the forum woudnt let me. i want to know what motor you offer that will give me pretty much the same speed, around a walking speed along with monster torque. i had gotten the rig all bound up a couple of times this weekend at a comp and it didnt have enough torque to break things or to get me out of the bind. not saying i want the torque so i can brake things but i would like to have a chance to get out of binds if need be. running a sidewinder esc, 3c lipo, bec and so on. any recomendations? thanks in advance.
01-19-2009, 12:04 PM | #414 | ||
I don't have anything so slow, except another 65t motor. The puller would be more than twice as fast. I do have one 65t Torquemaster, which will give you a lot more torque with the same wheelspeed. http://holmeshobbies.com/product.php...&cat=17&page=1 | ||
01-19-2009, 12:08 PM | #415 | |
01-19-2009, 12:11 PM | #416 |
is there a way i could run the 7t and put a big big spur gear on? i really dont mind having wheel speed but i am more of a torque guy. how well does this motor run at crawling speeds?
01-19-2009, 12:28 PM | #417 |
The puller runs very well at crawling speeds. Gear it down as much as you can, maybe run 2s lipo or equivelent, and you would be just fine.
01-19-2009, 12:40 PM | #418 |
| thanks. think thats what i am going to do. much rather have torque and it seems as if this is the torque master of them all. thanks john
01-19-2009, 12:44 PM | #419 |
thanks john. any idea on when you might have some 7t in stock?
01-19-2009, 12:58 PM | #420 |
HH Cobalt Puller- Reborn page 35! - Similar Threads | ||||
R1 + Cobalt Puller | Highlucks | G-Made Crawlers | 3 | 05-31-2010 09:38 PM |
