Go Back   RCCrawler Forums > Vendors > Holmes Hobbies
Thread: HH Cobalt Puller- Reborn page 35!
Old 03-08-2010, 08:46 PM   #581
I'm curious about the 14t pullers too. I'm ready to get one this friday. If not I'll get the 10t. When will these be in stock?
BGGruff is offline   Reply With Quote
Old 03-13-2010, 07:19 AM   #582
My 14t is on its way thanks john cant wait to get it...
FRENCHBLUE72 is offline   Reply With Quote
Old 03-21-2010, 11:32 AM   #583
Is there an estimated time on the colbalt motors to be back in stock? I seen them in action and really want one or more.
RusT808 is offline   Reply With Quote
Old 03-30-2010, 09:11 AM   #584
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Looks like these motors may be done for good. I have springs and brushes here, and armatures too. I can't get any more cans to my knowledge though. Bummer, I thought I had about 50 more left. Thread locked until I find some cans or get my replacement motor done.
JohnRobHolmes is offline   Reply With Quote
Old 11-29-2010, 10:06 AM   #585
And I found some cans to tide us over for a bit.
We have 7 and 14t armatures here ready to build up complete motors. Any other requests for special winds?
Old 12-02-2010, 05:29 PM   #586
Just ordered a 14T Thanks for finding some cans
blue devil toyota is offline   Reply With Quote
Old 12-02-2010, 05:36 PM   #587
And perfect timing too. By the time these cans start to peter out I will have the 550 brushed replacement going.
Old 12-03-2010, 12:00 PM   #588
Ok, you guys worked through the 14t versions pretty fast. I won't have more of the 14t for a while unless I get more blanks. We are getting 10t and 7t arms finished right now, I should know in a few days how soon they will be done.
If you are looking to preorder some 6, 7, or 10t armatures post up and I can help you out. If you are really looking for a 14t you will have to let me know so that I can get more blanks made. Otherwise I will wait a month or two for the 14t arms.
Old 12-03-2010, 11:29 PM   #589
will the 10t ones hold up too a 4 cell battery? I have a couple 7 turns but I want to run 4+ cells which do you suggest?
dominator1 is offline   Reply With Quote
Old 12-04-2010, 09:40 AM   #590
Yes, the 10t will hold up to 4s. It wears it out a bit faster of course.
Old 12-08-2010, 01:07 PM   #591
John,
Got my puller today. I ordered a 14T, but the sticker on the can says 7T. I won't mind if it is a 7T, but need to know before I hook 6s to it.
Thanks,
Bernie
order #5871
Old 12-08-2010, 01:21 PM   #592
Its a 14t, I forgot to fix the sticker.
Old 12-08-2010, 05:24 PM   #593
Old 12-08-2010, 09:45 PM   #594
BR-XL+14T puller+ 6s=OMG
John Thanks for such a great combo.
Old 12-08-2010, 10:59 PM   #595
I have this setup but I've been way to afraid to run it. How's the heat situation? Any suggestions on gearing, what setup you're running ect?
Thanks in advance.
Highmark is offline   Reply With Quote
Old 12-09-2010, 07:10 AM   #596
Thanks in advance.
I have not really crawled it yet. I just got it going lst night. I'm going crawling later today, so I'll post up later on how it works along with the rig specs.
Old 12-13-2010, 06:49 PM   #597
hey john i wanted to get a 7turn armiture.
JOYSTICK is offline   Reply With Quote
Old 12-20-2010, 02:10 PM   #598
Hi John,think I already talked to you already about this but with my 1/10th scale 8x8 HEMTT that will have a lift crane to put smaller trail rigs in the back,I have a 7t puller hooked up to the RC4WD super duty R2 tranny.Is the 7 turn going to give me enough power to haul my rig up different inclines without looking like its going to stall out?I haven't figured out the gearing yet though.
kuatto is offline   Reply With Quote
Old 12-20-2010, 04:00 PM   #599
Thanks in advance.
Sorry for the late update.
So here is my rig
Axial Honcho (base)
13"wb
2.2 flat irons
Stock ring and pinion
Stock spur gear
running 6s with a 19t pinion the motor would get warm/hot after about 15 min of crawling
I picked up a 5s battery and with the same set up crawled for around an hour and the motor was just slightly warm.
Overall I'm really happy with the torque and control with this combo. Now I just need to squeeze a little more wheel speed out of it. I'm going to try to play with 5s larger pinion, and 6s smaller pinion. Any input would be great.
Old 12-20-2010, 04:57 PM   #600
Hey John,
Got my 14t puller today.. What size pinion does it take? I pulled the one off of my 25t torquemaster hand wound and the shaft is bigger diameter on the puller..
jkwrangler08 is offline   Reply With Quote
HH Cobalt Puller- Reborn page 35! - Similar Threads
R1 + Cobalt Puller Highlucks G-Made Crawlers 3 05-31-2010 09:38 PM
You may edit your posts
