Go Back   RCCrawler Forums > Vendors > Holmes Hobbies
Thread: HH Cobalt Puller- Reborn page 35!
Old 08-08-2012, 03:24 PM   #701
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Default Re: HH Cobalt Puller- reborn
Just got a brick of billet to start work on the next lines of Puller motors! The Puller 500, Puller 540, and Puller Stubby will be filling in the void of the old Cobalt Puller line. I've been plugging away at protos for three years now, had CAD files for two years now, and finally solved some of the issues that were hanging up the final development. It only took a few thousand dollars of mistakes, about a hundred hours of labor, 30 hours of studying and formula crunching, and a shelf full of useless motors. Easy right! I've been keeping it on the down low for a reason, I didn't want to turn this into another sensored outrunner thread!
For manufacturing speed the first few motors will have a delrin face while I tune in the magnet assembly. Now I just have to narrow down the final design between 4 magnet combinations and two layouts each. Only 8 combinations left They will all work, but the proof is in the testing and not the theory. I know the best two to start with at least.
JohnRobHolmes is offline   Reply With Quote
Old 08-08-2012, 03:38 PM   #702
Default Re: HH Cobalt Puller- Reborn page 35!
Testing I can do, understanding how and why motors work, I leave that up to you.
klabeaume is offline   Reply With Quote
Old 08-08-2012, 06:28 PM   #703
The puller stubby?! Sounds interesting
Hittman is offline   Reply With Quote
Old 08-08-2012, 07:13 PM   #704
Can't wait, hopefully you get it done by Nats so we can check it out!
Destroyer is offline   Reply With Quote
Old 08-08-2012, 08:28 PM   #705
PapaGriz Yo
Grizzly4x4's Avatar
I'll take one big power with a side of low speed control....Thanks.
Grizzly4x4 is offline   Reply With Quote
Old 08-08-2012, 08:45 PM   #706
Coming right up sir! Ding Ding!
About 3 more hours left on my machine and I'll be able to schedule the most current faceplates. I should start Saturday or Friday, best estimate.
Old 08-08-2012, 08:52 PM   #707
dezfan's Avatar
Yes!!!!!!
I need one for my scaler!
dezfan is offline   Reply With Quote
Old 08-10-2012, 12:29 AM   #708
After you get the motor going. Since your starting with a clean slate could you install 2 studs out of the can for a battery mount? OR you could mount a piece of plastic on the bottom of the motor with screws and it could be a motor protector/battery mount. Thanks Matt
SDheavymetal is offline   Reply With Quote
Old 08-10-2012, 03:11 AM   #709
REST IN ALOHA CHIP
YoUnG_vErSiOn's Avatar
yeah what he said, if its good enough for Grizzdaddy its good enough for me.
YoUnG_vErSiOn is offline   Reply With Quote
Old 08-10-2012, 05:44 AM   #710
We can certainly do a version capable of this, great idea there It will increase the motor weight to have enough stiffness to hang a battery from it, but I have one can design already strong enough for it that was gonna get a big row of cooling fins. We could make a block of that material threaded studs.
Old 08-10-2012, 05:55 AM   #711
Ya know, I've never bought a high end motor because I've always found satisfaction in the integys but these new motors might just change my mind lol
demonoid369 is offline   Reply With Quote
Old 08-11-2012, 06:33 PM   #712
Make sure you make them so you can replace the bearings
halfcab is offline   Reply With Quote
Old 08-12-2012, 07:21 AM   #713
You bet! Gotta make sure the tolerances aren't so dang tight this time!
Old 08-13-2012, 10:04 AM   #714
Checking the file structure and tolerances on the new 500. I didn't have the right thickness of Delrin so I used plexi. So far so good! I'll shoot for completing a few complete protos this week.
Old 08-13-2012, 10:44 AM   #715
PapaGriz Yo
Grizzly4x4's Avatar
Will we need 1/8" pinions, 5mm, or have the option to choose?
Old 08-13-2012, 11:42 AM   #716
The 500 and TTC versions will have 1/8" pinions on the initial design. The Pro Puller (brushless) will have either 5mm or 1/8", not even sure if a hardened 1/8" shaft would take the power without snapping.
Old 08-17-2012, 03:16 AM   #717
New pullers coming I think I might peepee on myself. I freakin loved the old pullers and have been waiting for these new ones since I cant remember now I can complete my three new rigs. Once I got my hands on some of those old pullers from a few guys that had stocked up on them in my crawler group I wont use anything else. Then they all got worn out and died and I stopped crawling for about 8 months cause I didnt have any working pullers. that just how awesome those pullers were and I am sure these new ones will be even better. I cannot wait to get some of these new ones and get back crawling with my son again.
mrhobby100 is offline   Reply With Quote
Old 08-17-2012, 07:41 PM   #718
I can't freakin wait for these to hit!
TURBOFEST is offline   Reply With Quote
Old 08-18-2012, 06:00 AM   #719
cartronicshn's Avatar
New pullers with more power and better low end, hmmm....here we go again, i am in for three pairs
cartronicshn is offline   Reply With Quote
Old 08-21-2012, 01:21 PM   #720
I love it when math shows the way
First "500" brushed proto is assembled. Flux density increase of 2.6 times over FB9 magnets. Weight loss on can vs a 540 is 1.5 ounces, HEAVY version. Two ounce overall loss will be very easy with the finalized endbell and faceplate, and likely more with the lighter version of can. With specialized armatures the detent force is LOWER than a standard TorqueMaster, so the startup will also be better.
With the flux density increase we should see a speed reduction of about 2x as well, which means our "35t" will have to be about a 17t for the same speed. That will reduce the armature resistance by half for any given speed, and reduce armature heating for a given power level by 4x. In laymans terms this means peak torque and continuous power will increase until we hit the limits of the brushes.
Now I go have lunch, balance some armatures, throw some more programs on the CNC, glue in magnets, and get ready to test the Io and Kv! I will easily be able to build a 4 ounce version that is better than a regular 540 at this point. So that means I'll be building a 3 ounce version too It won't have nearly the power of my sensored outrunners, but its gonna be hard to beat brushed until we can catch up on brushless ESCs.
HH Cobalt Puller- Reborn page 35! - Similar Threads
R1 + Cobalt Puller Highlucks G-Made Crawlers 3 05-31-2010 09:38 PM
You may edit your posts
