![]() | #821 |
I wanna be Dave Join Date: Jun 2008 Location: Sin City
![]() | #822 |
owner, Holmes Hobbies LLC ![]() Join Date: Nov 2004 Location: Volt up! Gear down!
Got confirmation that we are getting air shipment on the magnets with my fancy pants idea to make them into "motor parts". That will give us enough mags for 100 motors, so there are 65 available beyond the current wait list. If you want to be added, send an email to me. If I can get ahold of the right hardware in time we will start making V5 cans, in the mean time v4 will be produced. Besides a slight drop in weight, the big benefit to v5 cans is a 4x reduction in labor time- my in house bottleneck. Also have a new style armature coming that will allow for stronger magnets without making startup unusable. It should ship from Japan in about a week. |
![]() | #823 |
I wanna be Dave Join Date: Dec 2008 Location: ?
![]() | #824 |
Dunno. Maybe a film canister.
![]() | #825 |
RCC Addict Join Date: Jul 2006 Location: Johnston SC
Email sent bud got me interested. ![]() |
![]() | #826 |
Quarry Creeper Join Date: Sep 2008 Location: Isle of Man
![]() | #827 |
![]() | #828 |
Another set for a happy driver! Same specs as the red endbell pair. Puller 500 Flow SL 35t medium wire 10mm comm Standup Copper Brush 33EH magnets We have new parts coming to test the 500 Torque edition. It will feature slightly higher weight for better torque and drag characteristics. Startup will be more abrubt as well. |
![]() | #829 |
Can I have a set with pink pieces on the end please.... I honestly do not think I have seen a better looking motor. The whole thing just looks killer. |
![]() | #830 |
Thanks! I worked a long time to get the design balanced with lightness and strength. Here is a new armature for testing, Puller 540 Flow type. This is a 15t, wire is 16.5ga. KV is a respectable 2300, and startup is very controllable. We can fit wire more into the slot, but the end turns get too tall and hit the can before max fill. Later prototypes have shorter stacks, but startup suffers because of skew limitations. A balance will be found in time. |
![]() | #831 |
Looks like I forgot to add the pic in the last post, I'll look for it back at work tomorrow. Update on Puller 500 magnets. They were sent via boat by "accident" ![]() |
![]() | #832 |
I wanna be Dave Join Date: Jan 2004 Location: Detroit
I'm sure the wait, while tough on you and us, is going to be well worth it.
![]() | #833 |
I have some extra downtime and parts to build Puller TTC and Puller 520s, whilst we wait on magnets for the 500 series. Only a few available, get em while they are hot! Holmes Hobbies LLC Please allow 2 to 4 weeks for building time so we can ensure they are just perfect! |
![]() | #834 |
RCC Addict Join Date: Nov 2011 Location: Surrey,BC- Canada
What is the main defference in the stubby to the 500 other than weight?
![]() | #835 |
Pebble Pounder Join Date: Oct 2008 Location: mid state
Sorry but itseems a little redundent nowthat the new puller motors seem to be out? but i just aquired a 7t puller and was wondering if i can still get it serviced using the serviceplan on the HH web site. Holmes Hobbies LLC isent an email through the website several days agon and havent heard back yet. i understand you have a bussiness to run and that its probably super busy soany info from anyone would help thanks. bob |
![]() | #836 |
Quarry Creeper Join Date: May 2012 Location: My own personal Heaven
John's crew rebuilt a 7T Puller for me a few weeks ago and it came out great! I paid for a rebuild and sent my motor in and they took care of the rest. It's super easy! :Thumbsup:
![]() | #837 |
Same here but a 14t Puller a few months ago.
![]() | #838 | |
| ![]() Quote:
bob | |
![]() | #839 |
Magnets finally arrived (via boat even though I specified air) and we can begin building 500s again. I also had a spare minute and built up a proto 510 Puller. Large pankake style rotor. Equal speed and terminal resistance to a 540 motor, only 3.75 ounces ![]() To get the basic Puller 510 rotor design I worked backwards from known variables to arrive at a motor with the same speed and terminal resistance as a regular 540 motor. Whenever a motor is shortened, the resistance for specific speed goes up. So if we want 35t speed from a shorter armature, we have to give up drag brake and stall torque because of the higher resistance. Knowing this, I designed the Puller 510 to have equal terminal resistance even though the final motor is shorter and lighter. It is possible because of the larger rotor diameter and stronger magnets. First pic shows the 510 stumpy armatures in various stages of completion, and 520 stubby armatures too. 510 Puller 28mm diameter rotor EH33 neo magnets Integrated flux ring 36mm major diameter 42mm long 3.75 ounce final weight, 106 grams Last edited by JohnRobHolmes; 03-15-2013 at 03:06 PM. |
![]() | #840 |
This motor set was built for Jim Hand, owner of Hand Bros off road. Puller 500 Torque edition. Armatures were matched on inductance, resistance, and weight. Motors were matched on speed with precise commutator sizing and timing adjustment. No load of each motor was 1.1a, very respectable for the tight airgap and lower than regular KV as compared with a normal 540 build. Puller 500 Torque 262.3g, 10oz for the pair Ribbed can 35t Fat wire Torque armature, large comm Holmes Soft Copper brush Holmes XX Spring EH33 Neo Magnet This set of motors also included flux rings for torque and speed adjustment. With heavy flux rings the KV reduced to 18% lower than a regular 540, while still being a full ounce lighter and starting up smoothly. THAT is how motors should be made ![]() |
R1 + Cobalt Puller | Highlucks | G-Made Crawlers | 3 | 05-31-2010 09:38 PM |
