Go Back   RCCrawler Forums > Vendors > Holmes Hobbies
Thread: HH Cobalt Puller- Reborn page 35!
Old 11-20-2014, 05:15 PM   #961
owner, Holmes Hobbies LLC
JohnRobHolmes's Avatar
Default Re: HH Cobalt Puller- Reborn page 35!
Quiet thread, but busy sales of Puller motors! In the past 12 months we have outfitted almost 1000 puller 400s and 500s into rigs! Even though they are already a potent motor, we always strive for improvements when possible. One thing you will find on new Team Puller motors is finer adjustable timing. As shown, the endbells are now slotted for fine adjustment over 24 degrees. We have been sneaking this improved endbell into team motors for about 6 weeks now, and when the next run of endbells is made all puller models will include the feature.
JohnRobHolmes is offline   Reply With Quote
Old 11-20-2014, 05:22 PM   #962
The next improvement is just in the looks department, but looks matter! As shown here, we have begun working with a company to bring anodizing and better can finishes to the mix. Costs more for us, but not for you! You will find the deep black luster on all Pullers cans from now on, and we will be offering anodized parts very soon. What colors do you want on the faceplate?
Old 11-20-2014, 06:08 PM   #963
Moving forwards into 2015 we have a few big changes coming for easier maintenance and more competitive folks.
The first change will be the can assembly. Instead of long cinch screws holding the motor together, we are going back to a traditional short timing screw. After many many hours of design consideration, we have figured out how to accomplish this AND shave 5 grams from the motor without resorting to performance degrading thinning of the back iron.
Second change is the brush assembly. The design goal was to increase conductivity without a weight increase, while offering a more compact design. Bonus time, it also seals the motor better from contamination! We will be machining these hoods very soon.
Third change isn't really a change, but a return to our roots in offering Cobalt Pullers. While Cobalt magnets are lower in power density, they are more temperature stable than Neo. With three slots this will allow a tighter airgap. This won't be a sweeping change, but an additional option on specific builds because in reality it will reduce power to weight ratio in most installations. Same as brushless motors, if cobalt offered an advantage it would be more common than neo mags. But Cobalt Puller sounds cool! And maybe some people run their motors past 160f, but so far we haven't found those folks in the competitive arena. So let us know if you run them boiling hot and we will have something for you to test!
Old 11-21-2014, 11:18 AM   #964
Sweet news John as I will be looking to update my motors very soon in both rigs
chevotafun is online now   Reply With Quote
Old 11-21-2014, 12:05 PM   #965
The finish on the can looks so good now! Way to go John.
mtdriver is offline   Reply With Quote
Old 11-24-2014, 08:31 AM   #966
John,
When will these new motors be available?
Old 11-24-2014, 04:05 PM   #967
Which part? New housing, Cobalt Puller, anodized parts, new brush system?
Old 11-24-2014, 04:18 PM   #968
ALL of it but the cobalt puller magnets.
Love the extra weight lose and the fact you offer a 11t in the crawler 500 now.
Will be looking for 3 of these
2 for my moa and 1 for the sporty
Old 11-24-2014, 08:52 PM   #969
Boiling hot? Hows 100-110 outside temp sound?
Vegas summers should do the trick with ease!
doublej is offline   Reply With Quote
Old 11-24-2014, 09:44 PM   #970
I'll be shooting for housings and brush system by first part of 2015.
190f magnet temp with the neo grade we use is where our tested cobalt grade starts to take over on force. But there is still plenty of fade elsewhere, the brushes and copper don't like those temps very much. Vs lower temps with neo its still less low end and snappiness, so in reality it's kinda meh unless I find a magic combo where weaker cobalts gain an efficiency edge enough to offset the coercive loss. Riveting, I know
I've been using the worst temp rated mags possible in my own rig, n50s. Never gets warm enough to fade when geared right, but startup suffers because the pole tips get driven into saturation. There's a lot more to balancing the magnetic circuit than it seems! It's one reason we can't just throw high strength mags in a regular 540 and expect an improved motor all around.
Old 11-24-2014, 09:56 PM   #971
Sounds fun to me, but we regularly play in stupid heat - so I find it interesting.
It's is a balancing act of run time vs chill time.
Next time I dona summer run to the "sandbox" I'll let you know, you can add 20 degrees over there on a mild day.
Old 02-22-2015, 09:40 AM   #972
John, your site wont let me make an account to order one of these beasts.
Jeepkid is offline   Reply With Quote
Old 03-17-2015, 08:40 PM   #973
I have 13t puller's with the large cans. I'm wanting to lose some weight and gain some ground clearance. I'm looking at Team Puller 500 Crawl 13t with 20 gauge wire. For my Bully 2.
Is there much of a difference between the old big can and the newer small can with 20 gauge wire? Less drag brake? Less power?
SDheavymetal is offline   Reply With Quote
Old 03-17-2015, 09:48 PM   #974
The new can doesn't affect power or drag, I didn't take away back iron. You will really like the 20g wire option, it is a huge difference over the regular 21g wire.
Old 06-29-2015, 05:20 PM   #975
So we may be able to get more OG Cobalt Pullers made, rumor has it a few hundred cans were found tucked away in a box. We will also get plenty of replacement armatures and brushes if this goes down.
If this goes through, what turn would most people want? I would assume 10 turn since that was always the most popular.
Old 06-30-2015, 12:08 PM   #976
PapaGriz Yo
Grizzly4x4's Avatar
I'd love to have another 7 turn. If not I still love the 10 turns, I just put a bigger pinion on.
Grizzly4x4 is offline   Reply With Quote
Old 07-01-2015, 05:15 PM   #977
10t probably best since it stays cool on 3s and most the guys I scale with run 3s only so that's definitely something to consider.
I have a 5t and it runs well on 3s, I just have to run a very small pinion and be cautious about running WOT that often.
Shinjari is offline   Reply With Quote
Old 07-01-2015, 05:52 PM   #978
Depending on price I would take a 7 and a 10 turn.
Sent from my XT1080 using Tapatalk
horsinaround is offline   Reply With Quote
Old 10-01-2015, 10:08 AM   #979
I'm looking for a new motor for my rig, which Puller 500 would fit best a heavy 1.9 SCX10 for G6 application? 15T ?
Also is it possible to order it reversed? (I'm using Currie and I can't move around the transmission)
Thanks.
Gilles.
utieh is offline   Reply With Quote
Old 10-06-2015, 06:11 PM   #980
I'd take a 7 and 10.
Slayso is offline   Reply With Quote
HH Cobalt Puller- Reborn page 35! - Similar Threads
R1 + Cobalt Puller Highlucks G-Made Crawlers 3 05-31-2010 09:38 PM
You may edit your posts
