12-18-2007, 01:16 AM | #181 |
ghetto fabulous newbie Join Date: Sep 2007 Location: with your mom
john please help me out finding a answer.Click servos Also do you think a Elite 2000 10 cell would be enough power for the Scorpion 3032-10? estimated runtime with the elite 2000's for my super? also what do you know about the Scorpion 3026-10,how would that do in a super? Thanks Last edited by yotachump; 12-18-2007 at 01:28 AM. |
12-19-2007, 09:04 AM | #182 | ||||||
I didn't have the net for a few days, time to catch up. Quote:
12-19-2007, 09:05 AM | #183 | |
12-19-2007, 09:27 AM | #184 | |
Rock Crawler Join Date: Jul 2006 Location: Northeast
Hi JRH, I think you missed this question of mine. What motor are you carrying right now that would be good for this setup? Again I am looking at using a mamba max and putting it in a jugg gearbox for now, moving onto an emaxx tranny. Edit: I would also run 1 pack if I could run only one motor. | |
12-19-2007, 10:41 AM | #185 |
The hardest part is the tranny and axles. You wont have much geardown to work with. The second issue is the voltage. With any heavy vehicle you are best using a higher voltage with a slower motor. I still have one XL feigao motor left, it would work well but needs a 5mm pinion. Is this basher only or will you want it to crawl too? |
12-19-2007, 01:12 PM | #186 |
Quarry Creeper Join Date: Jul 2007 Location: Mac
JRH, ETA on getting AX-10's back in stock?
12-19-2007, 01:24 PM | #187 |
12-19-2007, 01:30 PM | #188 | |
This is going to be a basher. | |
12-19-2007, 05:04 PM | #189 |
SCALE PERFORMANCE PARTS Join Date: Oct 2007 Location: Cedar Park
| Lipo stuff
John, I'm almost ready to take a step up into the Lipo world and was wondering what you'd recommend for me based off of the products you carry. I'm planning on making this change in January... For the batteries, I'm thinking about these: http://holmeshobbies.com/product.php...&cat=10&page=1 I'm running a Mamba Max with a CC BEC (that I'd lke to run at 7.2v) and a 55t Integy. Sound reasonable? Oh I noticed your batteries seem to be a lot smaller physically than the Great Planes one I was looking at in my LHS. It was 124x42x22mm 15C 2100 mah 3-cell and yours is 65x34x20mm. Why/how is that? Is that because they have a built in balancer? What is the good/bad to having balance built in? I'll also need an AC/DC charger and want one that does everything I'd ever need it to do to a Lipo (balancing, etc). I have a seperate charger already for my Nicd packs so discharge on the Lipo charger isn't necessary (I think). So I'm thinking about this: http://holmeshobbies.com/product.php...5&cat=7&page=1 I'm not sure I understand the balancing & adapter part though. Could you explain it to me in small words? Last question is about the plugs on the ends of the batteries... I currently have Female Deans plugs on my ESCs and it looks like the batteries come with Females as well. Is that something I can change on the batteries or should I redo my ESCs and all my other batts? I didn't have any specific reason for doing it that way, it just turned out like that and I notice some of the Lipo batts have warnings about messing with the wiring. Thanks, Patrick Last edited by Locked Up; 12-19-2007 at 06:28 PM. |
12-19-2007, 05:26 PM | #190 |
My question must have hit a nerve or been to hard to answer :-P I get forgotten alot |
12-19-2007, 06:49 PM | #191 |
| Missed the question, sorry. I don't have enough time to handbuild packs, but I can get them made in bulk with welded or soldered construction. I will put those on the next order for packs, and Cheapbatterypacks is a place you could get them made asap. Which construction type do you want?
12-19-2007, 07:02 PM | #192 | |
| In that case your budget is really your limit for speed. Just how fast do you want to go, and would you consider lipo? A mamba max/ 8xl combo would work well for 12-14 cell nimh (35-40mph) and about $210, but if you want to go really fast you need more voltage and a more expensive motor. Quote:
1. The lipo must be larger in size because of the built in balancer, (if it indeed has one). Otherwise I cant guess on why the batteries are a different size. If you have a balancer you don't one built into the pack. 2. The charger and balancer in the 0606i work without fuss. Basically you charge the lipo like normal with just a few button presses, and the balancing tap is plugged into the side of the charger too. The adapter makes about any brand of lipo balance on the charger. The vislero lipos I carry come with an adapter so you wont need a different one. 3. Your batteries need a female plug, ESC's and brushed motors get the male plug. Having a male on the battery is dangerous really, especially on good sub-c packs. A shorted sub C will drain upwards of 500 amps momentarily before it starts to heat up fast. | |
12-19-2007, 07:12 PM | #193 |
Thanks John. I'll go ahead and redo the ends on my ESCs and batteries and will let you know when I'm ready to order. I didn't think about shorting the batteries with the male ends. Guess I was preparing myself for natural selection |
12-19-2007, 07:14 PM | #194 |
Shorted packs are no fun. I have ruined a few myself.
12-19-2007, 07:18 PM | #195 | |
12-20-2007, 04:20 PM | #196 | |
Thanks JRH, when I get back from vaca in a few weeks I will be looking at getting something and will let you know. | |
12-21-2007, 11:28 PM | #197 |
Rock Crawler Join Date: Jan 2006 Location: Colorado Springs
This thread is a good idea!! So here's my question. I bought a Revolver 2 last year and I'm just now getting around to install it. The adapter it came with is shaped like an X, with the four inner holes the ones that match up to the motor. My problem is that I'm trying to put this into a pede tranny but the outer holes on the adapter don't match up. Do I just need to drill some new holes in the tranny or did I get the wrong motor adapter? It also came with a big red o-ring. THanks in advance, Tom |
12-21-2007, 11:58 PM | #198 |
do you think the Vislero 2100 3s lipo battery that you sell would be a good choice for my super with the Scorpion 3032-10? Estimated run time? if not a good choice for a battery, what lipo should i run? also the Mamba Max can only handle up to a 3 cell lipo, correct? im new to lipo, so on setting the Mamba max lipo cutoff on a 3 cell lipo i set it at 3 volts per cell?so a 3 cell cutoff would be set at 9 volts? Thanks Last edited by yotachump; 12-22-2007 at 12:09 AM. |
12-22-2007, 09:29 AM | #199 |
Quarry Creeper Join Date: Jul 2007 Location: south jersey
hey jrh, i have a dx6 and a vtail mixer, is it better to use the v mixer or should i just use the dx6 mixer,? also how long will lipos hold a charge if unused for awhile? thanks, and the lipo i got from you for the dx 6 fit perfect , thanks |
12-24-2007, 10:22 AM | #200 | |||
Otherwise you can get a machined motor mount. Quote:
Glad you like the RX lipo, they are sweet. | |||
(HH) Tech Questions and Customer support thread - Similar Threads | ||||
Futaba customer support | XJkid93 | Chit Chat | 6 | 07-24-2012 06:07 PM |
ZNO-RC Customer Support | ZNO-RC | Redcat Crawlers | 28 | 03-20-2012 08:44 PM |
axial customer support/service THANKS! | superflex | General Crawlers | 6 | 01-31-2011 08:40 PM |
airtronics customer support | dlamb11877sf | Electronics | 0 | 04-13-2010 10:04 AM |
